Go Back   HeliFreak > R/C Electronics Support > R/C Related Electronics DIY
R/C Related Electronics DIY DIY R/C Electronics for tinkerers and the budget minded
Old 08-23-2014, 01:08 PM   #1 (permalink)
Default Eeeeek! expert needed!
=] well I will try in here and live in some hope!
I have an ESC that uses an anti-spark lead for connecting to 12S lipos, the problem being it is new and the connection did not want to come apart like it should have.
the ensuing struggle has resulted in component damage, but I did manage to release it. so, where do I get a replacement resistor? any ideas? link or advice needed....
rings are gold-black-black-brown and about 6 mm dia.
thanks!
Old 08-23-2014, 01:25 PM   #2 (permalink)
Default Resister
Hi
The color code is actually Brown Black Black Gold which would be a 10 Ohms +-5% (5% being the Gold band)
Check a local electronics store
HeliBladeSR is offline        Reply With Quote Quick reply to this message
Old 08-23-2014, 05:48 PM   #3 (permalink)
=] Thanks! It just shows clueless I am! Soldering I can do with everything in front of me, is there an eBay link you would have to assist me more? Thanks again, bit lost here... Cc
Old 08-24-2014, 10:44 AM   #4 (permalink)
Default 10 Ohm resister
The length & thickness should give you a better understand of the wattage rating of the resister.
What are they?
Old 08-24-2014, 11:28 AM   #5 (permalink)
=] HeliBlade thanks, dia = 6mm x 17mm length....
Old 08-24-2014, 11:48 AM   #6 (permalink)
Default Resister
I believe based on your picture and the size, this is somwhere between a 2 watt to 5 watt 10 Ohm Metal Oxide Film Resistor. I would go with 5 watt if you can, since it can handle more current to be on the safe side. Even if it was 2 watt and you replaced it with a 5 watt is not going to hurt anything, but you do want to make sure it's 10 Ohms.
Not sure what electronic parts are available to you local in the UK.
You may be able to confirm the wattage with the manufacturer of your electronic component.
