Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Master CP
Master CP Walkera Master CP Helicopter Support
Old 03-04-2013, 02:51 PM   #21 (permalink)
Originally Posted by kevtucker View Post
Ok I put the exact settings in my Devo-7 and have levelled off the servo arms and Swashplate.
So next step is to get both Blades at 0 Degrees on my pitch gauge at Mid-Stick by altering the Ball links ?
Cannot do this now as I'm at work but will try when I'm home.
Thanks for your help
Kevin
Correct . Once done use pitch travel adjust if you need to, to get the +10 deg of pitch your looking for at high stick and -10 deg at low stick .
5488fletcher is offline        Reply With Quote Quick reply to this message
Old 03-04-2013, 03:09 PM   #22 (permalink)
Thanks. Will have a go at it tomorrow.
Kevin.
kevtucker is offline        Reply With Quote Quick reply to this message
Old 03-04-2013, 04:32 PM   #23 (permalink)
Last thing Barry.
So When I put the Throttle to Full Stick I adjust with TRAVAD PITCH H %
and TRAVAD PITCH L % for low stick in the Tx.
Sorry for all questions. Just hoping I'm doing everything correctly this time.
Kevin
Old 03-04-2013, 06:44 PM   #24 (permalink)
Last thing Barry.
Kevin
correct . No problem ask as many questions as you wish ., i'm glad to help .
Old 03-04-2013, 09:03 PM   #25 (permalink)
I get it now. So the TRAVAD is adjusting each of the Three servos in either direction on how much they move when you use the Sticks ??
Kevin
Old 03-04-2013, 09:33 PM   #26 (permalink)
Kevin
Yes , its adjusting the range of movement from center of servo travel .
Old 03-04-2013, 09:52 PM   #27 (permalink)
After your done adjusting TRAVADJ and the head is all set up and you have your -10 at low , mid stick is 0 pitch with arms level and high stick is +10 deg , you can go back into your normal pich curve and reset PL so you have between 0 and -2 deg at low stick . This will keep you from slamming heli into the ground during a panic throttle shut off as the ground is coming . Nothing like full negative pitch to help tear up a heli .
Old 03-04-2013, 10:10 PM   #28 (permalink)
Was going to ask if I left it after I set up, so my Pitch Curve I could put to say :
PL -35%
P1 INH
P2 INH
PM 0%
P3 INH
P4 INH
P5 100%
Kevin
Old 03-05-2013, 08:26 AM   #29 (permalink)
PL -35%
P1 INH
P2 INH
PM 0%
P3 INH
P4 INH
P5 100%
Kevin
That will work good for you in normal flight mode .
Old 03-05-2013, 12:41 PM   #30 (permalink)
Hi mate. Think I have managed to get the 0 degrees and 10 degree at High and Low stick.
Have to wait till Friday till I can try to Fly as I'm on Night shift all week.
Also just ordered this
http://store.blinghelis.com/index.ph...master-cp.html
Ill let you know how I go Barry and thanks for help. Will be back if I have a problem
Kevin
Old 03-05-2013, 03:40 PM   #31 (permalink)
Good luck .
Old 03-10-2013, 09:39 PM   #32 (permalink)
Hows your heli flying ?
Old 03-11-2013, 04:28 AM   #33 (permalink)
Well Barry.
It's in repair again. Had a accident in house with it where I flicked wrong switch on Tx and it has hit a wall and burnt the Main Motor out so just waiting on new one.
I also have a Xtreme Swashplate / Rotor Head and Blade grips to put on.
I posted about the blade grips yesterday regarding the washer placement.
I should be backup this weekend. Been playing with my new V911 I got Saturday. It's brilliant I love it
Kevin
Old 03-11-2013, 10:40 PM   #34 (permalink)
I wanted to add something after watching cruzroys video set up that i forgot to mention but you may already know .After you get the head properlly set up with the 0 deg . arms 90ed,and m= 0 in pich curve in normal throttle mode , if heli feels like it drops to fast go into your pitch curve and adjust for 4 or 5 deg of positive pitch at mid stick . Your only concerened with having p=0 when you are setting servo arms at 90 and adjusting the head for proper geometry . Once this is done play with the pitch curve to get the feel that helps you learn . You may have to raise your throttle curve m position a little if heli is bogging down .
Old 03-12-2013, 12:39 PM   #35 (permalink)
Just got all parts put on.
Problem is I have positve pitch at low stick and negative at high stick.
Will have another look tomorrow but any ideas why this is ?
Kevin
Old 03-12-2013, 06:23 PM   #36 (permalink)
You probably have the new extreme blade grips set wrong . They should be set for leading edge control , i bet your set for trailing edge control . blade grip link should be on same side as leading edge of main blades .
Old 03-12-2013, 07:06 PM   #37 (permalink)
Hi Barry
Will post a picture tomorrow of how I have the blades and grips place. Everything looks fine to me. All look same way as per instructions.
Getting frustrated with this now
Kevin
Old 03-12-2013, 07:56 PM   #38 (permalink)
Hi Barry
Kevin
Make sure also that your not reversed in the transmitter for pitch in the servo reversing menu page .
Old 03-13-2013, 03:02 AM   #39 (permalink)
Haha was using the gauge the wrong way round
Its ok now.
So, This is what I have done
Set Pitch Curve to PL=-100% PM=0% PH=100%
Got -10% at Low Stick With TRAVAD PITCH at L = 25%
Got +10% at High Stick With TRAVAD PITCH at H = 35%
Got 0 at Mid Stick
Then I have copied the settings to a new slot and changed Pitch Curve to
PL=-35% PM=0% PH=100%
Then I get on the gauge
-3% at Low Stick and 16% at High Stick and 0% at Mid Stick
Is this all correct ? Not tried to fly it yet though. Just wanted to verify I had done it correctly.
Again Thank you for your help and sorry for been a pain Just all a bit confusing and want to get the Heli in the air.
Kevin
Old 03-13-2013, 08:42 AM   #40 (permalink)
Its ok now.
Got 0 at Mid Stick
Kevin
Are you wanting to run 16 degrees at high stick ? Also i noticed that your TRAVAD percents are not both 25 . If you lower the high one to match the low one do you have10 degrees blade pitch both directions ? If you do than your good . If all is good give it a whirl . If you dont like the feel of it around center you can always change the midde stick percent to give you 4 or 5 degrees positive pitch around around center stick but only in normal throttle mode .
Tags
master cp take off
