mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions |
10-07-2011, 07:45 AM | #442 (permalink) |
Blade Forum Support
That is nice man now that's lifting 10x its Wieght. Have a blessed week and weekn. Isaac
Sent from my DROIDX
Jesus Rep Its all Good,Its all GOD FPV Everything Now GOD BLESS |
10-07-2011, 08:02 AM | #443 (permalink) | |
im curious to your stick position to lift that cam....and pitch changes...etc? would it go higher? Last edited by Cartrixx; 10-07-2011 at 08:09 AM.. Reason: wrong person quoted |
10-07-2011, 08:41 AM | #444 (permalink) | |
Yes, I can go higher, but the climb rate is slow. It's just an experiment. The servos suffer with so much load |
10-07-2011, 04:11 PM | #447 (permalink) | |
On the output of the main motor there is a capacitor apparently identical to the output of the tail motor. I have not measured, but I suppose they have the same capacitive value. |
10-07-2011, 08:46 PM | #448 (permalink) | |
http://www.bonanza.com/listings/AVX-...00pcs/29712953
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Rotormast V-22, Futaba 12Z controle!! Last edited by Stevendavis; 10-08-2011 at 10:21 AM.. |
10-07-2011, 08:53 PM | #449 (permalink) |
This one is one I'm looking at also. It will be easier for me to atach it anyway.
http://www.electronics123.com/s.nl/it.A/id.276/.f
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Rotormast V-22, Futaba 12Z controle!! |
10-08-2011, 01:00 AM | #450 (permalink) | |
by the way - do any of you see a difference in performance after doing the dual mosfet conversion ? |
10-08-2011, 01:04 AM | #451 (permalink) | |
I will probably do LiftBag's dual mosfet conversion when i change the tail motor (if it will be damaged due to the capacitor missing) and not be bothered with soldering the capacitor back. will probably be better when i change to 120sr tail i guess... (see my convers with liftbag) Last edited by omerco; 10-08-2011 at 04:47 AM.. |
10-08-2011, 10:29 AM | #452 (permalink) | |
10-08-2011, 10:33 AM | #453 (permalink) |
Blade Forum Support
I haven't seen any one get it yet. They need to put what kv motor it can run on it and what pinions you can use on it . There is really not that much info on it.
Have a blessed week and weekn Isaac Sent from my DROIDX
10-16-2011, 01:36 AM | #454 (permalink) |
My last and final conversion.
Hpo5 motor is the best. Was called co2s in the vid. My bad. Lov it. [ame]http://www.youtube.com/watch?v=efs0jfeU9NM[/ame] Last edited by Plumbr; 10-16-2011 at 02:50 AM.. |
10-16-2011, 07:08 AM | #455 (permalink) | |
10-16-2011, 07:58 PM | #456 (permalink) | |
Nice video too |
10-17-2011, 06:33 AM | #457 (permalink) | |
Here is the motor. It's the HP05s chose the 9 tooth pinion. http://www.chinesejade.com/walkera43BLMotorEsc.htm Here is the signal converter. Its the $15 one if you live in the states There is no resistor on this converter so it needs to be soldered on the spot on the back of the board. http://thesteve.ca/walkera/ Here is another converter. This one has a resistor installed. So you can solder to the main motor + terminal. It's easier to solder to this point but throttle response isn't as good. http://www.wowhobbies.com/thestevebl...converter.aspx Here is the helimax esc that he is using. http://www.amainhobbies.com/product_...-Brushless-ESC |
10-17-2011, 05:44 PM | #458 (permalink) | |
10-17-2011, 06:52 PM | #459 (permalink) |
Here's some more help if needed.
Thanks goatkeeper and thanks to TNT. I saw his conversion and look what happened!!!! Im adicted!! [ame]http://www.youtube.com/watch?v=PkxJwK_pops&feature=youtube_gdata_player[/ame] Cheers Peter Last edited by Plumbr; 10-18-2011 at 11:02 PM.. |
10-22-2011, 09:15 AM | #460 (permalink) |
That is very cool. I took a slightly different route with my heli setup. I replaced the e-flite power harness with a dual harness with thicker wire. I am running two 300ma 1cell in parallel. My setup used to bog down with the stock harness with the pitch set to 70 or above. Now I have the option of running it with a single cell, or two singles in parallel, and it doesn't bog down even if I only plug in one cell. I currently have my pitch set at 86%.
andy Last edited by andyc; 10-22-2011 at 10:45 PM.. |
