Old 10-31-2012, 07:48 PM   #1 (permalink)
Default Nano cpx trouble binding
Hey guys trying to bind my nano to my dx6i but after binding it blinks in 3 flash cycles I can bind my mcpx and 120sr just fine I can also bind it to the rtf transmitter just fine so I have no idea what im doing wrong. It seems like it kinda binds as I can control the rotor but can't make it spin...
Sent from my DROID3 using Tapatalk 2
dschumm is offline        Reply With Quote Quick reply to this message
Old 10-31-2012, 07:52 PM   #2 (permalink)
You are binding it in analog. Read the manual about binding it to a computer transmitter. It takes a certain skill to do i properly and will take u a few times but u will know when u do it right
fuzzyllamma is offline        Reply With Quote Quick reply to this message
Old 10-31-2012, 08:00 PM   #3 (permalink)
I did it right the first time I did it and thought I was doing it the same way I am now but ill try it again
Old 10-31-2012, 08:03 PM   #4 (permalink)
from the manual
1. Disconnect the flight battery from the helicopter.
2. Power off the transmitter and move all switches to the 0 position.
3. Connect the flight battery to the helicopter. The 3-in-1 Control unit LED fl ashes after 5 seconds.
4. Push the bind switch/button while powering on the transmitter.
5. After 2–3 seconds, release the bind switch/button.
6. Move the rudder control stick to full right. Continue to hold the rudder control stick to
full right until the
blue LED on the 3-in-1 control unit is solid.
7. Release the rudder control stick.
8. Disconnect the flight battery and power the transmitter off.
nothinbetr2do is offline        Reply With Quote Quick reply to this message
Old 10-31-2012, 08:13 PM   #5 (permalink)
Thanks im grabbing dinner at the moment will check when I get back home
Old 11-01-2012, 03:12 AM   #6 (permalink)
I had this exact problem. Called HH and got the default "send it in" response. Went to the LHS where I bought it on a busy saturday. After about 35 brains churned on the issue, one of the local heli guys came in and suggested using the binding process in the manual, but do it while actually touching the helo with the antanae on the radio. We shoved the radio right up against the canopy and did the bind process and bam. Bound first try. This is the only way my nano will bind to my DX6i. Stock radio and my modified 9x work from any distance but, my DX6i will only bind buy touching the bird with the radio. Hope it helps.
Hobbez is offline        Reply With Quote Quick reply to this message
Old 11-01-2012, 08:14 AM   #7 (permalink)
well, when i got back from dinner last night i followed the directions in the manual.. that didnt work any better then before does the exact same thing, never turns the light on steady. i swear this just worked fine like a week ago lol
i'll try that when i get off work Hobbez hopefully this will work for me!
Old 12-26-2012, 10:15 PM   #8 (permalink)
Default helppp
I just saw your post and was about to attempt to bind my dx6i to my nano. How exactly did you do yours? It says put it BATT/BIND mode...what is this? Appreciate any help...
danKx is offline        Reply With Quote Quick reply to this message
Old 12-27-2012, 09:12 AM   #9 (permalink)
When you put in you connect the battery on the heli with the radio off. It will automatically go into bind mode after a few seconds. You will know it's in bind mode because the LED on the heli 3in1 board will begin blinking rapidly.
At this time, put your radio into bind mode.
The two will pair up and be bound to each other. Follow the instructions in the manual.
Daryoon is offline        Reply With Quote Quick reply to this message
Old 12-27-2012, 09:23 AM   #10 (permalink)
I had one and encountered the same issues , did the same things to resolve the problem. I called tech support and after going over everything via, the phone. they were kind enough to send me a new board, BAM....... problem solved
shihan is offline        Reply With Quote Quick reply to this message
Old 12-27-2012, 03:02 PM   #11 (permalink)
After a big crash on my nano cpx...i flyed after till the batery dies!
So after another charge.... my nano cpx when i plug the batery just blinks the blue led rapidly....and the dx4e does not respond anymore!
Is possible that the pcb board had lost it's bind? or is it dead?
i made a thread but i really need all the help you can give! thanks
targetingxmod is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 09:28 AM   #12 (permalink)
Seems that this is the only method thats works for me.
km193 is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 09:34 AM   #13 (permalink)
Hobbez, don't suppose you've solved this problem? any ideas what has caused it to only bind when touching antenna?
Old 01-29-2013, 09:05 AM   #14 (permalink)
Default Nano CPX Binding issues.
Just got my Nano and it would bind "from a distance" the first couple of days and then it just stopped. Stumbled on this thread and the touching of the transmitter (DX8) to the Nano works it like-a-champ.
Cheers Hobbez
cbelcher is offline        Reply With Quote Quick reply to this message
Old 02-19-2013, 01:23 AM   #15 (permalink)
Check your Reverse settings. I wondered why I couldn't bind. Fixed them and all is good.
Never underestimate the predictability of stupidity!
Leadsled is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 09:42 PM   #16 (permalink)
I know this is an old thread, but I have to let other people know this worked for me. I tried absolutely everything to get it to bind without success. Touching my controller to the antenna on the nano worked!!! Thanks a million. I thought I needed a new board.
Leroybrown is offline        Reply With Quote Quick reply to this message
Old 12-18-2014, 10:50 AM   #17 (permalink)
Here's another tip. All these micros - mcpx, ncpx, msrx,....etc all ship from the factory with the antenna wire wrapped around a body post. Baaaaaaaaaddd..... An antenna needs to be extended to its fullest length to be effective. Especially a receiving antenna. It also needs to be standing straight up. Use a strip of 1/32" heat shrunk tubing to prevent the wire from shorting out on the board once you've unravelled it and straightened it out.
Also turn your transmitter on first and let it sit for 5 seconds or more to allow it to find an open frequency - this is critical in a 2.4ghz noisy enviroment...Wifi, cordless security cams, laptops, smartphones etc... can make binding difficult.
Jose (Youtube -> Silverexpress01
See also Helifreak Blog)
MCPx 76/7 | Trex 250 DFC 667/19 | Hurricane 200 FES 143/7
Silverexpress01 is offline        Reply With Quote Quick reply to this message
