Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 11-02-2014, 05:07 AM   #1 (permalink)
Default E7SE??
So I crashed my 7HV. It is not the kind of Heli that I would like to repair. So I am looking for a new kit, and as a big part of this hobby is to try new stuff, I am looking to try a E7SE.
My questions are:
- Is it still a good heli to buy? Any plans for an update or so and the E7SE will be superseded?
- Any known issues? fails?
- Any parts availibilty issues?
- What is the maximum HS for this heli?
- Where does this Heli stands quality wise?
No helis!
Jad.
JadAl_87 is offline        Reply With Quote Quick reply to this message
Old 11-02-2014, 05:40 AM   #2 (permalink)
JadAl,
Yes the E7SE is still a very good buy, I've flown a lot of helis, including the 7HV and Synergy flies like nothing else
Their are no issues with it, straight forward build
Parts availability is up there, Lots of dealers now (http://synergyrchelicopters.com/dealers/)
Max head speed, I don't really know because some people are cranking it up the the speed canopy (I've seen a guy run it at 2800)
Quality wise is what this heli is all about, you tell us once you compare to your 7HV.
The danger with Synergy helis is once you start flying one your other helis don't come out much anymore.
Team Rail blades,
Team Scorpion motors,
V-Team
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 11-02-2014, 05:49 AM   #3 (permalink)
I will also be comparing to the Diabolo. When quality comes into picture, the Diabolo is my benchmark.
Flying wise 7hv did good, however it came short.
I am thinking of the following setup (basically what I had on my 7hv):
Kosmik 160
Pyro 750-50
MKS
BD3sx
I read that no issues with fitting a kosmik. is it?
No helis!
Jad.
Old 11-02-2014, 06:45 AM   #4 (permalink)
No sir, the Kosmik fits just fine. The E7SE is a high quality kit and very easy to work on. It flies very nicely, but of course you will have to draw the conclusions for yourself. I have flown Diabolo, Triabolo, and Henseleit. The E7SE is a great machine because not only does it fly extraordinarily well, it's a simple design with comparitively cheaper repair cost. I have had absolutely no problem with parts availability!
It's not belt, so it won't be quite as quiet as your Diabolo, and of course weight will depend on your setup, but its a way less complicated build than the Diabolo
Danny Dugger is offline        Reply With Quote Quick reply to this message
Old 11-02-2014, 07:56 AM   #5 (permalink)
One more thing... you might look into the Progressive Dampening System that FBL Rotors sells to ultimately tune the feel to your liking and flying style
Old 11-02-2014, 08:35 AM   #6 (permalink)
Get one! No upgrades necessary. Model flies great at low hs and is a monster at high hs. Great reps, and you can reach the owner for direct support if you ever needed to. Parts can be ordered direct from synergy. The se was just released last year as an update to the original e7. Shouldn't be going anywhere soon!
Specter 700 x 2--Diabolo UL--Compass 6hvu--Logo 600--oxy5+, oxy5, Oxy3, oxy2, SAB Mini Comet
Cajun Aircraft
B.Ewing is offline        Reply With Quote Quick reply to this message
Old 11-02-2014, 09:07 AM   #7 (permalink)
Went through the manual...indeed will be a simple build. Few parts count and straight forward design is why I am considering this heli.
I will try it stock. I am not the most experienced builder but so far I built a Trex450, KDS550, TSA700, 7HV, DIABOLO . Never had a wobble problem though I try different HS. Dunno if i am lucky or a good builder
No helis!
Jad.
Old 11-02-2014, 09:15 AM   #8 (permalink)
It flies beautifully all stock, in fact my SE is still stock after a year of abuse. As said... no upgrades necessary, it's ready for a beating right out of the box!!! I think you will love it.
Old 11-02-2014, 11:09 AM   #9 (permalink)
how much is the clearance between the frames? That is what is the possible largest motor diameter?
kit comes with 11T spur?
No helis!
Jad.
Old 11-02-2014, 02:13 PM   #10 (permalink)
Yeah, it comes stock with the 11t spur for the 4.9:1 tail ratio. The frames will fit very large motors, I have the monster KDE 700xf-495 (which has a 56mm can) in mine. I'll have to measure when I get home to give you a real number.
Old 11-02-2014, 03:21 PM   #11 (permalink)
Just in case anyone isn't familiar with the scale of this motor... I've attached a pic of it next to a Scorpion 4525-520 Ultimate.
Old 11-02-2014, 08:09 PM   #12 (permalink)
I measure darn close to 62mm between the frames. The KDE fills it up pretty well, lol. I'm actually working on a Kosmik install myself and it's as if the ESC plate were made for it. I used some 2.5x14mm screws and stacked three washers under each corner to space the controller up enough to access everything without obstruction. The Kosmik will bolt directly to the hole pattern on the ESC tray.
ID:	546971   Click image for larger version
ID:	546972   Click image for larger version
Old 11-02-2014, 11:30 PM   #13 (permalink)
thank you for sharing the photos. will it be some clearance between the Kosmik and the canopy?
How is the CF frames quality? for example the 7hv was kind of poor in this area.
No helis!
Jad.
Old 11-03-2014, 05:48 AM   #14 (permalink)
There's lots of room under the canopy, you could run a Cool Kosmik with a fan if you wanted to with room to spare. My frames are 2.1mm thick and seem to be good quality, but I'm no carbon expert. It's certainly more rigid than some offerings I've seen out there, these are tough helis.
Old 11-03-2014, 08:31 AM   #15 (permalink)
i have 2 of these helis. i fly the KDE 505kv, and the KDE 535KV motor in them. this one bad heli. with the 505KV, it is unboggable and so powerful it is actually scary...lol
no upgrades needed.
you may want to reconsider the BD3SX though if you are flying harder 3D. the elevator bounce that the unit exhibits really holds a pilot back from reaching his potential (IMO). for the record, i still fly 3 units myself, so i am not bashing, i am sharing my personal experience with the unit. what is ironic about it, my E7SE is the ONLY heli in my fleet with a BD3SX that doesnt bounce horribly though. it has a very very very small bounce.
i fly mine at 2050, 2150, and 2250HS. 2250 is my favorite.
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 11-03-2014, 12:03 PM   #16 (permalink)
no upgrades needed.
Have you tried the latest BD firmware? No more elevator bounce, and very locked in feeling. It's a huge improvement over all of the past versions. I think it flies very nicely now.
Old 11-04-2014, 09:19 AM   #17 (permalink)
So E7SE on the way!
The simple straight forward design of the Heli got me.
Will see if money well spent!
No helis!
Jad.
Old 11-04-2014, 10:17 AM   #18 (permalink)
Speaking from an E5 stand point I think it is well spent.
B400(retired),Mini Titan V1(Retired),Radikal G20 (scrapped),Align T-Rex 500pro DFC,Synergy E5s
Digger1973 is offline        Reply With Quote Quick reply to this message
Old 11-04-2014, 12:01 PM   #19 (permalink)
So E7SE on the way!
Sweet!! Welcome to the Synergy family, keep us posted!
Old 11-05-2014, 01:37 PM   #20 (permalink)
I can only think of 1 upgrade for the E7se and that is the metal bellcrank from fbl are there more that I haven't heard of?
Synergy 4eva
ChapaWolf is offline        Reply With Quote Quick reply to this message
