Go Back   HeliFreak > R/C Helicopter Support > Bergen R/C Helicopters
Bergen R/C Helicopters Bergen Intrepid 90 Intrepid Turbine Observer Industrial Twin Observer Turbine Support Forum
Old 12-06-2013, 09:43 PM   #41 (permalink)
quick question on a different note. my bergen is the only bird I have trouble doing rolls. the tail swings out but is rock solid upright. I thought it was my thumbs but tried it all different ways. any other suggestions
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Skookum support pilot
geomecc is offline        Reply With Quote Quick reply to this message
Old 12-07-2013, 09:14 PM   #42 (permalink)
What gyro and servo?
Chris D. Bergen
cbergen is offline        Reply With Quote Quick reply to this message
Old 12-07-2013, 10:54 PM   #43 (permalink)
gy701 gyro/gov and savox1290. i have this same setup on a few of my gassers
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 12-08-2013, 09:35 AM   #44 (permalink)
How well does the tail hold in normal mode (non heading hold)?
Chris D. Bergen
Old 12-15-2013, 10:24 AM   #45 (permalink)
I'm not sure. I did set it up to not drift in rate during A hover. next decent day I get I will take it out and see how it holds.
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 12-16-2013, 04:31 PM   #46 (permalink)
What procedure did you use to eliminate drift in non heading hold? IOW, what did you adjust?
Chris D. Bergen
Old 12-20-2013, 12:03 PM   #47 (permalink)
i put the gyro in rate and adjust the linkage so it hovers without drifting one way or the other. i might put a futaba 611 and use a gv1 instead of the 701 and see if it makes a difference. the funny thing is if i remember correctly it will roll better one way and not the other
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 12-20-2013, 02:59 PM   #48 (permalink)
Which linkage did you adjust?
Chris D. Bergen
Old 12-20-2013, 06:15 PM   #49 (permalink)
tail rotor pushrod
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 12-20-2013, 10:16 PM   #50 (permalink)
Then I think here lies the problem. The pushrods is only adjusted to center the pitch slider on the shaft.
To adjust the pitch to correct for drift, you must adjust the links from the slider to the blade grips.
This thread talks about a 401, but ALL gyros should be setup this way. https://www.helifreak.com/showthread.php?t=17886
Chris D. Bergen
Old 12-21-2013, 12:54 AM   #51 (permalink)
I will do it as suggested. it's essentially the same except urs is the only heli I know of that u can track and adjust t/r blade that way as all others are one piece links to t/r grips. I will let u know how I make out hope fully Sunday. thanks
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 12-21-2013, 08:26 AM   #52 (permalink)
The difference is, if you adjust the pushrod, then the pitch slider isn't centered on the shaft. Now you have unequal travel from one side vs the other, which is why in a roll, the tail is better in one direction vs the other.
Chris D. Bergen
Old 01-05-2014, 04:49 PM   #53 (permalink)
thanks chris. I reset up my tail rotor linkage the proper way (as per your instructions)!
it rolls straight as can be.
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 03-21-2014, 11:51 PM   #54 (permalink)
quick question about the bergen fbl head conversion. the instructions say to use .040 & .015 shim plus the clip I can't get the clip on both sides with the thick shim (measures .0390) on both sides. is there a revised method with what shims to use?
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 03-22-2014, 09:44 AM   #55 (permalink)
The shims will fit, you just have to work at it. Easiest method "we" have found is to install the clip on one end, add the shims and damper for that side, slide it through the head block, install damper and shims.
Slide the clip over the shaft. Find a tube that will just slide over the shaft and slide it on. Now push the tube down hard. You'll compress the damper and the clip will snap into place.
-Kevin
Skiddz is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 09:12 PM   #56 (permalink)
We did revise this, only use the .040 shim.
Chris
Chris D. Bergen
Old 03-23-2014, 12:28 AM   #57 (permalink)
we're the blade grips changed from the older gassers because i got a new fbl head block with my old grips and I can't get everything together without the bearings being real notchy even without the clip and spacer that go btwn bearing and thrust bearing inside the grip.
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 03-23-2014, 08:51 PM   #58 (permalink)
Nope, the blade grips are the same, as is the head axle.
Did you have the c-clips installed on the head axle in the non FBL head block?
Chris D. Bergen
Old 03-23-2014, 11:16 PM   #59 (permalink)
yes I did have them installed but when I assembled everything the grips were super tight so I removed the clips then I removed the spacer washer for the thrust bearings and used the thin shims (they were thiner than the washers) and the grips was still too tight. so I disassembled it and used the original rotor Block with the shims that was almost 040 w/o the clips and the thin shims as a sub for the thrust bearing spacer. (I think they were close to 020 )and it's slightly notchy but much better. idk why it's giving me a problem.
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 03-24-2014, 07:25 AM   #60 (permalink)
Ok, there should be no spacer washer between the outer radial bearing and the thrust bearing.
In the grip, there are only the 2 radial bearings and the thrust bearing.
Chris D. Bergen
