Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 09-17-2011, 06:11 AM   #1 (permalink)
Default Gaui 425 shaking help
I need some help please with my 425....
A few weeks ago I had a minor crash, checked everything and replaced main shaft, feathering shaft, flybar and main blades.
Blades are balanced, nothing is bent but she shakes like mad, so much that when off the ground you cant read the lettering on the skids
Have I missed something or done something wrong in the setup because I am stumped
any advice or comments would be welcome
Blade QX, Align Trex 500, Gaui 550 Hurricane, HK600GT, 450 Quadcopter
I have a perfect record in helicopter flight......I've never left one up there!!!!!
Davy Crockett is offline        Reply With Quote Quick reply to this message
Old 09-17-2011, 09:47 AM   #2 (permalink)
Check the tail shaft and the hub that the tail blade grips bolt to. Another possibility could be a bent head block.
KRYPTO316 is offline        Reply With Quote Quick reply to this message
Old 09-17-2011, 11:29 AM   #3 (permalink)
I have found part of the problem....
I had put the thrust bearings on the end of the feathering shaft instead of inbetween the 2 bearings
maybe I should learn to place things in order when I take them off the heli
Old 09-27-2011, 06:18 AM   #4 (permalink)
You said you found part of problem, was that it? I am having similar prob. shaking horribly w/out blades at 1/4 throttle. As i spool up can't see any wobble in shaft then at that speed, shakes terribly. I will check the tail and thrust bearing but do not think bearing at this low speed w/out blades.
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is online now        Reply With Quote Quick reply to this message
Old 09-27-2011, 08:14 AM   #5 (permalink)
I had put the thrust bearings on the end of the feathering shaft instead of inbetween the 2 bearings in the main grips
Old 09-28-2011, 01:30 AM   #6 (permalink)
Check the swash plate. Some of them were assembled incorrectly, and were 'off-center'. Spool it up slowly and watch the swash plate to see if it appears to wobble around.
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote Quick reply to this message
