Kontronik Drives Jazz and Jive ESC's and other Kontronik equipment support |
01-22-2014, 08:15 AM | #1 (permalink) |
Brand New Products from Kontronik
Go check out the latest products from Kontronik!!
Jive Pro http://www.kontronik.com/index.php?o...inzeln&lang=en Multirotor Esc's http://www.kontronik.com/index.php?o...id=213&lang=en
Richard Zappe Team Kontronik USA PeakAircraft |
01-22-2014, 08:57 AM | #2 (permalink) |
You see it lol, I was going to announce it just now lol
It has been so hard keeping this one quiet as I have been about ready to burst with it!!!
The difference between knowing your s**t and knowing you're s**t! Optipower - Kontronik Drives
01-22-2014, 09:26 AM | #3 (permalink) |
Hehe I have been waiting ever since Charles told me a few months ago.
01-22-2014, 09:30 AM | #4 (permalink) |
They also mention the LogTel
logging and telemetry module to work with the new Jive Pro and Kosmik. http://www.kontronik.com/index.php?o...emid=2&lang=en All other modules from the kosmik including the bluetooth module will work with the Jive Pro. You are limited to only one accessory port instead of 3 like the Kosmik.
01-22-2014, 09:58 AM | #5 (permalink) |
Will the Jive Pro be firmware upgradeable via the Progdisc?
Rush 750 / JR 8917HV / MKS HBL980HV / Kosmik 160HV / Scorpion HK-4525-520 Ultimate / HC3SX / AR8000 / TM1000 Goblin 500 / Hitec HS-5245 / MKS DS760 / Talon 90 / Quantum 4115-1200 / HC3SX / AR8000 Blade 450X / mSR / mCPx / CX2 / |
01-22-2014, 10:39 AM | #6 (permalink) |
Yes it is based on similar architecture to the Kosmik so yes you will be able to update it with the Progdisc
01-22-2014, 12:00 PM | #7 (permalink) |
So the benefits are:
1. BEC up to 8V 2. Supports Kosmik BT device programming 3. More advanced governor 4. End user can update the firmware Am I missing anything?
Mark Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc.... |
01-22-2014, 12:21 PM | #8 (permalink) |
No more jumper. (last i heard)
longer spool up times for scale birds
01-22-2014, 12:25 PM | #9 (permalink) | |
01-22-2014, 12:30 PM | #10 (permalink) |
neither of those are official yet. should be announced shortly
01-22-2014, 01:02 PM | #11 (permalink) |
Price for the 80HV is €20 more than the current 80HV and the 120 is the same as the Helijive is now.
Availability is they are due this spring/early summer. They will have the ability to have the same features as the Kosmik, capacity limit etc due to the same chipset and larger processor being used.
01-22-2014, 04:40 PM | #12 (permalink) |
What about signal output and compatibility with Vbar gov?
01-22-2014, 04:57 PM | #13 (permalink) |
Cap Limit like Kos, put me down for 2 80's
01-22-2014, 05:22 PM | #14 (permalink) |
Again same capabilities as kosmik so it will not support external governor. Honestly kosmik governor is better than vbar governor.
01-23-2014, 12:06 AM | #15 (permalink) | |
Thanks |
01-23-2014, 12:29 AM | #16 (permalink) |
its more than likely faster than your transmitter can download. not sure about an exact number. the stream coming out af a kosmik is around 100hz so jive pro will probably be the same.
01-23-2014, 03:01 AM | #17 (permalink) |
I wonder if the new Jive Pro would still work with Jlog devices...
01-23-2014, 04:09 AM | #18 (permalink) | |
Also, the Jive 80 Pro will have all the features that the 120 Pro will have
