Belt CP E-Sky Belt CP
Old 03-16-2012, 12:30 AM   #1 (permalink)
Default esky ET6I transmitter issue
Hey folks,
Just wondering if anyone else has had issues with the TX that comes with the Belt cp.
Just about to launch into a flight and the batteries died, so went home and got a new set for the TX, and it wont register or connect to the Chopper.
When i turn the TX on the green lights go on, but the red light at the bottom left won't.
any known fixes?
Yeah yeah I know i should get a DX6 or something but in New Zealand they are about $700, Which is way beyond my skill level to appreciate for the cost.
Done a search of the site and the web but not found anything that helps.
Please i need my Fix!
Dan
Kiwidan is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 03:38 AM   #2 (permalink)
I had the issue once, a quick re-bind solved the problem for me.
Don't know how to do it off the top of my head, but if no one else can tell you I'll have a look at the manual when I've finished work.
comatosed is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 04:43 AM   #3 (permalink)
Thanks heaps will look up how to re bind and do that
Old 03-16-2012, 10:50 AM   #4 (permalink)
Any joy?
Old 03-16-2012, 02:39 PM   #5 (permalink)
HI Na
tried it different ways but no joy. IT seems that the TX is not transmitting, will take it back to the shop I brought it from, I expected it to last longer than the heli.
Old 03-17-2012, 07:11 AM   #6 (permalink)
Have you caught the trainer switch? Top right shoulder of the Tx, behind the gain adjuster.
Old 03-17-2012, 03:38 PM   #7 (permalink)
Have tried pretty much every combination of switches and no joy. The red led on the bottom left is no longer flashing which makes me think that the transmitter had brought the farm
Old 03-21-2012, 10:02 PM   #8 (permalink)
Caved and brought a DX6i the shop gave me a great deal on one setting as it was going to take a fair while to get the cheap Esky TX fixed.
Old 03-22-2012, 04:54 AM   #9 (permalink)
Congrats Dan,
Totally glitch free,fully prgrammable and reliable - you'll love it!
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head
T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG
E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades
TRex600N, Kasama Head, OS50SX
copterboy is offline        Reply With Quote Quick reply to this message
Old 03-22-2012, 05:52 AM   #10 (permalink)
Originally Posted by copterboy View Post
Congrats Dan,
Yep, upgrading to a programmable Tx is the single greatest thing you can do to increase the flyability of a CP. Once you get your curves set up how you like them you'll wonder how you ever got in the air with the stock unit.
Trex 450 Pro V2
Trex 450 Sport V2
Esky Belt CPX
Blade mCP X
GreyEyes is offline        Reply With Quote Quick reply to this message
Old 03-23-2012, 12:33 AM   #11 (permalink)
Guys guys guys i wish i could say that was true, unfortunately the Gyro is not talking to the RX and i there fore have no tail rotor movement in the servo at all
is this normal? i followed several intructionals in how to set up the new RX,
things i have tired to do to figure out what is wrong,
1.disconnect the tail servo from the gyro and put into the rudder slot (it works then)
2. move the connectors to different slots.
every thing else is working ( i think ) i have set the expo rates and the swash is working fine, the throttle is working fine.
Im lost folks
Old 03-23-2012, 01:14 AM   #12 (permalink)
Ok, what you have done is to troubleshoot it to the gyro as being the issue.
Before we call the gyro bad, first let's look at it a little closer.
Check very carefully how it is connected to the reciever and how the servo is connected to the gyro. Make sure you do not have a connector plugged in upside down.
This happens all the time.
I'm assuming the gyro worked with the old tx?
If it did, then it should work with the dx. You can double check this by temporarily swapping back to the old radio and seeing if it still works.
This will help us to help you.
Plus, it helps us a lot if you can post some pictures of how you have it all hooked up.
It's not uncommon for the stock Esky gyro to fail. If it did, then coult your lucky stars it happened now and not in the air.
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X, Mosquito, X/A Hexa/WKM/UHF/FPV, F330 Flame Wheel,
PenguinV2/UHF/FPV, 757-3 ex Ranger/uhf/Ruby/fpv, QAV250 w/Vector , Ritewing Drak w/Vector Crossfire and fpv.
Tomstoy2 is offline        Reply With Quote Quick reply to this message
Old 03-23-2012, 02:37 AM   #13 (permalink)
ok going to try to post some images
not sure if this will work.
yes the Gyro worked with the old tx, BUT the old TX died hence the new DX6i, so no testing on the old TX. The lights on the Gyro do go, ------------------------ WAIT HOLD ON A MIN-------------------------------------------------
OK YOU ARE A LEDGEND!!!!
Just ran back into the room and flipped the tail servo going into the gyro....... AND (servo sounds) hell yes thanks man!!! made my night!!
HELIFREAKERS you all rock.
Old 03-23-2012, 02:51 AM   #14 (permalink)
You hear that Jerry? I'm a LEGEND, and NOT just in my own mind.
You're welcome, man. Been tripped up a few time by some of the simplest stuff,,,,
Old 03-23-2012, 07:57 AM   #15 (permalink)
That's because when I was in New Zealand for over a year I put in a good word for you, Tom. The whole country being a few million of sheep and few thousand of people, the word spreads, you know
Jerry
jperkosk is offline        Reply With Quote Quick reply to this message
Old 03-23-2012, 12:07 PM   #16 (permalink)
Knowing you as I do, my good friend, I'm pretty sure the 'good word' wasn't what you were spreading over there.
Old 03-23-2012, 12:13 PM   #17 (permalink)
Well, that's something else I have never done!
For the record, neither have I EVER put every single servo plug upside down into an Rx, then checked the orientations and come to tthe conclusion that the brand new AR8000 Rx was dead and a
...and re-checked a 2nd and 3rd time and still not found a problem (after all, I've been doing this for a few years now, how could I possibly get it wrong).....before a technical support line (at about £2 per minute) pointed out that I hadn't actually TRIED it the other way.....
....nope...never happened to me....
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s
Luke Warmwater is offline        Reply With Quote Quick reply to this message
Old 03-23-2012, 12:15 PM   #18 (permalink)
...and it definitely wasn't only two months ago that I didn't do this....
Old 03-23-2012, 12:15 PM   #19 (permalink)
The "good word" might've been indeed an overstatement, but what counts are the results, right? You have become a legend there
Jerry
Old 03-23-2012, 12:17 PM   #20 (permalink)
You hear that Jerry? I'm a LEG END, and NOT just in my own mind.
What.....like typing mistakes where someone misses a "space" out?
