Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Genius CP
Genius CP Walkera Genius CP Helicopter Support
Old 11-20-2012, 09:52 AM   #21 (permalink)
Darn. I think there may be a limit on times you can edit a post, and I've reached it lol. Hopefully I won't just have to redo the whole post.
Copying and pasting is such a pain!
Blade CP...whatwillitbecome?...
Genius CP...mainfun-timeflyer...
CopterX 450 Pro...constanttinkering...
What Now?!?
sbillingham is offline        Reply With Quote Quick reply to this message
Old 11-20-2012, 05:34 PM   #22 (permalink)
Great thread sbillingham.
There is a 15 day edit limit here on Helifreak.
If you would like to edit or add to your post send TowPilot a PM and he can
edit or add to whatever you like for your post. He does this for my posts also.
Thanks for linking my setup guides.
Tom (Tom Z on Rcgroups)
CX2Pilot is offline        Reply With Quote Quick reply to this message
Old 11-21-2012, 07:15 AM   #23 (permalink)
That's great info, Tom. And thank YOU for your setup guides! Couldn't have gotten off the ground without them, I do believe!
What Now?!?
Old 11-21-2012, 10:46 AM   #24 (permalink)
Also, I asked him to add credit for your guides. Oops, my bad!
What Now?!?
Old 11-21-2012, 06:56 PM   #25 (permalink)
Your welcome.
I'm glad the setup guides were able to help you out.
Tom
Old 11-29-2012, 08:53 AM   #26 (permalink)
A big thank you to TowPilot for dealing with all my edit requests! Added a link to Rideveer's GCP to Mini CP conversion guide and added credit where credit was due.
Happy Flying!
What Now?!?
Old 12-03-2012, 09:02 PM   #27 (permalink)
This should be a sticky. I have it bookmarked on the pc
dogtooth is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 12:51 AM   #28 (permalink)
bump.
Rockin' the world and flying... that's where i live..
oxide1 is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 02:50 PM   #29 (permalink)
Happy Flying!
Thanks for thinking enough of my mod to link it. It's rldeveer not ri and link didn't work when I tried, but post is still there.
RD
rldeveer is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 11:36 PM   #30 (permalink)
WOOHOO!!!!!!! finally made sticky!!!! was chipped by the mods for bumping this to the top of the list, fair enough if that's the rules..... don't have to anymore!!! this thread is where it should be!!!!! sbillingham awesome work on this thread!! it deserves to be sticky, well done!!!!
Old 12-07-2012, 08:48 AM   #31 (permalink)
Well that's cool! Thanks for that!
What Now?!?
Old 12-07-2012, 08:59 AM   #32 (permalink)
RD
Absolutely! PM'd the edit request to get the SN right and to fix the link lol. My apologies! And, hey, thanks for taking your time to write that whole conversion up. Carpal Tunnel!!!
What Now?!?
Old 12-07-2012, 05:35 PM   #33 (permalink)
Finally got stickied!
LameBMX is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 11:49 PM   #34 (permalink)
Just adding this link as it's relevant to my head rebuild and the Minius head rebuild:
I've found the #003 O-Rings in 90 Dura Nitrile rather than 75 Dura Viton HERE:
http://www.amazon.com/dp/B0051XYL2E/ref=biss_dp_t_asn
I use the 75 Dura Viton ones with mCPX bronze washers; they work very nicely. I think these should provide a slightly firmer head even, provided they don't make the grip bearings crunchy.
mnem
Crunchy. But not good with ketchup.
mnementh is offline        Reply With Quote Quick reply to this message
Old 12-17-2012, 04:38 AM   #35 (permalink)
mnem
I just ordered up the 75d bag of 100 myself. Still in the air. Waiting patiently to hear an opinion of which is better. Obviously stiffer is better performance wise. Softer is better because will help keep other parts from breaking. Do you use o-rings to stiffen up a servo saver mod? I tried the not cut all the way through saver mod, but it still toasted a servo.
Old 12-22-2012, 12:43 PM   #36 (permalink)
I really like the feel of the head with the 75 durometer #003 o-rings; it is STILL considerably firmer than the stock setup. I don't know if the 90 durometer ones will go together without making the grip bearings go crunchy, and I doubt I'll be a good enough pilot to NEED that extra firmness for a long time. Like... anytime before I use up a whole baggie of the 75/#003 o-rings.
I don't use the servo-saver mod at all; I've broken 3 servos all told since I bought the heli. Now that I'm in the neighborhood of having an actual helicopter instead of a suicidal hummingbird, I'm probably going to either start hacking the $5 cheaper Mini FP WK-02-5 servos with the control boards out of my old Genius CP WK-02-4 servos, or I'm going to try the HK-5320 / HK-5330 servo mod.
At $3.44 each, sure is an attractive option; even if I do have to make some shims to fit them and reverse them internally. Well, reverse two of them; they're normally reversed for the Genius, so the Pitch servo can stay stock. Oh, and you have to swap the ground & signal wires at the plug on all of 'em; takes about 30 seconds. Easy-peasy, and you only need to make the shims once. Downside is you kindof have to change them ALL at once to keep response times uniform.
http://www.hobbyking.com/hobbyking/s...c_0_075kg.html
http://www.hobbyking.com/hobbyking/s...ec_0_17kg.html
Before long, there'll be nothing left that's Genius except the mainboard...
mnem
I can live widdat.
Old 01-11-2013, 09:29 PM   #37 (permalink)
If you travel with a Devo-6 (or similar?) radio, you can remove the back and flip the hand bracket so it is much more flush and easier to ship for those of you who can't seem to leave the birds at home.
Intheway is offline        Reply With Quote Quick reply to this message
Old 03-16-2013, 08:06 PM   #38 (permalink)
Everyone!
Make this change the next time you have to get a new frame/skids for your Genius. Same amount of work and only left over part is the GCP servo holder. Cost less and will save $ in long term. Haven't bought a skid or frame ($3-$4 ea) since, GCP frame $12-$13. The frame is solid as a rock as compared to the GCP frame. I can't say enough about this mod. Only odd ball is the servo link and you just need to get a longer rod that you can put the dog leg in. P/N above worked, snip to length, screw on one end as normal and CA/hot glue the other.
RD[/QUOTE]
Hope this thread is still active. Can you describe the mods you did to mount the RX tray? Did you have to add support under it? Also, how long is that custom pushrod overall?
egero1 is offline        Reply With Quote Quick reply to this message
Tags
devo, genius, guide, setup, walkera
