Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 08-24-2015, 08:16 PM   #1 (permalink)
Default Moisture build thread, any advice?
I am building this kit, which I have had in the box for over 1 year. Been flying IMAC, and thus I was distracted from my helicopters. But now I am back.
1st thing is I downloaded the most recent manual for the E version:
Last edited by orthobird; 08-24-2015 at 08:49 PM.. Reason: MOSTRO build thread!! not moisture! dang spell checker
orthobird is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 08:19 PM   #2 (permalink)
I did every thing per the manual, with the 1st step, the bottom gear plate assembly, it was pretty much straightforward.
the manual did not say it, but you want to tighten down the boom clamps with the boom in, then remove the boom.
ID:	604736   Click image for larger version
ID:	604737   Click image for larger version
Old 08-24-2015, 08:22 PM   #3 (permalink)
the top servo plate assembly is also straightforward, but , be sure to make the locknut be flush with the main gear assembly (on the main shaft).
ID:	604739   Click image for larger version
Old 08-24-2015, 08:25 PM   #4 (permalink)
Motor installation was also without any problems, and this Scorpion fit perfectly. Also, be sure to make sure that the screws are not too long and do not get too close to the motors windings. This motor also has a felt layer to prevent touching by metal. In any event, in this case, the screws did not protrude even to the felt.
Old 08-24-2015, 08:27 PM   #5 (permalink)
the frame also was without incident, except, the locking spring mechanism for the battery tray is too snug. meaning, it does not move freely.
Old 08-24-2015, 08:28 PM   #6 (permalink)
Monoblock installation was also no problem onto the frame. There are 5 screws +1 into the motor mount on each side.
ID:	604744   Click image for larger version
Old 08-24-2015, 08:41 PM   #7 (permalink)
rigid core head assembly was also straight-forward. The M6 bolts were tightened down real good. Also, the manual is very good in explaining the orientations of the bearings and washers.
Old 08-24-2015, 08:50 PM   #8 (permalink)
Please change title to MOSTRO not moisture
Old 08-25-2015, 08:33 AM   #9 (permalink)
No leave it I like moisture it has a ring to it
sab havoc 3 blade 700
sab black thunder 700
logo 600sx x2
blade nano s2
fatboyrob is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 09:43 AM   #10 (permalink)
Autocorrect giveth and autocorrect taketh away.
Samuel Adams field rep
Buffalo Wings field rep
Success is the ability to go from one failure to another with no loss of enthusiasm.
Churchill
capebob is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 12:36 PM   #11 (permalink)
Where are these kits for sale?
daboxe is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 02:16 PM   #12 (permalink)
Carbon Extreme is the distributor http://www.carbonxtreme.com/catalog/index.php/
Also available at Amain http://www.amain.com/rc-helicopters
and Experience RC http://www.experiencerc.com/store/index.php
Churchill
Old 08-25-2015, 07:45 PM   #13 (permalink)
Where are these kits For Sale
and In Stock?
Trex 500e Pro, i2 Head, VX1e; Trex 550e DFC w/Blue Full Vbar, 730MX
600e Pro Performace Upgrade w/Blue Mini Vbar, 750MX
Logo 600se w/Silverline Vbar Pro, PowerJive120, Pyro 700-45L
Yellow SAB WobblinGoblin770 w/ iKon v2, Red Mostro v1 w/ iKon v2
byter182 is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 08:38 PM   #14 (permalink)
Are they no longer available?
I purchased mine from Esprit RC. I was on a waiting list for like 6 months or something like that.
Old 08-26-2015, 04:56 PM   #15 (permalink)
Seems to be a unicorn, I did a search on those sites above, but no luck in finding any.
Old 08-26-2015, 05:28 PM   #16 (permalink)
Anyone know what happened???
Why did this company disappear?
I am disappointed I purchased this and now, no support??
Today, I was putting together the tail, and one of the tail grips, as I was tightening the 2 mm ball, it snapped!!
Now that tail grip is useless! I need to order a new one and a new ball! I am glad it snapped now and not during flight!! It snapped while I was threading it in, not even tightening!
Old 08-26-2015, 06:56 PM   #17 (permalink)
Anyone know: Can i use Futaba BLS 157 servos for cyclic?
here are the specs:
torque: 513.9 @ 7.4 volts
speed: 0.11 sec/60 degrees @ 7.4 volts
Brushless motor
Old 08-26-2015, 07:36 PM   #18 (permalink)
one more question on this topic: what servo arms are you all using? Regular nylon or aluminum ones?
Old 08-26-2015, 09:15 PM   #19 (permalink)
I am using nylon arms. I am thinking those servos would be fine as well.
It seems that a lot of spares are available for the mostro. However there aren't any kits out there right now. I think they are losing a lot of potential sales. There seems to be a shortage of canopies. I am wondering if that is why there aren't any more kits out right now. Seems like they were doing well at the beginning of the year and sort of fell off over the last couple months. I find the available stock of spares as a good sign.
Oxy 2, Gaui X3 #1, Protos 380, Gaui X5, Synergy 766, Specter 700
Oxy 2/X3/Protos 380/X5/766/Specter 700 Consecutive Successful Flights (Current) = 32/16/12/145/7/50
Consecutive Successful Flights (Max) = 145
macdad is offline        Reply With Quote Quick reply to this message
Old 08-26-2015, 11:48 PM   #20 (permalink)
I'm using a set of this horns:
http://www.secraft.net/shop/step1.ph...20090414105628
They are perfekt and save your servo gears in case of an crash.
I noticed too much flexibility and some play on the swash while i was using plastic horns. Not much - but the swash get's a little bit more ridgid when using alloy horns.
Velos 880, 800e Pro DFC, Mostro 700, Suzi Laos 800
RJX Xtreme 90EP, Outrage F50, Goblin 570KSE, Goblin 380
garfield2412 is offline        Reply With Quote Quick reply to this message
