Old 07-23-2013, 03:22 AM   #1 (permalink)
Default multi rx help please
This may have been answered many an occasion already, but can you bind an Align 3GX gyro/receiver and another Spectrum receiver to the same transmitter to run more channels? Please help, Thankyou.Emilio
hoversmooth999 is offline        Reply With Quote Quick reply to this message
Old 07-23-2013, 05:10 PM   #2 (permalink)
by the way.. this is for a blue thunder scale prodject. I need an extra channel to.run a seperate throttle curve since this heli. has a seperate powered tail with pitch control. programming to a DX8.
Old 07-23-2013, 07:58 PM   #3 (permalink)
I don't use a DX8 but cant you assign your powered pitch control to 5 and mix somehow?
Separate throttle curve? Sounds like revo mixing.
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 07-23-2013, 10:19 PM   #4 (permalink)
thanks bad 007, in a way I will be revolution mixing. what it is, is a fuselage that takes a 600 size heli with the tail drive components removed. the tail on this heli is run by a seperate esc and motor, but the tail still has pitch control as well. so the tail gyro from the 3gx is still used to control the tail pitch servo but another channel is needed to run the seperate tail esc and motor. it cant be tied to the main throttle because that would cause a loss of tail control when reducing collective to descend. the tail is a Fenestron tail. the 3 gx does not have any open channels, hence my need of a second dsm receiver that has an 8 th channel for the second tail esc. really the eighth channel is all I need the second receiver for. just need to know if I can have the 3gx and another dsm receiver bound to the same transmitter. APOLOGIES for the lengthy explanation. and thanks again. any recommendations appreciated.
Old 07-24-2013, 07:25 PM   #5 (permalink)
Use a 8 channel RX and wire it as if you where using a DX6 and a 6 channel RX as per instructions and gear would be tail gyro gain.
You don't bind the 3GX at all, you bind the sats if your using sats and bind a RX if using an RX.
