Old 06-12-2009, 11:23 PM   #1 (permalink)
Exclamation 13t & 14t Pinions
I just put the short shaft, adapter and 13t pinion on the Protos. It looks like it sits too high.
The pinion can't go any lower in the adapter and the adapter can't go any lower on the shaft.
I'm afraid the belt will come off!
Anyone have this problem?
Did I assemble something wrong?
ID:	101530   Click image for larger version
MSH Prôtos ...A Better Way to Fly
MSH Prôtos Mini
Mikado Logo 600
Vergnügenstabi
DriveWRX is offline        Reply With Quote Quick reply to this message
Old 06-13-2009, 12:42 AM   #2 (permalink)
Yeah , your too high.
I had the older kit with the longer shaft motor , so after calucating a few times i cut the shaft to fit.
You say you bought the short shaft for the motor ? Maby it can be set lower ?
martin
Logo XXtreme 800 8917 / 256HV VBC
rcmarty is offline        Reply With Quote Quick reply to this message
Old 06-13-2009, 06:06 AM   #3 (permalink)
please delete
SAB GOBLIN 700, MKS HV Servos all round, Vbar Silverline Pro, Quantum 500KV "Goblin Edition" motor, Kontronik Kosmik 160HV, Giant Power Lipos.
discoferret is offline        Reply With Quote Quick reply to this message
Old 06-13-2009, 06:59 AM   #4 (permalink)
http://www.msheli.com/Manual/Motor_S...odificaton.pdf
rick.007 is offline        Reply With Quote Quick reply to this message
Old 02-24-2010, 12:04 PM   #5 (permalink)
martin
rcmarty - Im in the same boat with the older kit and totally confused about what/how to cut.. I have the adapter for the 13T.. does it still need cutting ??
aquaanox is offline        Reply With Quote Quick reply to this message
Old 02-24-2010, 09:05 PM   #6 (permalink)
You will need to trim the motor shaft to use the 13/14t pinions
Starting with a standard shaft and 15t pinion i set the height of the pinion for normal operation. Then i calculated how far into the 13/14t adapter the motor shaft would go in , then trimmed off the difference.
I put an old t-shirt/rag on the motor shaft (Small cut then slide over shaft for a good seal) and wrapped up the motor so no grindings would get into the motor.
I used a dremmel with a cutoff wheel , i stopped to let the shaft cool if it got too hot for my liking.
My protos was a lot better after the drop in pinion (14t) and raised the throttle % . Far less shutdowns
Martin
Old 02-25-2010, 01:20 AM   #7 (permalink)
corrado
www.msheli.com
HighFreq is offline        Reply With Quote Quick reply to this message
