Old 08-12-2012, 12:06 PM   #1 (permalink)
Default 2221-2010 and minip
2221-2010 is too powerful for MinIP or could work?
Greetings from Spain (although hurt for basketball )
donangelo is offline        Reply With Quote Quick reply to this message
Old 08-12-2012, 01:22 PM   #2 (permalink)
Banned User
Post
Someone told me a hyperion (same as scorpion) 2221-1630kv would be too fast for a Mini P. I'm guessing 2010kv would give insanely fast head speeds.
kavic5150 is offline        Reply With Quote Quick reply to this message
Old 08-12-2012, 01:37 PM   #3 (permalink)
The 2221-2010 is the 4 series motor. The problem is if you buy the scorp version you are gonna have to change the motor shaft so it will work with required msh pinions with one way bearing. The msh 2010 kv motor is the same as scorp but has the correct shaft for the pinions!! And yes the 1630kv motor is no good on the mini for 6 series. The mini requires a 1300kv motor for 6s packs. The mini uses a 120 tooth main gear. Now an answer to OP. No the motor is not to powerfull but is meant to be used with a 4s pack but why buy the scorp and then have to change the motor shaft ??? The adapter shaft for regular short shaft scorps is a discontinued piece of history as are the pinions to be used on it.
scott s is offline        Reply With Quote Quick reply to this message
Old 08-12-2012, 01:37 PM   #4 (permalink)
The 2010 is the Protos 4s.
The 1630Kv is too much for 6s operation on the Mini as it runs 1300Kv 6s.
MSH-Direct is offline        Reply With Quote Quick reply to this message
Old 08-12-2012, 02:08 PM   #5 (permalink)
Is that the 2010 and I have it in house aling450, I wanted to put it in the protos, with the sprocket adapter. My batteries are 6s ...
Old 08-12-2012, 02:17 PM   #6 (permalink)
unfortuanetly no it will not work on 6s in the mini Again the 2010kv motor is a 4series for the mini. The mini uses a 120 tooth main gear. Also the adapter shaft you speak of is nodda, out of production It is history because it just caused way to many vibe problems
Old 08-12-2012, 04:26 PM   #7 (permalink)
Banned User
Post
I forgot about the 4s option for the mini.
Donangelo you should definitely stick with the 6s setup. I know the 6s motor is out of stock almost everywhere. Check this thread for links to in stock 6s 1300kv motors. The one in Hong Kong is probably the best bet for cheap shipping.
http://www.ksmodel.com.hk/index.php?route=product/product&path=46_70_77&product_id=862
https://www.helifreak.com/showthread.php?t=441481
Old 08-14-2012, 02:21 PM   #8 (permalink)
Kavic Thanks, I've asked France. Now I do not know what to do with the 2210-2010 ... with how good it is
Old 08-14-2012, 02:36 PM   #9 (permalink)
One option is rewind motor for correct kv, gmauro & _Dekker in Europe are doing that. There is some Henseleit, Banshee and Diabolo guys in states doing it too.
I'm still learning to do it as extending this hobby.
-Samppa
Sent from my GT-I9100 using Tapatalk 2
Henseleit TDR 2011 | JR Vibe 50 | Goblin 380 KSE | Goblin Speed P850-50 4+4x1.6 DD 500KV | Goblin Urukay HK4530 5+4x1.5YY 540KV | Goblin 700 KSE | Jeti DS16 | VX1e | VX1 pro
http://www.helifleet.com/SJo1
SJo1 is offline        Reply With Quote Quick reply to this message
