Mikado Logo 800 Xxtreme Mikado Logo 800 Xxtreme Helicopters Discussion |
09-29-2015, 11:41 AM | #1 (permalink) |
Kosmik 200=nose heavy
With the new esc on my 800 it is a little more nose heavy than I'd like. So far I have shortened the esc to motor wires and saved 30grams. Not much but its a start. I have also removed my lipo tray and the two BIG strips of Velcro. I will be drilling holes in it (like Kyle did) in an effort to shed some weight. A lot less Velcro is going back on. Not sure where I can remove weight. Anyone else have this problem?
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1 VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL |
09-29-2015, 07:11 PM | #2 (permalink) |
My progress so far.
09-29-2015, 08:54 PM | #3 (permalink) |
You should be able to slide the battery's back on the plate some.
Even if you have to stagger the packs a bit. Could also eliminate the motor connectors . Just run the esc wire into a brass sleeve ( main blade bolts reducers) . Other than that , you've lost the big rx pack (assuming a mini buffer) . The 800 has such a light disk load that a few extra grams for a kosmic shouldn't cause any issues. Martin
Logo XXtreme 800 8917 / 256HV VBC Logo XXtreme 700 on 14s 8917 / 256HV VBC NEO Logo XXtreme 770 14s 8917/9188 VBC Logo 600 8917/ 9188 4035-500 VBC NEO |
09-30-2015, 09:14 AM | #4 (permalink) | |
09-30-2015, 10:55 AM | #5 (permalink) |
can you post a picture of how you cut your batt tray i have been thinking about it but haven't done it yet, thanks!
09-30-2015, 03:10 PM | #6 (permalink) |
Nothing fancy. I used a 3/4 bit. I was afraid of tear out from a hole saw. I still need to do some clean up on them.
10-01-2015, 11:43 AM | #7 (permalink) |
Nose heavy? How? Pictured is mine with Kosmik 200 Cool.
RC-Thoughts.com - TeroS formerly known as CP-Geek |
10-01-2015, 01:37 PM | #8 (permalink) |
Maybe my Thor packs are heavy compared to yours
I have a finless boom clamp mine Neo at the back with antenna mount Could you take a few pics with the canopy off?
10-01-2015, 02:08 PM | #9 (permalink) |
Sure. I have GensAce 4400 60C nowadays, they are about 840gr each in weight and they are not as back as they could be. I used to have GensAce 5000 40C, they were about 930gr eachand they had to be positioned as back as they would go but heli was still sitting on the mainshaft on the table.
EDIT: Also, my motor is rewound, heavier than original. Not much, maybe 50gr or so.
10-01-2015, 08:20 PM | #10 (permalink) |
I'll put my Thor's on a scale and see what they are. Cool pic sitting on the main shaft.
10-07-2015, 07:47 AM | #11 (permalink) |
I had the same problem and I wrapped a strip of lead (if I recall well, approx. 1 mm thick and 15 mm wide) just in front of the heck rotor housing. Fixed it with double sided tape and covered with black tape so that it was hardly visible.
I had to remove the extra weight when I put on the tail boom cover from www.heli-center-berlin.de regards, belgo |
