Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 03-29-2012, 10:12 PM   #1 (permalink)
Blade Forum Support
Default Review on NCcreig work on flashing my xp12a esc
Hey folks I'm back with another review this time on my boy NCcreig. I sent NC my esc to flash it and while he was flashing he cleaned up the board and he did a great job on it. He did a professional job on it and he did it fast. I mail it to him Tuesday and he got it Wednesday and I got it back today ( Thursday ) by the way I'm in Charlotte and he is in Sanford but the big plus is he got it he did it and he did it fast and had it back to me so I can play .
So if you need someone to flash your escs he can do it I know their are others that can do it too, but I know he can because he done mines and he did a good job so I'm giving him :thum bup: for a good job, clean work, and fast service.
Here are some pics of his work.
Be blessed
Isaac
Sent from my A100 using Tapatalk
ID:	303168   Click image for larger version
ID:	303169   Click image for larger version
ID:	303170   Click image for larger version
ID:	303171   Click image for larger version
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 03-29-2012, 10:46 PM   #2 (permalink)
Wow, that solder joint on the signal wire is *perfect*!
And the hot glue strain relief at the bottom of the esc... Dang, I woulda burned a finger trying to pull off something that looked that good.
Sheesh, Craig, great stuff!!!
SuperBee364 is offline        Reply With Quote Quick reply to this message
Old 03-29-2012, 11:23 PM   #3 (permalink)
I dunno, I was going to offer to clean up his wiring for him....
Seriously, very, very nice work.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX
65L88 is offline        Reply With Quote Quick reply to this message
Old 03-29-2012, 11:28 PM   #4 (permalink)
You'd be surprised how much easier it gets when you do them alot. I actually solderd my BL tail signal wire holding the 3in1 in my hands with no support yesterday. I usually use helping hands or my vise, but didn't have em with me.
Nice work craig, keep it up!
MSH PRÔTOS
Rave Ballistic 635
Spunjah413 is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 07:17 AM   #5 (permalink)
nice looking solder job for sure!
MHS PROTOS - FB-CF, ThuderPower, Quark Gyro
E-Flite mCP x - C05 & HP05/SR120 Tail
SAB Goblin 770 -
Kontronik Motor&ESC
memheli is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 12:57 PM   #6 (permalink)
Going to do a flight vid Isaac? Interested in how the HS holds with this gov code.
God Bless!
maarset is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 01:10 PM   #7 (permalink)
On my first BL build my hands were shaking so bad trying to solder that signal wire, it took me an hour to do. This last one when i did it, it literally took 15 seconds. Tinned, touched, done. It def does get easier. Great job though. Although someone beat me to the punch...I was offer to clean up the wiring too.
Compass Warp 360/Vbar
Mcpx Bl stretched/HP03T
Goblin 700/Vbar silverline
Chris20 is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 01:15 PM   #8 (permalink)
I can appreciate that!
Thanks for the compliments, guys.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 01:16 PM   #9 (permalink)
God Bless!
The 915 doesn't take well to governing as much as say the HP06v2 or the Spin 16.3. If you go too low in governing you experience blowouts. I feel around 80-85% is good with barely any blowout, and 65-70% super low but will get pretty good blowouts on really heavy collective (great for indoor stuff).
Me and Dylan suspect its the batteries that are the limiting factor on why the 915 doesn't govern so well. Dylan as measured 10A draw on the HP06v2, so who knows what the 915 is trying to request during full load. If you run the 915 @ 80% for around 2-2.5 minutes, than to 100% you will hear almost no increase in HS as the battery just does not have enough juice left to give it any more.
MSH PRÔTOS
Rave Ballistic 635
Old 03-30-2012, 01:23 PM   #10 (permalink)
No problem....your jobs are always clean. I may still ship u my esc if the XP-12 ever becomes available again.
Old 03-30-2012, 01:44 PM   #11 (permalink)
So would a CM05 motor be out of the question for the gov code?
I have a CM05 with XP-7a esc and stock tail extended boom.
Old 03-30-2012, 01:56 PM   #12 (permalink)
I just picked one up from ClubHeli.com. I had to pay $26 for it though!
Team Newb pilot
Old 03-30-2012, 05:29 PM   #13 (permalink)
yes it will work, just did mine and it flies perfect. even got it governed to fly in the house.
Atom500(FBL)., Gaui x4II (FBL) ;Trex450 sport (FBL). All with Ikon fbl gyro. AMA#1019423.
Tony .
tony521 is offline        Reply With Quote Quick reply to this message
Old 03-31-2012, 03:40 AM   #14 (permalink)
Blade Forum Support
Ok I have change out the 915 for the HPO8 to use the govern xp12a esc becuz it didn't do well with it . Like it was said before the first 2mins it did fine then the HS would drop off . No threat I have a Hpo8 and that fixed the problem. 100% th and 100% pitch no bog I just did that to see How good it works so im running 85% pitch and 100% th and it works great so the hpo8 will stay on the gov. Oh I forgot the it has 8t pinion.
Be blessed
Isaac
Sent from my DROIDX using Tapatalk
FPV Everything Now
GOD BLESS
Old 03-31-2012, 05:51 AM   #15 (permalink)
This is probably the resaon why, Isaac:
I'm glad you got running to your liking!
Team Newb pilot
