Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Banshee Helicopters
Banshee Helicopters Banshee Helicopter Support
Old 01-25-2015, 05:31 PM   #1 (permalink)
Default Naca Duct
Has anyone figured out where the best location is for these ducts? Like how far up or down the canopy it should be for the best cooling!!!
Helicopters Don't Fly - They Beat The Air Into Submission
Logo 500SE
Minicopter Diabolo 700
Banshee # 45 700 LE and 850
jcflyer is offline        Reply With Quote Quick reply to this message
Old 01-26-2015, 01:57 AM   #2 (permalink)
5cm from the front of the nose
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 01-26-2015, 06:16 AM   #3 (permalink)
The nose position we all tried on the TDR and did not work really well as we know that airflow at speed is nearly at 90deg to the NACA duct, better position would be to put one each side of the canopy just in fromt of the motor angeled up at about 20-30deg.
Just my two cents!
VControl
Old hand at Planks
Peter
Old 01-26-2015, 06:27 AM   #4 (permalink)
Do you guys have any pic's?
Logo 500SE
Old 01-26-2015, 06:49 AM   #5 (permalink)
Just my two cents!
Peter, your comment is noted, however..just by adding the naca duct 5cm from the nose I had a drop of over 15 degrees in temps...however my climate is very different from any body out there. 5cm from the front is directly on the kosmik..it was perfect...
I also installed a heat sink..there are pictures under "what did you do with your banshee" now I cant remember the exact figures but those two items dropped the temps by almost 20 degrees.
Diabolo 700
Old 01-26-2015, 06:54 AM   #6 (permalink)
I see even Gert on the Diabolo site recommends it either side. Any hole that brings airflow into the canopy will lower temps, but I think for least drag and most effective cooling it should be two either side angeled upwards to be inline with airflow at speed, that is the way the NACA duct works at it's most efficient. There is also a large suction from the bottom back of the canopy so it helps.
http://www.minicopter.de/catalog/pro...59&language=en
VControl
Old hand at Planks
Peter
Old 01-26-2015, 07:02 AM   #7 (permalink)
My TDR insane canopy has them like that...infact I have three NACA ducts...LOL Dubai heat is intense.
No wonder my banshee is slower than my DS all that blady drag...Just joking Peter
Diabolo 700
Old 01-26-2015, 06:52 PM   #8 (permalink)
Ok guys thanks ordered two ducts today!!!
Logo 500SE
Old 01-27-2015, 07:34 AM   #9 (permalink)
Judging from my Diabolo experience I will not use them anymore.
Sure, Denmark is very different from Dubai, so I got not more than 5 degree of a difference.
And that is logged temp, not measured one.
But I also think my motor is so much better with the new winding, so temps under the hood are under control.
I wish i could say that about the weather right now..
ArguZ is offline        Reply With Quote Quick reply to this message
Old 01-27-2015, 05:59 PM   #10 (permalink)
So what temps were you having before and after?
Logo 500SE
Old 01-30-2015, 01:40 PM   #11 (permalink)
OK in looking at the position for installing the naca duct, 5cm from the nose would put it below the esc and just above the packs. Don't know if that is gonna work? Any comments? I am running a kosmik 200 with a fan!!!
Logo 500SE
Old 01-30-2015, 10:16 PM   #12 (permalink)
Maybe a little higher and a bit more forward, the idea is to get air moving inside the canopy and if the entry point is to far back it will still stagnate inside the front portion of the canopy. Flow should be past hot components and out the back/bottom of the canopy where it is open and suction are created.
VControl
Old hand at Planks
Peter
Old 02-01-2015, 03:46 PM   #13 (permalink)
Well so much for adding a naca duct!!! I added one made some flights today and there was just about no change!!! The esc showed about a 5* cooling but the the motor was the same as before adding the duct!!! Gonna try adding some hole else where in the canopy...
Logo 500SE
Old 02-08-2015, 04:48 PM   #14 (permalink)
I did some more testing and I am getting about an 8* reduction in temps on the esc, so it is working for the most part.
Logo 500SE
Old 02-11-2015, 07:43 PM   #15 (permalink)
https://www.helifreak.com/showthread.php?t=681551
Email: InsaneCanopy@hotmail.com
Oat Insane is offline        Reply With Quote Quick reply to this message
