Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 12-20-2010, 04:09 AM   #1 (permalink)
Default Building my Velocity 90.
For those who are intresting, i like to show the sweetest 90 which i ever
hold in my Hands,,
My Setup:
3 times Futaba BLS-253
GY-701 Gyro Futaba
Outrage Torq Tailservo
Futaba S-Bus Reciver
All Electronics runing straight up on 8 Volts, no Regulator no Swich.
The Servos are crazy fast on 8V:eek::eek:
Engine will be the YS-3DS with the new Outrage Pipe.
more Picture soon.
ID:	196286   Click image for larger version
ID:	196287   Click image for larger version
ID:	196288   Click image for larger version
silverbullet is offline        Reply With Quote Quick reply to this message
Old 12-20-2010, 10:57 PM   #2 (permalink)
BLS253 on 8V, really? They are spec. for 6V max.
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX
Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451
wolfdown is offline        Reply With Quote Quick reply to this message
Old 12-21-2010, 12:38 AM   #3 (permalink)
Many people are finding out that some of the futaba bls are so over built they can run on near double the voltage. Not the BLS-251 though. They are good servos. Your gonna love that gy701. Its amazing
johnpotter82 is offline        Reply With Quote Quick reply to this message
Old 12-21-2010, 02:52 AM   #4 (permalink)
Jes Guys, see Robbe -Futaba have uptadet officaly that the BLS Serie can runn on 2S Lipo without a problem.
(Excluding the BLS 252-254 Tailservos,) Also same for the HS and S-Bus Reciver serie.
U have to scroll down the PDF to the end, there u will find the infos (sorry its in German)
http://www.futaba-forum.net/basic/do...ervos_2010.pdf
Old 12-21-2010, 08:29 AM   #5 (permalink)
Hey Hugo
You copied my setup
- BLS 451 Cyclic
- Torq 9080 Tail (until i can get a "real" Torq Tail servo - however 0.05 should be OK)
- one of the new Hyperion HV Servo on trottle
- GY 701
- Futaba S-Bus RX
- Perfect Regulator Fail On Switch - direct 2S
- YS-3DS with Hatori YS V2 pipe
And I do have the same Canomod Cannopy too
Build is almost done. This is by far the best heli i ever built.
All I need is some time to fly that thing
harryboe is offline        Reply With Quote Quick reply to this message
Old 12-23-2010, 03:33 AM   #6 (permalink)
Here are some pictures of the setup ..
Few things to note:
- The Perfect Regulator fail on switch has two "Servo" leads soldered on for redundant power in.
- I also have a PushGlow next to the started shaft - I love that gadget
- The wiring id extremely simple and clean - most of the servo cable over-lenght go safely under the pitch servo. Folded them there and added some shrink tubes to keep them in place.
- I had to mod the Gov sensor mount. Drilled two holes to mount the sensor on the inside of the frames. No big deal and very clean as well
I really love the way this heli is designed. There are so many nice features.
Just one example: The servo mounts - the servo can travel a bit together with the mount tabs as long as there are not screwed on fully; this allows to set-up the push pull links without any stress on the servo bearings. Well Done!
ID:	196704   Click image for larger version
ID:	196705   Click image for larger version
Old 12-23-2010, 03:59 AM   #7 (permalink)
I'm not sure how to read this. The torqure ratings do not match specs from servodatabase.com. Is this independent testing values? Are the units in oz/in ?
Old 12-24-2010, 12:04 AM   #8 (permalink)
i think its newton centimeters. A euro torque unit. Just google a conversion to oz/in
Old 12-24-2010, 03:26 AM   #9 (permalink)
thanks .. I was trying kg/cm but that wasn't working at all
Old 01-11-2011, 10:22 AM   #10 (permalink)
subscribed
Peter_SVK is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 06:35 AM   #11 (permalink)
Is there a muffler included in the kit, like the Velo 50?
Serbi is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 06:56 AM   #12 (permalink)
nope sadly
Fusion 50 sk-720 ,Fusion 50 v-bar , Velo 90 v-bar Outrage uk field rep...
millerman is offline        Reply With Quote Quick reply to this message
