Belt CP E-Sky Belt CP
Old 02-23-2009, 04:51 PM   #1 (permalink)
Default Tower Pro MG 90
They have arrived, well they are at the post office cause the mail man was to lazy to come knock on the door but I'm picking them up in the morning. Anyone want any? Faster than its more exspensive brother the hg65
MG90
MG90 servo, Metal gear with bearing
Weight: 14g
Dimension: 23*12.2*29mm
Stall torque: 2.2kg/cm(4.8V )2.5kg/cm(6V)
Operating speed: 0.11sec/60degree(4.8v), 0.10sec/60degree(6v)
Operating voltage: 4.8-6.0V
Dead band width: 10us
all comes with arm set
Matt
Junk Yard 450,
Blade MSR
GAUI 200 (under reconstruction)
Trex 450 (sponsered by Pittjitsu)
creteus is offline        Reply With Quote Quick reply to this message
Old 02-23-2009, 07:40 PM   #2 (permalink)
I might be interested. Are they better than the Futaba 3114? I have all SG90's and all of you suggested to use MG90s which werent available at the time. I'm looking for a nice tail servo which can take a beating but still not be that expensive.
1) eSky Lama V3 2) EXI basic ARF kit. Electronics: Dx6i/AR6200, E-sky 25A ESC and motor, SG90's, Tail: G401B/Futaba S3114
alan-31 is offline        Reply With Quote Quick reply to this message
Old 02-23-2009, 07:51 PM   #3 (permalink)
I wouldn't say they are better than Futaba, but they are better than the sg 90s for sure. I totaled my heli and didn't strip a single tooth. Can't go wrong either for $11.00 each.
Matt
Junk Yard 450,
Blade MSR
Old 02-24-2009, 01:04 AM   #4 (permalink)
I'd say they are better than the S3114's they have better specs. except speed is the same and have metal gears but I would still put the s3114 since it's lighter on the tail and use MG90's for cyclic.
Matt the specs you have are wrong for speed I think. I'm pretty sure .10@4.8 and .09@6v that's what I have written down from when I bought them.
-Heli Yea! Master of: the living room, mechanical setup and, the obvious!
Belt'ish CP FBL, HDX 500 DFC, New V120D02S FBL, Mini CP FBL, Hirobo Shuttle ZX, 450L w/VX1e, QR-X350PRO FPV, 450L w/APM FPV(in progress) DEVO 10 white w/2km range!
Heli Yea! is offline        Reply With Quote Quick reply to this message
Old 02-24-2009, 06:11 AM   #5 (permalink)
those are the specs from the tower pro site. I just copied and pasted.
Matt
Junk Yard 450,
Blade MSR
Old 02-24-2009, 10:32 AM   #6 (permalink)
Either way good speed minimal difference that I would even notice.
Old 02-24-2009, 02:05 PM   #7 (permalink)
Thanks creteus, sounds like a good idea to use the MG90s for the cyclics. Would you say they're longer than the SG90? I could barely fit the SG90's in my EXI and I had to squeeze somewhat to make them fit from inside the frame.
Old 02-24-2009, 02:15 PM   #8 (permalink)
Yeah they are a bit longer. I took one of the left upper frame piece off of mine to get them in. Also it makes it alot easier to run the wires out of sight on the inside of the frame. Pictures are crap sorry
ID:	83797   Click image for larger version
ID:	83798   Click image for larger version
Matt
Junk Yard 450,
Blade MSR
Old 02-24-2009, 02:40 PM   #9 (permalink)
Me likey! So the pics are a little fuzzy but you can see what's going on!
Old 02-25-2009, 12:14 AM   #10 (permalink)
$11 each? Geez how come so cheap? I was looking at these same servos and they were $30 dollars each.
B2TheEYo is offline        Reply With Quote Quick reply to this message
Old 02-25-2009, 12:26 AM   #11 (permalink)
Thumbs down Highway Robery!
$30 Really? Where are you looking? I paid $10 for mine before they were even out as a promo then the price went up to $11 Can you post a link cause they are ripping people off!
Old 02-25-2009, 12:54 AM   #12 (permalink)
I'll have to look. I've been on a few sites now. I remember seeing TowerPRO MG90's for $29.95 US. I was like !!!!!!! SCREW THAT! =P
I ran across it a few weeks ago when buying my replacement servo for my Belt after my um.. "experience"..
Old 02-25-2009, 08:59 AM   #13 (permalink)
Thanks Creteus, I guess I'll have to pass for now since I'd have to remove the frame somewhat to put them in as you said. I'll continue with using the sg90s for now. Nice servo though.
Old 02-25-2009, 11:11 AM   #14 (permalink)
Its cool. they're on ebay so if you change your mind thats were you can get them. I have the SG 90s in three packs or singles and th MG 90s are there also.
Matt
Junk Yard 450,
Blade MSR
Old 02-27-2009, 03:37 PM   #15 (permalink)
pm sent.
f5air is offline        Reply With Quote Quick reply to this message
Old 11-11-2009, 03:55 PM   #16 (permalink)
Hello
are they ok for copterx 450 ae V2 ?
fanedi is offline        Reply With Quote Quick reply to this message
Old 11-11-2009, 04:01 PM   #17 (permalink)
yes
Alex
MY BLOG Stop by say hi :-)
500 ESP: Ely Q Comp: "Kasama'd Trex 600N:
lex7919 is offline        Reply With Quote Quick reply to this message
Old 11-11-2009, 04:02 PM   #18 (permalink)
They are perfect, both the SG90s and the MG90s. I used them both in a CopterX AEV2, and still use the MG90s now.
MG90s are much more resistant to a crash.
Logo 800 - TDR 14S - TDR 12S - Logo 500SE - Logo 400 - Furion 450 6S mini-V - 300X - 150S - mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner - F27D Evo
redbird300 is offline        Reply With Quote Quick reply to this message
Old 11-11-2009, 05:04 PM   #19 (permalink)
what is the difference between the MG90 and MG90s?
williec30 is offline        Reply With Quote Quick reply to this message
Old 11-11-2009, 06:49 PM   #20 (permalink)
Yes they are different sizes and I've heard the S isn't a very good servo.
Matt
Junk Yard 450,
Blade MSR
