Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 01-04-2013, 07:26 PM   #21 (permalink)
Originally Posted by Luvmyhelis View Post
Soko is also sending me one of his kits to setup the head with on the Warp.
I didn't see how it would work on the warp. Well as a pitch gauge, yes. But using it to set "spirit level" as they call it with the nontraditional rotor head looks impossible so a bubble level would need to be used as well. I still want one for setting up future helis though.
itsmillertime0 is offline        Reply With Quote Quick reply to this message
Old 01-04-2013, 08:38 PM   #22 (permalink)
I was going to use a 2221v2 1630kv. Will that motor work well and what pinion should I use
sresener is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 02:24 AM   #23 (permalink)
I set the throttle curve 25 -30 percent and get 3500 rpm on the head
I use 6 cells : Мир
should put 4 cells and will be okay
I do not have 4 cells and now supply 6
alexfly1980 is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 11:11 AM   #24 (permalink)
SDPI 3.17mm 12t pinion. And yeah, if you are running the 2200 can series this is the motor you want.
Old 01-05-2013, 12:09 PM   #25 (permalink)
Keep me posted BaconRaygun ( I was hoping you would get one also!). We can compare notes here. Also, since you are a Boca man, any plans there in stuffing these into your own Warp?
I had actually laid out a new 2200 can and was getting ready to custom wind it down to roughly 1530kv . Now, I think I will let that project rest.
Guess what just got delivered!
Its pretty... looks like a tiny 4025- I'll post up some pictured in a few.
To answer your question, yes, absolutely. I will be stuffing this heli with ceramics and high grade stainless bearings. I have my own method of allocating different bearing types to different areas of the heli as I believe that ceramics are not ideal in every application. I'm going to wait until I see wear though, and document this... figure some people would like to know how the stock bearings hold up.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 12:12 PM   #26 (permalink)
Can you weigh the motor?
Steve
Stevemech is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 12:15 PM   #27 (permalink)
my scale needs batteries, but I think I can stop at a friends house later.
AMA# 977012
Old 01-05-2013, 12:17 PM   #28 (permalink)
Thanks, that would be great!
Steve
Old 01-05-2013, 02:20 PM   #29 (permalink)
Here it is. Just waiting on blades, tail servo, BEC and a few LiPos... maiden should be this week!
I'll post up the weight later.
AMA# 977012
Old 01-05-2013, 02:27 PM   #30 (permalink)
I must have one
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 02:34 PM   #31 (permalink)
Very nice indeed.
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 03:04 PM   #32 (permalink)
nice, look forward to info. the stock motor really is a door stop, a small door stop :-)
cheers
raptorheli2 is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 08:30 PM   #33 (permalink)
When will this be available to the public?
vincent_tx is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 11:48 PM   #34 (permalink)
subbed.
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 01-06-2013, 11:37 AM   #35 (permalink)
Not sure when it will be available to the public. I'm just one of the guys testing the prototype... not really a rep or in any other way affiliated with Scorpion. I suppose I'll find out once we test these and give them (Scorp) feedback.
AMA# 977012
Old 01-06-2013, 11:51 AM   #36 (permalink)
Best hurry up then
Old 01-06-2013, 11:55 AM   #37 (permalink)
a new motor can't come quick enough from any source. i have seen smoother cement mixers than stock one. :-)
cheers
Old 01-06-2013, 12:23 PM   #38 (permalink)
Member
cheers
LOL!!
At least it smooths out at speed. I did a vibe analysis through my Vortex last night and my heli was super smooth. I put some stiffer mounting tape on my FBL sensor so as to help with tail tuning, etc., and I'll do another vibe analysis tonight.
The sound right after spool up is still there though, hasn't gotten any better or any worse.
Old 01-06-2013, 02:05 PM   #39 (permalink)
Originally Posted by Bob O View Post
LOL!!
flat out guarantee these low freq noises are related to magnetic resonance. It is a combination of stators, mag spacing, and how they were wound. Even though they got this part wrong, the motor will still run well at speed.
Old 01-06-2013, 03:20 PM   #40 (permalink)
Got a chance to weigh the motor. 106.8g (including bullets and all), not bad. 25.8 grams over the 2221-1630
AMA# 977012
