Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 02-07-2016, 01:54 PM   #21 (permalink)
Very nice, looks,good in the air.
waxman is offline        Reply With Quote Quick reply to this message
Old 02-16-2016, 01:30 AM   #22 (permalink)
After about 20 flights with my TDR2:
1.) Removed 8->6mm reduction bush from pinion and replaced shaft on my Xera 4530 with 8mm shaft. So i have now ideal clearance between pinion and motor body. Removed spring washer from motor ... it seems that motor is now little quieter. After pinion bush removal i found that 20t pinion is hollowed.
2.) Carbon tail boom moved after every flight little forward. So i sanded tail boom clamps and now tail boom stays in place.
3.) I got used to TDR2 profile and i like my current design much ... so i will keep it as is for now (although i ordered neon red window and tail fin decals).
4.) Replaced Radix 110 with NHP Razor 120. Tail on TDR2 works different than on TDR1. I dont know if this is caused by mechanics or by NEO. Tail stops with Radix 110 was great, tail hold position in pitch pumps and cyclic maneuvers, but lacks authority in pirouettes. With NHP Razor 120 authority in pirouettes is much better, but i need to reduce gain.
5.) In overall i like TDR2 much more than TDR1 .
swalko is offline        Reply With Quote Quick reply to this message
Old 02-24-2016, 01:13 PM   #23 (permalink)
And i forgot to mention one important detail ... i use standard (non programmable) BLS352 servos on cyclic with ball link in outer hole on blade holder arm. NEO have longer servo travels, so with BLS352 and disabled geometry correction i get more travel than TDR2 mechanics allow. With value 100 i have 15.5 degree on collective. 8 degrees on cyclic with value 95, cyclic ring on 90.
Old 02-24-2016, 10:39 PM   #24 (permalink)
Where do you disable geometry correction on the Neo? My understanding and according to Mikado's feature list, this is not possible on the Neo unlike the older VBar
VControl
Old hand at Planks
Peter
Old 02-24-2016, 11:44 PM   #25 (permalink)
It is possible now only thru preconfigured setup file.
From german version of VBar NEO building tips page http://vstabi.info/de/node/2059 download this file http://www.vstabi.info/sites/default...DR_2_Setup.zip .
If someone is interested i may upload my setup.
Dont download Robert Sixt setup from VStabi forum, because there is geometry correction enabled ... i we done 3 full setups (first without geometry correction, second with Roberts setup and finally one with linked setup file) until i had right one.
Old 02-25-2016, 01:04 AM   #26 (permalink)
Thks will be using VBC and I see there is a macrocell setup version for it.
VControl
Old hand at Planks
Peter
Old 02-25-2016, 01:12 AM   #27 (permalink)
I think that macrocell is for retracts only.
Btw this week i received caddy and missing retracts parts .
Old 02-25-2016, 01:36 AM   #28 (permalink)
Hi,
in a few days a new firmware for Neo will come out. Then you have a setup parameter for the geometry correction.
The Macrocell is only for the retracts.
Stephan
Fingolf is offline        Reply With Quote Quick reply to this message
Old 02-25-2016, 01:48 AM   #29 (permalink)
Great!
Old 02-25-2016, 01:49 AM   #30 (permalink)
Google translate makes a hash of that page! So load setup file via pc on to Neo then bind with VBC and check settings.
VControl
Old hand at Planks
Peter
Old 02-25-2016, 04:39 AM   #31 (permalink)
Nice review, thanks.
Mezelluf is offline        Reply With Quote Quick reply to this message
Old 02-25-2016, 05:08 AM   #32 (permalink)
I will talk with Rainer for the translation.
Stephan
Old 02-25-2016, 10:39 PM   #33 (permalink)
Now in English after I asked on the Vstabi forum, thanks to all for that as well. Now it makes sense.
VControl
Old hand at Planks
Peter
Old 03-02-2016, 06:34 PM   #34 (permalink)
Just had an email from Mikado ref Neo update:
"Geometry correction can be disabled"
is one feature of the latest firmware
LOGO 500SE & 600SE & 600SX
Synergy E7 -
N7 - N5C
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II
Alun
CyprusFlyer is offline        Reply With Quote Quick reply to this message
Old 03-09-2016, 02:19 AM   #35 (permalink)
Color scheme update.
ID:	639880   Click image for larger version
ID:	639881   Click image for larger version
Old 03-09-2016, 08:02 AM   #36 (permalink)
CHC Benefactor
Love your new colour scheme!
Raptorapture is online now        Reply With Quote Quick reply to this message
Old 03-09-2016, 08:33 AM   #37 (permalink)
Old 03-09-2016, 11:07 AM   #38 (permalink)
... but I want mine!
Is that a black FG canopy?
If so is the tail black or are they both CF ?
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is online now        Reply With Quote Quick reply to this message
Old 03-09-2016, 11:27 AM   #39 (permalink)
Black FG canopy and CF tailboom.
Old 03-31-2016, 12:41 PM   #40 (permalink)
1420 and 1980rpms:
Lietanie 13.3.2016 - Henseleit TDR 2 - 1 (5 min 19 sec)
Lietanie 13.3.2016 - Henseleit TDR 2 - 2 (5 min 35 sec)
