Old 11-06-2011, 10:46 AM   #21 (permalink)
Originally Posted by A.Delaney View Post
What packs are you running with? I have some Lightning Power 6s 5000's but im worried they may be to big and heavy. My Hyperion 6s 5000's are much smaller and lighter. Although the Hyperions are 25c compared to the 40c of the lightning powers. Im anxious to see how it balances out with the 800 boom and blades. Also are you going to run the stock tail blades?
I have new Turnigy & Zippy 40c 5000 and 4000 packs and Gens Ace 25c 4000 packs. I'll see if the 4000's balance and use them if they do.
I have stock, KBDD and Edge 115's to try out. I'll start with the 115's just because they are the biggest.
Tom
litespeed is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 01:36 PM   #22 (permalink)
I was thinking about buying 115's myself. Im wondering if they will clear with Edge 813's. I guess I'll find out.
Trex 700N, Trex 450PRO
"Why buy one when you can buy two for twice the price"
A.Delaney is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 02:32 PM   #23 (permalink)
Edge 813's and 115's have been reported to colide using the stock frame.
terrabit is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 04:04 PM   #24 (permalink)
Well that shoots that idea then.
Old 11-06-2011, 04:44 PM   #25 (permalink)
Yeah, I hope Edge decides to make a 793mm blade. I can't imagine 110mm or less will suffice on an 800. I'd think 120mm would be about right.
Old 11-10-2011, 12:02 PM   #26 (permalink)
Well I started taking apart my 700 last night. I got most of everything I need off it. I'm wondering if I should look into the third bearing block upgrade since I'm swinging 800mm blades with this frame. I'm sure it wouldn't be a bad idea.
Old 11-10-2011, 06:29 PM   #27 (permalink)
Third bearing block is a great upgrade. also as far as tails go, I am running 800mm align mains and Edge 115's, no problems at all. I did not go with edge 813's due to there weight.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 11-10-2011, 07:20 PM   #28 (permalink)
For the 3rd bearing block. Its just the same part number as the other two align blocks right? Then I need the CHP main shaft extension pin. Or would it be better to get the KDE 3rd bearing upgrade kit. As long as it fits the CHP DL frames.
Old 11-10-2011, 07:24 PM   #29 (permalink)
Not sure, I used the KDE 3rd block. It came with the MS extension.
GAUI X5 / X7 *
Old 11-10-2011, 07:36 PM   #30 (permalink)
Ok thanks Dave. I ordered the 11t pinion and some other parts from you for this build. Im still thinking about the motor. I was reading some of your other posts about your 800. Did you end up testing a few different motors? Any conclusion?
Old 11-10-2011, 07:46 PM   #31 (permalink)
I cant seem to find the dimensions on the KDE 3rd bearing block. Im looking for the center to center distance of the mounting screws. Since the CHP DL frames are predrilled for a 3rd bearing block. I would like to make sure the distance is the same on the KDE as the factory Align bearing blocks.
Old 11-10-2011, 08:11 PM   #32 (permalink)
erm the kde blocks fit in the align blocks holes so they would have to be the same
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 11-10-2011, 08:16 PM   #33 (permalink)
Ok, I was just wondering because the stock 700E frame is not predrilled for a 3rd bearing block from Align. The KDE upgrade comes with a template to drill the holes in the frames. However the DL frames are already drilled. I just wanted to make sure it was the same.
Old 11-10-2011, 09:20 PM   #34 (permalink)
I used the KDE block on my DL. Put it on top where it shows. 8^)
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 11-10-2011, 09:24 PM   #35 (permalink)
I thought the 700E frames have been shipping lately with pre-drilled holes for the 3rd block?
GAUI X5 / X7 *
Old 11-10-2011, 09:54 PM   #36 (permalink)
Yes they are, mine is. Purchased early September.
rc_dude is offline        Reply With Quote Quick reply to this message
Old 11-11-2011, 03:35 AM   #37 (permalink)
I have one of the first 700E kits that was made. Its a few years old.
Old 11-11-2011, 04:43 AM   #38 (permalink)
I do too. Mine was actually pre ordered before the stateside release. Got my kit 3 days after they hit the states. So mine has the shorter rails and no 3rd block holes. but I installed the KDE block and it took all but 15 minutes. the template was simple to use. Holes were easy to drill. you wont be disappointed. KDE did a wonderful job on these.
GAUI X5 / X7 *
Old 11-11-2011, 05:39 PM   #39 (permalink)
Ok, thanks guys. Pictures to come soon.
Old 11-11-2011, 07:18 PM   #40 (permalink)
I can't wait! You're doing exactly what I want to do!
I just need to finish this term at school before I have money to fund my project.. I did order my servos already though!
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf
Align 600EFL PRO, DFC, 3GX, KDE
Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s
Thunder Power 65C LiPo & JR 12X
350Z_Al is offline        Reply With Quote Quick reply to this message
