Turbine Helicopters Turbine R/C Helicopters |
03-16-2009, 01:31 AM | #41 (permalink) |
Re-routing plumbing and wiring to Bergen specifiec exit in FOD Screen
-Kevin No helicopters were harmed in the creation of this post. AMA CD # 7309, Turbine Waiver# RW 890 Click Here For Bergen Intrepid Turbine Build Videos |
03-16-2009, 01:33 AM | #42 (permalink) |
FOD orientation: The Bergen way.
03-16-2009, 01:33 AM | #43 (permalink) |
Ready to wire the Glow Plug and Starter Motor
03-16-2009, 01:34 AM | #44 (permalink) |
Installing the Starter Motor into the FOD Screen
03-16-2009, 01:35 AM | #45 (permalink) |
Gas Producer is done!
03-16-2009, 01:36 AM | #46 (permalink) |
test fitting 2nd Stage and Gearbox:
05-15-2009, 11:58 PM | #47 (permalink) |
Interstage tunnel installed
05-15-2009, 11:58 PM | #48 (permalink) |
Test fitting temperature probe:
05-15-2009, 11:59 PM | #49 (permalink) |
Temp probe installed and secured:
05-15-2009, 11:59 PM | #50 (permalink) |
Test fitting front engine mount (Beveled side towards the engine!)
05-16-2009, 12:00 AM | #51 (permalink) |
Front engine mount installed:
05-16-2009, 12:01 AM | #52 (permalink) |
Engine and assorted plumbing, valves and electronics set up on a test rig:
05-16-2009, 01:26 AM | #53 (permalink) |
Ignition!!!!
05-16-2009, 01:36 AM | #54 (permalink) |
2nd stage/Gearbox bolted up:
05-16-2009, 01:39 AM | #55 (permalink) |
Rear engine mount installed:
05-16-2009, 01:43 AM | #56 (permalink) |
Gearbox lube pipe installed:
05-16-2009, 01:45 AM | #57 (permalink) |
Closeup of lube pipe mount installed and bent into position:
