Old 08-02-2013, 09:14 PM   #61 (permalink)
Originally Posted by krdavis28 View Post
Guys, a question for you experts. I ordered the Tunigy 306's and the 306hv for the tail, and I already received the YEP 40A esc. Can I run these at 5.5v ?
Thanks,
Randy
the 306 is rated at 6v max. The 306hv is rated at 7.2 max so you would be fine running at 5.5v
nartac is offline        Reply With Quote Quick reply to this message
Old 08-02-2013, 09:56 PM   #62 (permalink)
Thanks Nartac. I thought that was the case but wasn't sure. Cant wait to get this Frankenstien with a 300x tail in the air. Hope it flies as good as it will look.
krdavis28 is offline        Reply With Quote Quick reply to this message
Old 08-06-2013, 11:53 AM   #63 (permalink)
I'm using TGY-113mg cyclics, and I don't see those in your table. I also don't see those in the list on the BeastX website. If I find a combination of settings that work, do you want them posted here, or does someone know what pulse width hz settings to use for those servos?
FP - Blade mCX2/mSR {x2}/Nano QX{x2}/120SR - Syma s107g - Xieda 9998{x2}
CP - Blade Nano CPx/mCPx(v2+BL {x2})/CP Pro 2(Scale Build in Progress)/300x/300xSS(Benched)
TX - Spektrum DX6i/DX8
jcmo is offline        Reply With Quote Quick reply to this message
Old 08-06-2013, 07:55 PM   #64 (permalink)
Default Servos and MH Carbon Frame
Got a MH carbon/alum frame. I just got my TGY306HV servos and you have to mod them to make them fit. Its pretty simple, just requires a little cutting of the servo flange at the center hole. Aside from that they fit good and look awesome on the bird. Put the TGY306G on the tail, cant wait to get this thing back together and in the air.
Old 08-26-2013, 02:58 AM   #65 (permalink)
Default servo travel?
Hi guys!
I've installed a MKS DS95i as tail servo in my 300X, and that made my tail 100% perfect! Love it!
Now I've also installed the TGY306G as tail servo in my T-Rex 450 and 450X. These seem to be a clone of the DS95i.
There's one thing though that puzzles me with both these servos: The travel is very limited! On my 300X I can barely have enough throw with the ball far out on the horn and the inner hole on the pitch lever arm. But on my 450X even that is not enough.
See video:
[ame]http://youtu.be/RDyG80ArQfk[/ame]
My settings are:
-tail servo 560 Hz
-tail servo pulse length 1520 us (EDIT: It's set at 760 us, sorry my bad)
I tried with 150% travel on my DX8 but it did not seem to help.
Any ideas? I mean, some of you guys also use these for cyclics - how on earth do you get enough travel then???
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 08-26-2013, 05:00 AM   #66 (permalink)
Originally Posted by SHYguy View Post
H
My settings are:
-tail servo 560 Hz
-tail servo pulse lenght 1520 us
The pulse width should be 760us on that servo.
http://www.mksservosusa.com/product.php?productid=6
( Goblin 500, Blade 300x, AXE 100 CP ) x 2
kcgraves is offline        Reply With Quote Quick reply to this message
Old 08-26-2013, 05:26 AM   #67 (permalink)
Yes you are correct (center pulse lengt). I also have that setting, just double checked. I just remembered wrong when writing the post.
Any other ideas?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 08-26-2013, 05:45 AM   #68 (permalink)
Any other ideas?
I do that a lot lately.
The radio end points probably are limited by the gyro. If you disconnect the tail rod and then go into the Beastx programming for tail end points will it move further?
Old 08-26-2013, 05:48 AM   #69 (permalink)
Tried that, still very short movement... it was the same with the DS95i.
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 08-26-2013, 07:26 AM   #70 (permalink)
Default Servo summary
My buddy made same mistake. He had set his gyro on his tx to inhibit. We changed the settings by activating the gyro and increased gain to at least 30 ( dx8) and his ds95i has full throw
Old 08-26-2013, 07:35 AM   #71 (permalink)
Gain has effect on throw???
Gyro is activated and set to settings as pr. 300X manual.
Can you please elaborate?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 08-26-2013, 08:27 AM   #72 (permalink)
My settings are:
-tail servo 560 Hz
That's your problem, you should be set to 1520uS (unlike the DS95i)
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 08-26-2013, 12:43 PM   #73 (permalink)
I have the same servo on the tail of my 300 and it is set at 1520 and worked great until I planted my 300 last weekend. Not due to a tail issue but dumb thumbs. Now it is locked up. Do the gears for the MKS fit the TGY ?
Old 08-26-2013, 05:16 PM   #74 (permalink)
That did the trick!
Dare I try that on the MKS DS95i as well or may it ruin it?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 08-26-2013, 05:23 PM   #75 (permalink)
I am uncertain why. My friend has a ds95i on the tail and his servo did the same. He had it at 560/ 760. I then enable tx gyro but it didn't have full throw until we increased the gain to around 25-30
Old 08-26-2013, 05:42 PM   #76 (permalink)
As I see it you must adjust gain while flying. Until you have no wag but solid tail hold.
Whilst you set endpoints on the bench.
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 08-26-2013, 07:16 PM   #77 (permalink)
Ok. I know the MKS95i is a great servo. I have the TGY306g and it has been really good until it locked up because of a hard crash. I have looked at the gears and they LOOK the same as the MKS. Also there are a few people saying that the KSTDS115 clone is also a match for the MKS and the TGY and the gears are the same. I am ordering a set of the replacement gears for the KST, they are only $6. Thought I'd give it a try. Will post the results as soon as I get them in.
Old 08-27-2013, 03:06 AM   #78 (permalink)
I'm thinking that since the center pulse frequency is different it can't be an exact clone.
Also IIRC the specs are a little bit better in favor of the MKS. Had several crashes and they sure are strong as a horse!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 08-27-2013, 10:39 AM   #79 (permalink)
You are absolutely right but it was just weird. He had only tiny throw like yours. I went into bx menu E (end points) and had full throw but not when not in bx setup. For the heck of it, I cranked up the gain and whoa la, it had full throw. I don't know if this is due to tx or what because he has a dx8 and I have a jr 11x. Mine doesn't do that but perhaps I will try inhibiting my gyro or turn it down low and see if it does the same. I have a ds95i on both of my 450 pros as well
Old 08-31-2013, 02:28 PM   #80 (permalink)
Originally Posted by isdal View Post
Anything I missed? Please comment it you have experience with a particular servo and the ar7200bx (working great / not working) or know the beastx setting / frequency.
I use the Hitec 5065MGs on the cyclic and Hitech 5084MG on the tail and they work great with the AR7200BX. I also use them with a normal BeastX on my 450Pro and they're great there too.
jaydekay is offline        Reply With Quote Quick reply to this message
