Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 08-14-2014, 10:16 PM   #1 (permalink)
Default Wht size rx pack?
Curious what size rx pack you guys are running on the e5s
I have 3000mah life I was going to mount it on the left side frame but is freeking looks huge! I had the entire under side of battery tray on the bird it came from ..
Thanks ..
kayakboy69 is offline        Reply With Quote Quick reply to this message
Old 08-14-2014, 10:16 PM   #2 (permalink)
2550mah 2s lipo here
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 08-14-2014, 10:27 PM   #3 (permalink)
Left side frame bottom edge of battery at lower edge of frame and yea its not strapped down just trying to figure cg and battery placement
Old 08-14-2014, 10:35 PM   #4 (permalink)
Well I just found I can seek it into the canopy
Just got a watch the wires and nail them down good ...
Old 08-16-2014, 07:08 PM   #5 (permalink)
1300mah 2s lipo, very light and cheap. I keep 4 or 5 charged up.
4cyclic is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 12:09 AM   #6 (permalink)
What about LiFe I run a 2s Life on my N5c and it works great with a western robotics reg on my bls251
~Synergy N7, YS91-3DS, IKONV2/BT XPERT SERVOS
~Synergy N5c TT, OS55-H, IKONV2
~Blade 180cfx
~Futaba T14SG
TeamXpertServos
Frequency is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 10:25 AM   #7 (permalink)
I ran a 2100mAh LiFe on both my E5 and E7 for a while. It was small enough to be able to position easily and still gave several flights.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 07:11 PM   #8 (permalink)
Ended up finding a home for the 3k life pack thanks guys
Old 08-19-2014, 06:17 PM   #9 (permalink)
Pulse 2550mah 2s in my setup as well on 6s. I've really been happy with it and like the safety factor vs BEC on a heli this big.
Synergy E7SE (KDE 700XF-495); Synergy E5 (KDE 600XF-530); Goblin 500 (XNova 4020-1200).
Chris Gardill is offline        Reply With Quote Quick reply to this message
Old 08-19-2014, 07:51 PM   #10 (permalink)
Yea just seemd huge mounted on left side frame
Old 08-20-2014, 01:29 AM   #11 (permalink)
Hyperion 2200 2s LiFe. Sits on top of the front flight pack. Using one of Ralph's battery trays (they need to exist again ), but the same theory could apply with stick packs or strapping in two bricks.
Before that, OP, I had been using that same 3000mAh hyperion pack in the same spot. Fit perfect on top of a 3.3Ah flight pack.
"You need more rockets. Everything is better with rockets"
Mike Dipalo--Synergy RC, MKS Electronics
Commodore8888 is offline        Reply With Quote Quick reply to this message
Old 08-20-2014, 03:15 PM   #12 (permalink)
I have a crap set of batteries for testing .. will be getting a set of glaciers which im sure will be smaller and allow the rx pack ti tag along [emoji12]
Old 08-21-2014, 02:02 PM   #13 (permalink)
Same here. I get 3 flights out of one with my E7SE.
Underscore is offline        Reply With Quote Quick reply to this message
Old 08-24-2014, 07:11 AM   #14 (permalink)
I've actually found that it works best for CG purposes for me if I just have it strapped to the top of the flight pack. I then just have an EC3 harness for it that runs it back to the ikon. I've seen pictures of folks running them in both places so don't think there's a wrong place for it necessarily.
Old 09-06-2014, 08:10 PM   #15 (permalink)
On the RX packs is the 1 wire sufficient for HV set up? I read on another post that 2 wires were better than 1 for adequate power to the FBL system. ON THE pulse RX packs looks as though they only have 1. Curious as I've been contemplating getting rid of my BEC
Jason Asch is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 08:22 PM   #16 (permalink)
You can make a wiring harness with two servo connectors and an EC3 (or whatever connector you want to use) and run power from the main power leads on the battery pack.
Old 09-06-2014, 08:31 PM   #17 (permalink)
Yeah like this? https://www.spektrumrc.com/Products/...odID=SPMYHEC36
On the Pulse RX pack looks like it only has one see here: http://www.helidirect.com/plurx-2550...es-p-26537.hdx
What do you all do with HV set up?
Old 09-06-2014, 09:19 PM   #18 (permalink)
I am running a 2cell 2500 mah lipo for my rx pack. I have it plugging into my wr super bec pro with power bus. It has an option for 8 or 8.4 volts HV setup on the bec I believe. I haven't looked at the dip switches on it in about a year or two now. Great for delivering the voltage and current to a hv setup.
B400(retired),Mini Titan V1(Retired),Radikal G20 (scrapped),Align T-Rex 500pro DFC,Synergy E5s
Digger1973 is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 10:26 PM   #19 (permalink)
Originally Posted by NuttyToughGuy View Post
Exactly like that, yes.
I have two of those and they do only have one servo-type connector. I'm using mine on my nitro helis and I plug them into a power switch. I would just use that adapter you posted that link to.
Old 09-06-2014, 11:02 PM   #20 (permalink)
This is what I do, too on my hv setup. Actually, I did it this way on my lv setup also.
*Spyder 2200 lipo RX pack > ec3 harness into 2 servo leads > fbl unit.
There are variations of this depending on your equipment and desired levels of redundancy.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
