Warp 360 Compass Warp 360 Model Helicopter Discussion |
11-04-2014, 08:31 AM | #1 (permalink) |
Governor set up for my warp 360 with CC Edge 50
I would be most grateful for any help with the settings for a governor set up for my Warp, using the castle link.
At the moment i am using fixed end points but want to try Governor mode... never done this set up with the internal governors before. CC Edge 50. Motor is stock 1320kv 8 pole, with 16T pinion. Main gear i now know is 135T which i believe gives an 8.44:1 gear ratio. i am not too sure on what i should use for the head speeds 1,2 & 3. Are there any of the other settings i should use or alter?. Thanks kim.
Spirit Warp 360, Spirit Goblin 500 sport. Spirit Trex550eDFC. BeastX Trex550FBL. Blade 270cfx. Blade180CFX. Nano CPX. BL. neXt Sim Dx9. Dx6G2 |
11-04-2014, 11:11 AM | #2 (permalink) |
I am not sure as far a gov gain goes, I would leave it at stock to start with. Your gear ratio is correct as well as your motor specs. I would recommend that you don't go any lower than about 2650 for your lowest HS on that ESC and whatever the max you can get on Idle2 (should be around 3100 or so) and split the difference for Idle1.
NX4|Tri-Chronos|Chronos|7NT|Specter700 Saje Marvin - Citizen 125 |
11-06-2014, 07:33 PM | #3 (permalink) |
Raz0rSh4rp,
Thanks for your help.. i had hoped someone was using the Gov setup so as to get an idea on the 3x head speeds, i will try to get it sort it later. At the moment i am still using fixed end points and absolutely enjoying the flying of this Warp....... think my 450pro will have to go!!
