Blade 450X Blade 450X Helicopters Information and Help |
06-22-2014, 12:39 AM | #1 (permalink) |
Canopy Grommet Source
Anyone know a source for these? or size? I've managed to finally loose all mine.
06-22-2014, 12:41 AM | #2 (permalink) |
I dont know if they are the same size, but align's 450 canopy grommets are 2 bucks for 4 of them.
Team Synergy |
06-22-2014, 06:03 PM | #3 (permalink) |
I can't vouch for them as I've never used them but microheli sells some specifically for the 450x. That's my plan since I seem to pop mine off nearly every single time I try to put on the canopy.
(I've found though that licking your fingers and rubbing them on the canopy posts helps them slide through the grommets easier) |
06-22-2014, 11:49 PM | #4 (permalink) |
This is what I used and they are available from most DIY stores. They are used as bump stops on cupboard doors etc. I made a small hole in the centre and stuck them on the canopy with cyano. Also if you stick them on to the rear most position of the slot the canopy is a slightly looser fit.
06-23-2014, 06:19 AM | #5 (permalink) |
For a quick fix, I've been using the rubber servo grommets (round type not square). It's not a permanent fix but when you're out flying it'll work.
06-23-2014, 06:39 PM | #6 (permalink) |
I just bought some from here yesterday. Was the cheapest I could find when you add in the shipping charges. "Whatever the market will bear" applies to these things for sure.
http://www.ebay.com/itm/221463922979...84.m1439.l2649
Gaui X3 Spartan Vx1e, Blade 130x, 450x G31(MIA) Taranis, DX6i |
06-24-2014, 01:37 PM | #7 (permalink) |
I took my old grommet with me to home depot and bought a pair that are working just fine.
George
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis |
06-26-2014, 06:55 AM | #8 (permalink) |
When you put the new grommets in (or old ones if they're perfectly intact) just place a drop of ca on the inside of canopy and let it encircle the outside of the grommet. No more popping off/wearing out easily - unless you just try to destroy it
proto x - nano cpx - 450x - dx8 |
07-21-2014, 11:45 PM | #9 (permalink) |
I found the Align grommets to work better for me.
Blade 550x // 450x // 450-3D // mCPX-BL // mCPX2 // DX9 // DX6i // Phoenix 5 // Thunder AC680 |
07-22-2014, 08:22 PM | #10 (permalink) |
Or spend $6 on a set of these: http://www.completeheli.com/fusuno-s...s-fua-003s.htm I installed these on my new Fusuno canopy and so far they work great and a 100 times better than the stock rubber grommets that keep popping out.
XL V2, Soxos 7.1L - Previous: Kraken 580, Nimbus, Protos 380, Kraken 700, Diabolo 700, Oxy 5/2, Logo 600 / 550SX, Protos 700, Synergy 516, Velos 880, Gaui X7 / X5, Goblin 380, Blade 120SR/180SR/ mcpx BL/300X/450XL, Align 700X/150/Leap 3D |
07-23-2014, 09:31 AM | #11 (permalink) | |
And +1 for the Fusuno metal grommets, they are they only way to go. Here's another source... http://www.helidirect.com/fusuno-sil...rs-p-28185.hdx
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon) Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi) AMA Member, HCAM Member |
07-23-2014, 10:26 AM | #12 (permalink) | |
After my last crash, I was combing the net for parts and came across them. No one place had all the parts I needed so ended up ordering from all over the place; clubheli.com and ExperienceRC were both good as well. And in case you get a balance connector on your Hyperion battery that doesn't fit any plugs, you can order the correct connector from here: http://www.rc-connectors.com/
07-28-2014, 12:50 AM | #13 (permalink) |
I use the ones from hobbyking or aligns
Vbar Control/DX9-Realflight 7 Align 250 pro DFC, Blade 450x with every blade hopup/lynx upgrades (4sale), Align 500L Dominator, Goblin 380, Goblin 700 Comp |
08-11-2014, 05:23 PM | #14 (permalink) |
I bought grommets from MicroHeli. Found them on their webshop while grabbing some spares for my mCPX BL. Their prices are a bit high but their shipments are the fastest and cheapest I've ever experienced on International shipments, which definitely weighs up for the price differences.
Last time I ordered parts from MicroHeli I had them at my door 3 work days later. That's pretty darn good considering I'm living in Norway and MH in Asia. |
