Old 07-27-2012, 07:34 AM   #1 (permalink)
Default Tarot ZYX/ZYX-S firmware upgrade
I noticed there is a growing amount of pilots here that are now using the Tarot ZYX FBL gyro, welp I've just been informed by our friend unochen there is an upgrade firmware.
Here's what he said:
ZYX firmware upgrade to version 3.50.rar(only use in ZYX)
http://www.kingwjg.com/zyx/zyx%203.50.rar
ZYX-S firmware upgrade to version 3.50.rar(only use in ZYX-S)
http://www.kingwjg.com/zyx/zyx-s%203.50.rar
1.Optimize the heading hold control, eliminate bouncing when spin brake.
2.Optimize the main rotor control, eliminate swing while tic toc.
3.Accelerate the response speed of joystick, so that the helicopter can follow your hands better.
4.Optimize the pirouette compensation to make pirouette flight more stable.
5.Improve the joystick dead band setting to make stick control smoother.
First Flight Attention with 3.50 Version:
1.During first flight, if there are hunting or swing with you helicopter, please decrease the D gain on corresponding axis first.
2.When tail servo is on neutral point, set the tail pitch to be approximately 8°in the direction that compensates the main rotor torque by adjusting the linkage length.
3.If the brake speed of left and right pirouette are different, please adjust the "Deceleration L" or "Deceleration R". The higher parameter value, the break will be faster.
Firmware upgrade instruction
1.Connect the ZYX gyro to PC by ZYX USB adapter,click "Connect ZYX",make sure it succeed.
2.Open the Firmware in ZYX PC software.
3.Keep the PC,USB adapter and ZYX gyro connecting.Power off ZYX gyro,press "SET" button of gyro and power on.
4.The red lamp is flashing,click "Upgrade" button to start upgrade,the ZYX gyro will restart after successful upgrade.
5.Please make sure your gyro is Tarot ZYX,otherwise the gyro will be damaged.The ZYX gyro does not need to be setup again.
http://www.0577mx.com/news_view.asp?clsid=15&id=268
Enjoy
walkera4g3 is offline        Reply With Quote Quick reply to this message
Old 07-27-2012, 07:58 AM   #2 (permalink)
Good find thanks!
youturnjason is offline        Reply With Quote Quick reply to this message
Old 07-27-2012, 09:20 AM   #3 (permalink)
Thanks, I just downloaded the firmware, will do the upgrade tonight
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 08-20-2012, 08:18 AM   #4 (permalink)
Have you guys noticed an improvement with the new firmware?
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote Quick reply to this message
Old 08-20-2012, 08:24 AM   #5 (permalink)
Looking forward to some flight reports after the update.
Sent from my HTC PH39100 using Tapatalk 2
bobtruck is offline        Reply With Quote Quick reply to this message
Old 08-20-2012, 08:29 AM   #6 (permalink)
Reports are in http://www.rcgroups.com/forums/showthread.php?t=1512179
Old 08-30-2012, 06:21 PM   #7 (permalink)
how do I open the file?
Downloaded the 3.5 RAR, and then? It contains a bin-file. The software is asking for some hex-file.
LOGO 500 : Spartan Vortex Nano; Scorpion 4020 1100kV
Quad 250 : Openpilot CC3D
chopstick is offline        Reply With Quote Quick reply to this message
Old 08-30-2012, 07:27 PM   #8 (permalink)
extract the file from the rar into your MyDocuments folder then use the software to upgrade
http://www.rcgroups.com/forums/showp...postcount=4300
Old 08-30-2012, 07:28 PM   #9 (permalink)
Mine asked for a bin file, make sure you are clicking the open button in the bottom right next to upgrade
Old 08-31-2012, 12:11 PM   #10 (permalink)
I upgrded with the software from http://fbl.net.nz/
So now I can start testing the tarot on my sjm180 (250-class)
Old 08-31-2012, 12:59 PM   #11 (permalink)
Thanks for the link to the connection sequence. I tried to upgrade mine last night but it just would not take. I'll try again tonight.
As another thought, has anyone screwed this up and bricked their Tarot?
Old 08-31-2012, 02:00 PM   #12 (permalink)
I suggest you download the file again and try to flash the firmware again. It may have gotten corrupted during the download.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 02:33 AM   #13 (permalink)
Hi,
I just to see a new versión 4.0:
http://www.0577mx.com/news_view.asp?clsid=15&id=273
regards,
Enjoy
gobuntu is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 11:30 AM   #14 (permalink)
Yep. Here's the English version using Google Translate
http://translate.google.com/translat...D15%26id%3D273
Goblin Speed | iKon
Old 03-09-2013, 07:09 AM   #15 (permalink)
Download / download address:
english: ZYX 3 AXIS GYRO 4.0 Software Installation
Simplified: The ZYX 4.0 three-axis gyroscope Software
Traditional: The ZYX 4.0 three-axis gyroscope Software
ZYX 3-axis gyro upgrade are as follows:
1: to enhance the the joystick response speed of the main rotor, the main rotor violence coefficient option to improve the performance of the flight of violence.
2: To improve the stability of the helicopter spin, enhance helicopter hovering stability.
The ZYX-S 3-axis gyro upgrade content as follows:
1: support the double satellite receiver or dual S-BUS receiver (sold separately expansion module: ZYX20.)
2: support fixed speed the (sold expansion module: ZYX20)
3: to enhance the the joystick response speed of the main rotor, the main rotor violence coefficient option to improve the performance of the flight of violence
4: spin stability, improving hover stability.
5: Adjust the signal sequence of the S-BUS receiver instead Futaba default order (If you use the S-BUS
The receiver, in line with the type of debugging software receiver page re-adjust the transmitter channel sequence).
T-Rex 600 Nitro Pro - T-Rex 450 Pro - Prôtos 500 BeastX - Logo 400 Vbar - Compass 6HV - Compass Atom500
http://www.helicanopy.nl
Tribal69 is offline        Reply With Quote Quick reply to this message
Old 03-09-2013, 07:46 AM   #16 (permalink)
Awesome!
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 06-10-2013, 03:45 PM   #17 (permalink)
Still can't update the firmware.
How can I open the firmware with the PC software. There is only an option under "file" to open a .config file. But the firmware is a .bin file. ????
HELP!!!
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote Quick reply to this message
Old 06-10-2013, 04:18 PM   #18 (permalink)
Big "OPEN" button on the right hand side under the "Firmware upgrade" title.
Goblin Speed | iKon
Old 06-10-2013, 04:21 PM   #19 (permalink)
Thanks Dr. M . . .
But I have a different PC-Software.
It is the old one, where it does not show the Tarot unit on the right side.
I just downloaded the 4.o PC-software from Tarot, but it does not really install.
There must be a bug or something. I get a window with about half the programming screen and can't press any buttons.
Do you have by any chance a better 4.0 PC programming software version or link?
Old 06-10-2013, 06:35 PM   #20 (permalink)
Try this
http://fbl.net.nz/
and mucho info here
Sigma, MCX, MSR, BOL, B400
BSR, EXI 450 Pro FBL, mCPX
Align 500ESP FBL
AXN FPV
Daddy is offline        Reply With Quote Quick reply to this message
