Old 12-29-2009, 06:09 PM   #1 (permalink)
Question Align ESC Settings for Align 500L Motor
I have a stock Align T-Rex 500 ESP kit with a 13T motor pinion and a 6S LiPO. I have limited flying experience and am not interested in 3D at this time.
The stock Align ESC (RCM-BL60G) has three settings for motor timing: LOW (2-pole), MID (6-pole) and HIGH.
Which one of these 3 settings should I use for the stock Align 500L motor?
Also, the ESC has three settings for throttle response: STANDARD, MEDIUM, and QUICK. Which one should I use?
Any advice greatly appreciated!
Align/Copter-X 450AE-V2 hybrid
Belt CP w/ Copter-X head in scale fuselage
Align T-Rex 500ESP w/mods
Align T-Rex 700E (final testing stage)
wrather1 is offline        Reply With Quote Quick reply to this message
Old 12-29-2009, 06:18 PM   #2 (permalink)
that 500 manual has those settings, Med timing, quick response
T-Rex 450PRO V2, T-Rex 700E V2, T-Rex 500EFL Pro ICE100 Vertigo motor T-Rex 550 FBL BeastX, KDE/Neu, ICE100
superjoe83 is offline        Reply With Quote Quick reply to this message
Old 12-29-2009, 07:02 PM   #3 (permalink)
I have the manual, and there are "default" settings. I actually wanted to know what people are actually using.
Old 12-29-2009, 07:19 PM   #4 (permalink)
thats what he ment use the default settings there what you should use
Alex
MY BLOG Stop by say hi :-)
500 ESP: Ely Q Comp: "Kasama'd Trex 600N:
lex7919 is offline        Reply With Quote Quick reply to this message
Old 12-29-2009, 07:29 PM   #5 (permalink)
Hey these are my esc settings for my 500 esp eactly same setup as yours, 13T pinion gp75- ds520 (FANTASTIC SETUP)
brake: low stick/ no brake, not much point, doesnt seem to do much
timing: mid stick/ dotn fully understand this but it works out nice
LVC: Mid stick/ medium, i fly on a timer so i dont depend on the battery going
Aircraft: Mid stick / soft start helicopter, no governor (more accurate)
throttle responce : High stick/. Quick so you dont have a delay on the throttle
bec output : high stick/ 6V because my servos and recivier can handle it (ar6200)
over all with this set up it flys very stable and smoothly, if you want my dx6i settings to let me know, they are very smooth and idle ip is as smooth, just with that more headspeed and negative pitch,
Hope this was what you was after
Trex-Deanoo is offline        Reply With Quote Quick reply to this message
Old 12-31-2009, 04:53 PM   #6 (permalink)
Thanks, man- exactly what I ended up with! Seems to work fine.
Cheers,
Old 12-31-2009, 04:55 PM   #7 (permalink)
no problem let me know how it goes
Old 01-01-2010, 04:50 AM   #8 (permalink)
does this matter if it's at medium responce if a flat throttle curve is used?
mark
http://www.youtube.com/user/cyclopops
Trex 500 torque tube driven tail, BeastX 9257
http://www.abbeyschool-of-motoring.co.uk/driving/
cyclopops is offline        Reply With Quote Quick reply to this message
Old 01-01-2010, 07:23 AM   #9 (permalink)
No it doesn't if you are running a flat curve. I'd still select a quick response if you use normal mode at all.
450 PRO, 500 ESP
Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice.
lankey is offline        Reply With Quote Quick reply to this message
Old 01-01-2010, 08:58 AM   #10 (permalink)
not really,. what it realy does is make the throttle not jump from 0-100 instantly, you will have a 2 second delay, its like a soft start but when your flying if you get me
flatcurves dont change the throttle speed so there is no speed to rise or lower too
if this makes sence :L its hard to explain in a way
just like lankey said, it is best to use quick responce if you nead to bail out and your not in idle up or whatevere
Old 01-01-2010, 03:04 PM   #11 (permalink)
I was wondering this? Can the stock esp moter (500L) even handle the HIGH timing??? Is it safe and possible? Anyone try it, or is it suicide?
Mike2112 is offline        Reply With Quote Quick reply to this message
Old 01-01-2010, 03:06 PM   #12 (permalink)
id like to know about this, timing i dont get fully i knwo it has something to ddo with the number of poles but im not sure, i would guess thatit is how fast the motor pulses/ rotates
Old 03-23-2015, 09:35 PM   #13 (permalink)
I set my timing degrees to 8 and own to 8 as well seems smooth haven't flown a full pack yet to lower motor temps but soon I'll know
emederos is offline        Reply With Quote Quick reply to this message
