Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 09-18-2014, 02:27 AM   #1 (permalink)
Exclamation Lost control of my Warp… two times.
Hello there,
I have the Warp 360 with the stock motor, HiModel 60A, 3 × TGY-306-HV, Align DS-525m and Gens Ace 1400 mAh LiPo. For the Tx/Rx part, I fly with and Spektrum dx6i and OrangeRX R620 + OrangeRX R100 Satellite. The gyro is an Align 3gx V5.
My first crash was at the flight #12. I was hovering reversed and suddenly, no control! Just one canopy standoff and one breakable servo arm
My antennas were not well-disposed at this time, so I changed it and now this is like that :
I was pretty confident this setup will be good. But yesterday, another loss of control (flight #21)… The heli was not really distant from me, but I was making an pirouette after rising vertically (I don't know the english name… fast forward, then 90° up, then pirouette when the heli stop rising). So the heli drop down from pretty hard altitude and there is almost no damage. The Warp seems to be quite solid
This time the receiver was blinking (not the satellite) while I did not check that for my first crash -_-
I am not sure that is a problem is Rx/Tx as I disposed the antennas free of other electronic or carbon frame. If my problem is electric, it could cause that kind of failure I guess…
Do you have some tests to do in order to know if the problem is radio-based or controller-based for example? The BEC of the HiModel is 5.5V/6A, this is enought right?
Thank you, and sorry for my english :-/
Guilou is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 10:17 AM   #2 (permalink)
mnc
It sounds more like bec problems than radio to me. To test you could move your cyclic stick up and quickly (with TH on or motor unplugged) to see if the bec kicks out
Never enough time, Never enough helies
mnc is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 11:14 AM   #3 (permalink)
Do the servo test first, if that's all good then do a standard range check. You may want to have a friend help with the range check.
If still nothing then it may be the RX/satellites. Personally, I wouldn't trust the Orange gear on a heli like this... I would only trust those on cheap foamy airplanes. I've seen a few guys have issues with these receivers.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 11:24 AM   #4 (permalink)
Thank you for yours answers. I have just made a range check without the satellite (I have broken it…) and I have at least 20 steps.
I have made the mnc's test and it's weird: when I have just plugged the battery, I can shake my sticks as I want, the red LED on the controller stay light. But after 2 or 3 minutes, the LED is blinking (even when I just move the heli, not use the radio) and after the LED shut off!
When the LED is off, I have still the control of the heli and the receiver does not blink.
Do you think my controller is too weak?
Old 09-20-2014, 10:07 PM   #5 (permalink)
I once had a DX6i (old version, DSM2) that shown the same problem. I crashed two Storm 450s in the same day, they simply fell dead from the skies.
Since you are using Orange, I can tell you are using DSM2.
I'd rather switch to DSMX. If your TX is DSM2 only, get a new one. Since I switched, I had zero problems in more than 2 years.
Compass 7HV / Atom 6HVU / Atom 5.5 / Align Trex 500L / Spektrum DX8
Not flying anything - model or full - since 2017!
ARM_Coder is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 10:16 PM   #6 (permalink)
How many amps does your BEC put out on 6S. Many of them have a sliding scale where the output amperage is inversely proportional to the input voltage (more cells=less current).
I would, as others have suggested, use actual Spektrum receivers. I have used the orange ones successfully in small foam airplanes, but would not try them in a helicopter.
Is your tail boom grounded?
Are your belts lubed with silicon?
Old 09-21-2014, 04:23 AM   #7 (permalink)
Hello,
I have a Spektrum dx6i with DSM2 / DSMX. My Orange RX is DSM2. I use another one OrangeRX receiver in another heli since 2 years without any problems.
Moreover, I have made a test. When my Warp lost radio connection, the receiver LED shut down and will light up when the connection will be back again. If if cut the receiver power and power on again, then the LED will blink. I understand that a blink LED is for a brownout, not for a tx/rx linkage cut.
So the problem is electric I guess. Maybe static (my tail boom is not grounded, the belt is not lubed) or just a weak BEC. It's given for 5.5V / 6A at output but they don't precise for which input voltage… (it's 2 - 6S, I use 6S).
I am thinking about purchase a Gryphon Polaris BEC GSR-3030. It's given for 5A continuous at 22.2 V and I can output more than 5V with it (I have HV servos). Turnigy 306-HV are known to be MKS 95 clone and to need a huge quantity of power.
Do you think I am right?
Old 09-21-2014, 02:38 PM   #8 (permalink)
Im using the polaris with the kst servos. It has worked flawlessly for me so far.
Sent from my SCH-I535 using Tapatalk
NX4|Tri-Chronos|Chronos|7NT|Specter700
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 09-21-2014, 02:54 PM   #9 (permalink)
I have this on my Warp #1:
http://www.western-robotics.com/herc...r-mini_hp.html
A bit overkill I admit, but never any brownouts.
Old 10-23-2014, 10:29 AM   #10 (permalink)
Hey,
Some news here. I have installed the Gryphon Polaris SBEC and everything is ok know
Problem solved!
