Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > mQX
mQX Blade mQX Quad Helicopters Information and Help
Old 02-15-2014, 01:30 AM   #1 (permalink)
Default DX8 settings
I just bought one and was wondering if you guys have any advise for using a DX8.
CrashandBurn is offline        Reply With Quote Quick reply to this message
Old 02-15-2014, 03:09 AM   #2 (permalink)
Here,try this.
I have experimented with loads of settings and find that these work well for me I use Helicopter Model Type
D/R and Expo set /Aileron/ Elevator and Rudder set Sw: to F Mode
F Mode Switch Position 2 ( in door use )
Pos: Stunt 2 = Aileron D/R = 75 Expo = 0 / Elevator D/R = 75 Expo = 0 / Rudder D/R = 125 Expo = 0
F Mode Switch Position 1
Pos: Stunt 1 = Aileron D/R = 100 Expo = 0 / Elevator D/R = 100 Expo = 0 / Rudder D/R = 125 Expo = 0
F Mode Switch Position 0
Pos: Normal = Aileron D/R = 125 Expo = 0 / Elevator D/R = 125 Expo = 0 / Rudder D/R = 125 Expo = 0
You can switch position round if you preferred making (Normal D/R = 75 and Stunt 2 D/R = 125)
Throttle Curve
Position N / 1 / 2 all the same / Low = 0% / 25% = 55% / 50% = 70% / 75% = 85% / High = 100%
I have tried different Expo settings you don’t want + expo it makes the stick feel unresponsive and a little dead at centre position if you are an absolute beginner better to reduce D/R settings from 75 to say 25 or even 15 to start with have tried different – Expo as recommended by others they work well but seems a bit twitchy on recovery of fast moves don’t know why? So I prefer 0 Expo on everything hope these setting are of some use to someone
Old 02-15-2014, 03:12 AM   #3 (permalink)
Or try this.
Setup for the Blade mQX – Spektrum DX6I, DX7/DX7se, DX7s, DX8/DX18 Transmitter.
Use a new model or reset a current model.
All the default settings are used except for what is listed below.
You can use HELI or ACRO mode.
MODEL TYPE – HELI
SWASH TYPE – 1SERVO90*
REVERSE – All normal (N)
TRAVEL ADJ – All defaults
For quicker response increase ALIE and ELEV 125% to 150%. For quicker rudder response increase RUDD 125% to 150%.
THRO HOLD – Default is INH. Enable throttle hold and use these settings.
HOLD POS. 0.0%
SW: RUDD D/R
DR&EXP – Set to your personal preference
The mQX board has 40% expo on all controlls. This is set by the factory.
It can be counteracted with – 40% expo.
Here are some settings you can try to start with.
Standard Settings – Option 1
ELEV D/R = 100% EXP – 20%
AILE D/R = 100% EXP – 20%
RUDD D/R = 100% EXP – 20%
Standard Settings – Option 2
ELEV D/R = 100% EXP INH
AILE D/R = 100% EXP INH
RUDD D/R = 100% EXP INH
Beginner Settings
ELEV D/R = 50% EXP +20%
AILE D/R = 50% EXP +20%
MODEL TYPE – ACRO
Beginner Settings
