Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G3
4G3 Walkera 4G3 Helicopter Support
Old 02-26-2009, 09:45 AM   #1 (permalink)
Default Home Made Skids 4G3
Patience can get you a good set of home made upgrade skids !
See picture here..https://www.helifreak.com/showthread.php?t=121746
Hovering is divine, the alternative is PLANE !
nigel1 is offline        Reply With Quote Quick reply to this message
Old 08-03-2009, 07:37 PM   #2 (permalink)
My 4G3 is long gone but since I am still being asked how I made my skids...here you go...the stuff I used is called Strip Styrene, I used this product but you can get others. Try a local hobby shop that sells trains :
You will see one of these stands in the store.....http://www.evergreenscalemodels.com/Retailers.htm
http://www.evergreenscalemodels.com/Shapes.htm
Item# 6-222 - Used to make Joining pieces
Item# 6-224 - Main Skid Tubing
Take the 224 tube make a jig to bend it the shape you want. Thread a flexible heat proof rod into it (like a thin steel cable) to avid it kinking when you bend it. Heat it gradually and bend it then hold it in position and let it cool (10-15 seconds), it will stay where you cool it...
Then use tiny pieces of the #222 and some CA to hold the skids and frame together.
Drill holes with a small drill to fit the heli and I used some small black screws that I had in a tub from my Trex450 spares.
Mount and fly , when you land harder than you should LOL the joining pieces typically break, you you use a tiny amoputn of CA you can just repair them if not you will need to drill them out and replace the joining pieces or make a few sets for spares.
The material comes in bags of 8 pieces and 5 pieces so you will have enough to experiment it iwll take a few tries to get it right.
Hope this helps good luck.
If you want to buy a set of commercial upgrade skids, see http://www.micro-flight.com/Walkera%204G3.htm
However double check when I saw these in the flesh they were not tubular (as shown on the site) they were laser cut carbon skid frames with tubular skids at the bottom.
For those of you after scale bodies for your 4G3...
http://darthdrk.4t.com/photo3_6.html
Old 08-04-2009, 05:37 AM   #3 (permalink)
Thank you Nigel1, I'd be sure to try this. Very informative.
Cheers
Paul
walkera4g3 is offline        Reply With Quote Quick reply to this message
Old 08-04-2009, 08:04 PM   #4 (permalink)
Default skids
ive got a set of these. work well as a battery holder as well.
cheers
"What the hell's wrong with you kid ? Everyone loves a clown"
Crashntrash is offline        Reply With Quote Quick reply to this message
Old 08-05-2009, 07:54 PM   #5 (permalink)
Music wire covered with shrink tubing works good for me.
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote Quick reply to this message
Old 08-11-2009, 07:43 PM   #6 (permalink)
Originally Posted by Crashntrash View Post
http://www.micro-flight.com/Walkera%204G3.htm ive got a set of these. work well as a battery holder as well. cheers
I have these as well and love the rubberband holding method. I use it to hold 2 batteries at once, no problem.
Mike
Walkera BL 4G3 stock bl main 16T, 2.9g tail - Tx 2801
Blade MCX/MSR cskr 19mm swash 4 outdoor flight - Tx DX7
Function over ALL else
my photography http://BesPhoto.com
mikejbb is offline        Reply With Quote Quick reply to this message
