Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 05-11-2007, 01:28 AM   #21 (permalink)
Thats what I thought too. I am almost ready to fly mine and break in some packs. After I saw this I wondered if I had the wrong powerhouse motor.
Not Sponsored= Not Biased
t-rexn8 is offline        Reply With Quote Quick reply to this message
Old 05-11-2007, 04:38 AM   #22 (permalink)
The Kora has more than adequate power on 4S - no doubt about it
I have absolutely no bogging at all and it rips
I just need to change the pinion to get the HS up a bit
because when I had the Hyperion motor on 24T
it was even more powerful and had striking cyclics
But even now, I have to exercise careful collective management
because it has so much collective power
(easy to turn a roll into a cork screw)
and if I get a fright flying inverted
I can simply hit full aileron at zero collective
and BANG she is over and upright
Originally Posted by docjoe
I have to be very gentle with the collective management
or else I'll lose tail authority due to decreased head speed from bogging.
Sorry - but there is something very wrong with your setup
The has been a few times when I have washed headspeed off
but I've never actually managed to get an ugly bog out of the Lepton
You're not using the Hirobo tail blades are you?
They are completely a waste of time
You need longer tail blades
Eolo tails or Viper tails or ReadyHeli tails
Jafa is offline        Reply With Quote Quick reply to this message
Old 05-11-2007, 05:34 AM   #23 (permalink)
both packs are fine. all 4s being used.
with the readyheli tail blades I was getting wag and just plain sloppy flight with a 9650 servo. The 9252 really helped that though.
if i change pinions, the hs will drop.
i remember someone posting that they thought their kora was mislabeled. after all, they just write on them with a sharpie. I wonder if I got a 15-16 or something. There is just too much inconsistency here
avatar71 is offline        Reply With Quote Quick reply to this message
Old 05-11-2007, 06:49 AM   #24 (permalink)
If you could get your hands on a loaner Hyperion that would be a great back to back test - if the Hyperion does not light up then it would be an issue with something else on your Lepton
We have 6 Leptons here and they are all running 4S with heaps of power
Old 05-11-2007, 07:35 AM   #25 (permalink)
jafa, are you running the 14 turn kora's?
Old 05-11-2007, 07:50 AM   #26 (permalink)
I've just checked the box and it's a 15-14 with 790kv
Check the post from Gus - he's running the same setup as me
and he has 2800 on the head cos he's using a 24T
(mine is a tad lower due to 23T)
Old 05-11-2007, 08:22 AM   #27 (permalink)
If one suspects their Kora may be mislabeled, is there a way to confirm visually (or via some other easy way) which version you have?
Joe Ubaldo is offline        Reply With Quote Quick reply to this message
Old 05-11-2007, 09:43 AM   #28 (permalink)
Mine has a clear sticker on the bum with a felt pen marking 15-14
Gryphon field rep
Old 05-11-2007, 10:53 AM   #29 (permalink)
Check this out. This is a vid of Corrado(aka heliup) flying his Lepton with a Kora 15-14 on 4S.
http://www.runryder.com/helicopter/t264577p1/
Alvin
eheliflyer is offline        Reply With Quote Quick reply to this message
Old 05-11-2007, 11:52 AM   #30 (permalink)
Nice thanks for the link. Almost done with mine now so hopefully I can shed some light on this too.
Old 05-11-2007, 12:00 PM   #31 (permalink)
No Prob. That vid shows how powerful that setup can be.
Alvin
Old 05-11-2007, 02:16 PM   #32 (permalink)
Gus
If you don't think that you have a 15-14, count the magnets, the 14 will have 14 magnets.
Gus...
Gus (KI7LPX)
Synergy E5s, Goblin 380KSE, Gaui X3, Beam E4, T-Rex 250 Pro, MX-155, CF-226, CF-258, F1-5, F1-6, Chameleon, AcroWhoop V2 (2), Convergence VTOL, SK SlowHawk 2, SK ParkHawk 4, Bionic Bird, CF Wing, ThunderBird EDF Jet.
Gus is offline        Reply With Quote Quick reply to this message
Old 05-11-2007, 03:29 PM   #33 (permalink)
thanks for that tip! I certainly will.
Old 05-11-2007, 03:32 PM   #34 (permalink)
if you are ever in buffalo, please fly my rig because I cannot fly anywhere near that level.
Still, dont think I have near that punch either.
a-magnet-counting-i-will-go
I am sure the motor is a 14, its probably my setup.
overpower anything and you can fly sloppy. perhaps i need to learn to manage the head better :!:
Old 05-11-2007, 03:42 PM   #35 (permalink)
Gus
Another thing to watch out for, is that you don't have so much pitch that the swashplate is binding the main shaft.
I like to rotate the head by hand (spin it) and move the Ail/Ele sticks through their range while the head is spinning. I do this at low, middle, & high pitchs. If you have too much pitch (or Ail/Elv) you will see the head slow down.
It just depends on the structure of the Swashplate as to how much pitch, etc. you will be able to use.
On my EVO 50's, I use Quick UK swashplates, because they give me a better range than the others do.
Just another possibility.
Gus...
Old 05-12-2007, 03:09 AM   #36 (permalink)
Alvin that video didn't impress me at all, needs more HS. As you see from Corrados statement it was felt the motor was more in range and performed on a better level on 5S.
Old 05-12-2007, 06:07 AM   #37 (permalink)
It wasn't a hot setup but it is a viable setup - works ok
The problem is that avatar71's Lepton is no where near that level of performance
Which is is a concern and a disapointment
Gryphon field rep
Old 05-12-2007, 11:18 AM   #38 (permalink)
Shawn that is true but it was still a good example of how it can perform on 4S. I agree that on 5S it would be a monster. I personally think that if you are running 4S the Kora 15-10 would be an insane setup. I am running the Kora 15-10 with a 18T on 5S and I can only run 70% on my throttle because my HS would be over 3100. Right now my heli is just plain psychotic with power, but that is on 5S.
That vid was just ot show that with some good collective management that that setup will have plenty of power for the average pilot.
Alvin
Old 05-19-2007, 05:43 PM   #39 (permalink)
well, I think I might take some of my dissapointment back. I have been flying the lepton and the packs needed some working in. It does not explode up in the air like my trex 600 but it's pretty darn good for me. BUT, the consistency of the motor and esc (Kontronic's) kills the align motor and esc. The punch that the trex delivers quickly drops off. The kontronic stuff is just plain awesome! Perhaps IF I get better, I'll swap the 14 for a 10 or 12...
Old 05-20-2007, 07:04 PM   #40 (permalink)
Hey, I ended up using 5S in my Lepton with the 15-14 and 21 t pinion. It is really a rocket but am still working out some vibrations.
