Old 12-19-2013, 09:38 PM   #941 (permalink)
Originally Posted by lcc014 View Post
First 450 Pro 6S build:
What head and grips are you using there? I have a Tarot head with integrated swash driver that has worked well enough but there's quite a bit of slop in the grips regardless of what I do.
- Eric
Compass Atom 6HV, KDE 600XF-530 motor, CC Ice2 HV 80, Torq Servos, BeastX
MSH Protos 500, Scorpion/YGE, Brain
GAUI X3 6S, Xnova 1860, HW 50A V3, MKS DS95, 8910A+, BeastX, Belted Tail.
isogloss3d is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 07:47 AM   #942 (permalink)
I am using RJX head (bought from HK) along with Align DFC main shaft.
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 12-26-2013, 11:26 PM   #943 (permalink)
Originally Posted by Arey26 View Post
Thanks man. It's new and that was just my first 3D flight on the X3. I plan on throwing it a little bit more once everything goes well.
Update on my NTM 1700kv motor.. it does run hot whatever I do. I removed it from the heli. Run it alone and still got hot after only a minute. Tried on the K-Force esc (well basically the same but maybe my platinum has a problem) still same. Tried on a Turnigy Plush (oh well almost same as the hobbywing) still the same.
So does anyone using this motor which doesn't get hot? What esc and settings are you using? I'll try borrowing different esc from our group just to really know if I need to change the motor.
@Icc014, I see we have the same motor. How's the temp on your motor after a flight? What esc and setting do you use?
Regards,
Arey
Yeah that was a wonderfully smooth flight and good video too! Are you able to get a temperature reading from the motor? Some motors simply run hot (especially if ambient temperature is also high) but if within specified limits it's generally not a problem.
When I first read your post I assumed the heli you were running this motor on was a Trex 450 Pro. I understand the Gaui X3 is a little larger and heavier so I'm sure you're giving this motor a workout, especially if you're using 350 mm main blades.
- Eric
Old 01-09-2014, 08:06 AM   #944 (permalink)
Hi all,
I'm almost finished with my 6S setup. But i have a question. I have a Scorpion HKII-2221-2010kv motor + Castle EDGE 50 controller. I initially wanted to get TGY-306G-HV servos, but purchased the regular non high voltage TGY-306G servos. Will they work?
av3nger is offline        Reply With Quote Quick reply to this message
Old 01-09-2014, 08:29 AM   #945 (permalink)
Default Re: 6S Setups (Sticky)
Yup.
Sent using Tapatalk.
Old 01-09-2014, 09:03 AM   #946 (permalink)
Originally Posted by av3nger View Post
Hi all,
They'll work great, just make sure your BEC output is set to 6.0 V or less. That is configured in the Castle configuration software. The default setting will be safe (I think it's 5.5 V, if not 5.0 V).
| Jeti DS-16 | Compass 7HV / HC3SX | SAB Goblin 500 / iKON | Align Trex 500e DFC / AR7200BX | Tarot 450 Pro DFC / iKON |
tracernz is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 05:55 PM   #947 (permalink)
Default Align 6S 1250 Lipo
Is anyone running the Align 6S 1250ma Lipo and if so, what do think about them?
470LM HW Platinum Pro 60A, Brain
dannym is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 06:23 PM   #948 (permalink)
They are good so far, mine are very young but fit, form, function, and performance are all good so far.
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 06:13 PM   #949 (permalink)
3 months, light use, and they are still working well!
Old 03-29-2014, 02:53 AM   #950 (permalink)
Thanks for the update.
My Thor 6S 1350 mAh packs are my favorties so far (brick style). 1.5 yrs and 100 cycles each on the first two I bought and still going strong. Mostly run at governed 3000 rpm for 5 min, 20 sec flights of mild 3D. I picked up two more before Readyheli closed down. I'm wondering if there's another US vendor?
- Eric
Old 06-18-2014, 08:25 PM   #951 (permalink)
Try these packs if you want the best performance.
http://dinogylipos.com/6-cell-65c/159-5000mah-6s-65c
Mark
MarkF is offline        Reply With Quote Quick reply to this message
Old 06-19-2014, 06:05 PM   #952 (permalink)
Mark
Looks good, but can't sure its performance and durability. and little bit expensive..
chan is offline        Reply With Quote Quick reply to this message
Old 06-19-2014, 08:04 PM   #953 (permalink)
Back in January I got some Gens Ace 1200 packs. The packs are working well, but I would like to get some packs that have more runtime.
Trexwilly, are the Align 1250 packs still working good? I am considering the Align 1450 Lipos.
Old 06-19-2014, 08:19 PM   #954 (permalink)
The 1450s I have for my 450L are working great! They are really made for the L though they fit good on the X3 too, they are a bit long for the 450Pro,,,
Old 06-20-2014, 03:24 PM   #955 (permalink)
I am looking for batteries for a 450L, so that's good news. Thanks for the info Willy.
Old 06-22-2014, 07:36 PM   #956 (permalink)
I just got Pulse 1350's for the stretched 450 pro. They fit under the canopy. Hope to fly this week.
I didn't crash. I just ran out of airspeed, altitude, and idea's all at the same time.
cobieg is offline        Reply With Quote Quick reply to this message
Old 06-29-2014, 08:41 PM   #957 (permalink)
Here is mine! I finally got it 100% changed over to a stretch with tail blades as well. I do have a issue with the tail. It's not a wag, but a twitch. It is not the gain because when I do a pitch pump the tail is solid.
Micah
mhills51 is offline        Reply With Quote Quick reply to this message
Old 09-14-2014, 06:49 AM   #958 (permalink)
Originally Posted by SHYguy View Post
I have this one in my T-Rex, it really rips!
http://www.hobbyking.com/hobbyking/s...00KV_930W.html
Which motor do you prefere in a 450?
That one or the 460mx from dominator?
skndol is offline        Reply With Quote Quick reply to this message
Old 09-14-2014, 06:52 AM   #959 (permalink)
Which motor do you prefere?
Is for a 450pro dfc
Old 10-08-2014, 11:17 PM   #960 (permalink)
I just upgraded my 450 pro dfc to 6S. That means I changed the motor, esc, & lipo. Just "maiden-flew" the bird to get a feel of the rpm vs throttle position. What I found to be interesting is that 3200 rpm is achieved with 52% throttle. I can only imagine the speed if I push to 100% throttle.
In my stock 3S configuration, I get to 3200 around 87% throttle.
My suspicion is with the new electronics & pinion I'm using. Here's my new setup:
Align 460MX, 1800KV
KOBY 40LV esc
1300 mAh 6S lipo
Stock 12T pinion
Anybody with any thoughts on the issue and what can be resolved?
dgunawan1 is offline        Reply With Quote Quick reply to this message
Tags
450 6s
