Old 02-13-2012, 07:14 AM   #61 (permalink)
Cirkus that rig is coming along very nicely, I have also been thinking about mounting the shocks in an angle.
Congratulations, hope to see the maiden flight soon!
By the way, what scorpion motor is that?
Craneman is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 09:08 AM   #62 (permalink)
Its a 5035-410 (look on page 3)
The shocks work well at an angle, but I think I need to mount two more vertical. The angled ones keep the mount centered, and the outboard mounts dampen the roll of the mount. I think together they will work best.
I'm shooting for next weekend for a basic maiden, without a payload and no video Rx. Just tuning, hover duration testing, and that sort of stuff.
FlightCam
http://ryanbarnes.smugmug.com/
Cirkus is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 11:13 PM   #63 (permalink)
The WooKong-H arrived today, so I got right into installing things. I haven't seen very many WK-H's on the internet so here's a couple unboxing pics as well...
Top
Side
Bottom
Creamy chocolate center...
The goodies...
Bags
Out of the bags
FlightCam
Old 02-13-2012, 11:19 PM   #64 (permalink)
The main stuff
Protecting wires
GPS and status LED. The LED is canted so I can see it while standing next to it and also while its overhead. I will be making a silicone mold to blend it into and hold it firmly to the boom.
The WK-H, the Rx, and a few other bits of excitement, will go in here. It will be nicely padded and organized, of course.
Here, you can see the front legs are the first version, and the rear legs are the (hopefully) final version, giving more height and clearance under the gimbal.
I know the box looks a bit off right now, but there's a plan and it won't look quite right until I get all the parts in place, so don't flame me yet...
FlightCam
Old 02-13-2012, 11:29 PM   #65 (permalink)
That's all for tonight. Tomorrow, I get some more G10 plate material to cut the other half of the front gear legs. Also, I will be replacing the hardware used to assemble the legs. Right now it is held together with 8-32 bolts, through a nylon spacer, and held with nylock nuts. I will be replacing that with stainless 8-32 countersunk flathead screws from both sides and the nylon spacers will be replaced by aluminum threaded spacers. It should polish the looks of the gear a lot.
FlightCam
Old 02-14-2012, 03:10 AM   #66 (permalink)
You'll have a full plate for a little bit... looking good
JR9303 / JR9503 / Futaba10CHP
Old 02-15-2012, 01:05 AM   #67 (permalink)
OK, so I started today by swapping out the old landing gear hardware for the new stuff, see below...
Old hardware
Old hardware installed
New hardware was less than 1/2 the weight, plus it just looks so much better...
Old and new...
FlightCam
Old 02-15-2012, 01:13 AM   #68 (permalink)
Then I just had to clean up some wiring. All these wires are making me crazy, time to get some of them under control!
I had to make some extentions to get the wires routed where I wanted. It's more trouble but in the end it's worth it.
Hey, that looks factory!
All worth it in the end...
Getting some idea of how these will mount when it gets the foam liner...
I ended up doing this to the collective servos, throttle lead, rudder servo, and Spektrum sat lead.
Rudder servo lead runs down and away from GPS antenna and lead, just a bit more separation for good time's sake.
FlightCam
Old 02-15-2012, 08:12 AM   #69 (permalink)
be sure you use cable ties to hold down GPS mount to the boom, there are two slots made for this use.
tpnitro is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 08:20 AM   #70 (permalink)
I'm actually going a different route with that. It will have a silicone molded fairing to hold it.
FlightCam
Old 02-16-2012, 01:42 AM   #71 (permalink)
I didn't get as much done today that shows, mostly tedious wiring and little stuff.
I did get the silicone fairing molded around the GPS mount. I used Sugru. If you don't know what it is, look up www.sugru.com it's awesome.
I also redid the gimbal electronics. Mostly because I found some nicer looking LED voltage displays and switches.
Old and new
There are two batteries now, a 2-cell lipo for the Picloc, and a 3-cell for the video tx.
FlightCam
Old 02-16-2012, 10:02 AM   #72 (permalink)
Hey, that Sugru stuff is cool, thanks! Out of curiousity, how many little packets did it take to make the fairing? Are you going to have to redo it any time you change the tail boom?
R_Lefebvre is offline        Reply With Quote Quick reply to this message
Old 02-16-2012, 10:39 AM   #73 (permalink)
Yeah, Sugru is my new favorite stuff on Earth! It took 2 of the individual packets to do the fairing. And yes, it's semi permanent but can be removed without harming the components. If I have to replace the boom, I have had a serious failure and will likely be replacing many other parts as well, so no issues cutting it off at that point.
My transmitter took one packet of orange.
Auto mode and hold switch
Flight mode and gyro switch
Also, I had concerns about plugging in my servos incorrectly to the Picloc and shorting it because it has 4 rows of pins vs. 3 rows, so I covered the last row. I stripped off the yellow signal wire from the wire you see in the background, cut it in sections and pulled out the wire to make little hollow tubes. Once I had them all on, I cut them flush. No more shorting possibility.
FlightCam
Old 02-16-2012, 11:16 AM   #74 (permalink)
Labeled...
FlightCam
Old 02-16-2012, 11:24 AM   #75 (permalink)
You have some great skills and imagination. Very well done!!!
Chris_M is offline        Reply With Quote Quick reply to this message
Old 02-16-2012, 12:04 PM   #76 (permalink)
Default ...
Very nice work......... and very nice of you to share your work here with us.
I really like the electronics box you created for the gimbal.
@ [B]Cirkus[/B..... PM sent.
Keep us posted as you move forward with this project and others...
JASON
tott is offline        Reply With Quote Quick reply to this message
Old 02-16-2012, 01:03 PM   #77 (permalink)
To all:
I have received several PM's about the electronic enclosure I made for the gimbal. To address a few things:
1. Will you sell me one? No, not at this time. I don't have the spare time since my heli isn't finished yet. I might (MIGHT) sell the boxes precut on the CNC machine, with the switches and displays included for you to build your own, since the cutting of the squares are pretty much impossible to do by hand.
2. Then will you provide a parts list where I can purchase the same parts? Absolutely
3. Will you post a step by step build on how you put everything together? Sure, I have a long weekend this weekend so maybe I can knock out a how-to.
Even though the whole purpose of doing AP (besides the enjoyment of it) is to make some money, I don't really care to make money selling this idea. I'd rather just share the info, and if you like my idea well enough to use it on your own project, thats cool enough for me.
FlightCam
Old 02-16-2012, 01:39 PM   #78 (permalink)
Thanks Cirkus for addressing this.
IF you do decide to sell the boxes precut with the parts, put me in line for (2) to start.
Back to the Post.......
It is great to see you are constantly looking to better you designs for your rig. I am excited to see the progression and the flight of this beauty......Great job.
Mahalo Nui Loa,
JASON
Old 02-17-2012, 02:26 PM   #79 (permalink)
Finished the gear last night
FlightCam
Old 02-17-2012, 03:15 PM   #80 (permalink)
Wow, she's pretty big. You're staying with a flybar?
