Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 03-08-2012, 09:38 AM   #21 (permalink)
Found the problem,.. I posted the pdf in another thread on this subject last month
https://www.helifreak.com/showthread...=369235&page=4
gwright is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 04:15 AM   #22 (permalink)
Since i need to get some spare rubber grommets i am thinking of grabbing 140 degrees conversion. To say it very simply, all i need is PV1409 and PV1410 and in radio switch to 140 degrees swashplate and that will be it for the conversion?
shelved : Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 08:20 AM   #23 (permalink)
Member
Looks like the rods and ball links (1410) are included in 1409.
This is for the 140* 1:1 setup, being that the balls for aileron and pitch are the same distance away from the center of the main shaft as the ball for the elevator.
Old 03-15-2012, 08:50 AM   #24 (permalink)
Oh i see. Well spare balls and links are ok to get so i think i will keep 1410 in the order, it's just 2.79usd anyway...
Old 03-15-2012, 09:47 AM   #25 (permalink)
Member
Sounds good. It never hurts to have spares of these small bits.
One thing to note, and I'm sure you'll realize this when you assemble these linkages, is that there are two different sizes of ball links. The longer links get used on one set of rods, and the shorter links get used on the other set of rods. The rods with the long links go on the left side servo. The rods with the short links go on the right side servo.
You can see the difference in these two pics:
Left side - long ball links
Right side - short ball links
Old 03-15-2012, 12:11 PM   #26 (permalink)
Oh thanks for pointing it Bob. Yea i would probably figured but now i am sure .
So order is done, packed metal bearing blocks upgrade too. Not eager to change them really when heli is all setup but i will see...
Old 03-15-2012, 09:12 PM   #27 (permalink)
wouldnt 140 deg swash be pointless with FBL? the entire theory around 140 is to eliminate interaction. FBL does this for you.
Mikado 550sx, TT X50N, Align 470L
johnbs8 is offline        Reply With Quote Quick reply to this message
Old 03-15-2012, 09:35 PM   #28 (permalink)
Oh i don't know about that but i have flybar anyway... But i guess you are asking Bob right?
Well if it's supposed to reduce the movement of elevator servo because that on 120 moves a lot more than pitch and aileron then i think it would work on FBL setup because you still have to move elevator servo more as distances to main shaft are the same no?
Old 03-15-2012, 11:41 PM   #29 (permalink)
Member
I wouldn't say it's pointless. A more precise mechanical setup can only make the FBL controller's job easier (relieving the control loop or something like that). The MICROBEAST has specific support for 140* and 140* 1:1 swash plates configurations.
