Old 02-14-2007, 11:27 PM   #1 (permalink)
Default After market Swift Frame, what would you change/want?
Hi folks, I'm in the middle of designing/testing some frames for the T-Rex 600 and since some folks showed some interest in some Swift frames, I wanted to ask what you would like improved/changed with your Swift frames.
I will lay some things to bear in mind so we can improve the frames with minimal new parts and minimal machining/ costs for everyone.
- The frames will be in G-10 material so they are FLAT.
- I've solved the tail boom mounting by having a doubler on both insides of the frame to shim it.
- The upper bearing mount will require spacers to use the stock bearing block.
Now some questions,
Do you want to use full size servos and the bellcranks, or do you want to drop some weight and have mini digitals direct to swash? 2 versions (stock/ultra light)?
Do you want to use the stock gear or switch over to a T-Rex 600/Raptor gear?
Do you want a battery bay built into the frames to protect your batts (would probably require the shorter gear)?
If you want the lower battery bay, do want it slightly wider so A123s fit (if the dont fit the 53mm width already)?
Can boom supports bolt to the bottom of the frames instead of the stock langing gear?
Do you want a different setup for electronics mounting (some mounting plates at the rear above the boom, a longer front end that is protected more with side frames?)
I don't own a Swift, however, a fine gentlemen sent me his used ones so I could have a good idea at what is involved in this project. I think it is most certainly doable. Toss some ideas around and lets see what can be done.
My work on the T-Rex 600 frames can be seen at R.D. Heli Frames
Thanks,
Ron
R.D. Heli Frames
LOGO 600 3D V-BAR HK4035-630 Power Jazz 14SA123
T-Rex 600E Z-Power 50 CC85HV 14S A123
T-Rex 600N V-BAR TT.53 Redline 3DHiflow Pipe 2SA123
rdespins is offline        Reply With Quote Quick reply to this message
Old 02-16-2007, 03:25 PM   #2 (permalink)
Default Re: After market Swift Frame, what would you change/want?
Yes, I'd prefer to use full size servos with the bell cranks as it will help with the flight loads and not be direct on the servo's. Plus with push-pull to the bell cranks the load on the servo output spline will be equal.
By this do you mean the landing skids? If so yes, a shorter, more aggresive set of skids will look great on the Swift. Neon cloured ones will be even better to tart the models up
Yes, most definetly!! This is one thing I'd like to see on the Swift as the battery is exposed being underslung like it is and I know first hand just how vunerable it is to.
Ok, we all aim not to crash but invariably we do while learning new things and if we can atleast try to save our expensive batterys then great.
This alone will make any aftermarket frame conversion appeal to me.
Doing so this will make the conversion appeal to a wider audiance and so if it can be done but still be practical incorporate it. Or better still offer the option with spacers?
Yes most definetly I feel. I have my own mounted to the top of the main frames, just above where the gyro plate sits on the boom clamps. Works well for me and many others now to.
Yes again, sounds good to me. If possible a location for the ESC which is as far away as possible from the receiver and gyro, yet still afforded some crash protection by the frames.
Cant wait to see what you come up with.
Thanks,
Ron
Am going to have a look now.
This sounds like a very nice project and if I had access to the engineering shop I used to work at then I'd have looked into this myself as it's a good idea. The battery protection is one area I'd love to see done and indeed have ask Century for this but even their new carbon swifts still have the battery exposed which I feel is a shame, but the models look good and go very well so it's just a gripe.
Ian Contessa
Coolice Charge Cases & Power Supplies
Facebook Page
Coolice is offline        Reply With Quote Quick reply to this message
Old 02-16-2007, 03:33 PM   #3 (permalink)
Heres some quick sketches, any comments? These use full size servos with bellcranks.
I'm not certain that the battery tray in the second one will work out, it's probably too high and batts would hit the canopy.
Ron
R.D. Heli Frames
Old 02-16-2007, 06:37 PM   #4 (permalink)
Team Taco VP
Make it so all 3 servos can be on the same bell cranks so you dont have to calculate and use a longer arm for elevator!
Bob
Old 02-17-2007, 12:46 PM   #5 (permalink)
Bah Bob, you've already sorted that all out for everyone hehe.
Heres the latest rendition, Front battery tray is a little over 57mm wide, whould fit A123s.
R.D. Heli Frames
Old 02-18-2007, 09:53 AM   #6 (permalink)
Team Taco VP
Yea but I still dont like it!
You are WAY out on the servo arm and it's not push/pull so that poor servo is going to be hurting long term....
Bob
Old 02-18-2007, 10:16 AM   #7 (permalink)
Here is a different nose end that has lower battery bay. The dimensions are probably off, but the idea is there.
R.D. Heli Frames
Old 02-21-2007, 05:47 PM   #8 (permalink)
Erm, has any one seen the carbon 550?
Push pull Elevator, place for your ESC, remember you can fit a 10S pack on the bottom. It has a driven tail aswell, and your gyro is rite at the back on a plate.
Theres also a switch mount, metal rotor head, Full metal swash, hardened spindel.
Whole Kit of $390 wich is $210 less than a logo 14, $300 less than a razor.
KASAMA Team Pilot
www.adsheli.com
-V-blades -CSM -Spektrum
Adam Turner is offline        Reply With Quote Quick reply to this message
Old 02-21-2007, 10:56 PM   #9 (permalink)
Team Taco VP
Adam... I will take one
I saw it at the AMA Show but never even though to talk to Antonio about it
Bob
Old 02-22-2007, 11:09 AM   #10 (permalink)
Will there be sold upgrade parts for the old swift 16?
zenndium is offline        Reply With Quote Quick reply to this message
