Old 06-11-2008, 11:32 PM   #1 (permalink)
Question 'finger' test on a YS50
Sorry if this is a silly question, but... I've read about putting your finger on the backplate of the engine to gauge the temp, but I'm not entirely sure where to do that on a YS engine. The backplate (assuming I'm thinking of the actual backplate) is very recessed and has a fuel tube in the way (to pressurize the tank), so there is no flat surface area to touch. Do I just touch the thin outer edge of the bottom plate, or the middle of the cylinder wall where there is more surface area to feel?
-David
Trex500 sk360 | Logo400 vbar | Logo500 vbar | logo 600se vbar | Synergy N9 sk360 | E-Aurora vbar | Mini Protos beastX | mcpX
whaleboy is offline        Reply With Quote Quick reply to this message
Old 06-12-2008, 12:09 AM   #2 (permalink)
The "Finger on the backplate" test really doesn't work on the YS engines. The pinch test, and lidtening to the engine is the best way. And a temp Gun...
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote Quick reply to this message
Old 06-12-2008, 12:15 PM   #3 (permalink)
What is the pinch test? And I assume you mean listening to the engine? Since this is my first nitro, The only way I could tell its not tuned right by ear is if its sputtering. I do have a little IR thermometer. Where should I take a reading and what temp should it be? For break-in as well as after...
-David
Old 06-12-2008, 04:49 PM   #4 (permalink)
The pinch test is for setting the low end needle. After the engine warms up, preferably after landing after a flight, leave the engine idling and pinch the fuel line shut about 1 inch from where it enters the carburetor. The engine should speed up after 2 seconds and then die. If it dies right away, your low end needle is too lean. If it takes much longer than 2 seconds before it starts speeding up, the low end needle is too rich. Having the engine up to operating temperature when you do this is imperative.
HeliFreak Support
Graupner MZ-32
Old 06-15-2008, 02:33 PM   #5 (permalink)
I ran a couple tanks yesterday. I have a feeling I was running on the lean side, as I had plenty of power, no bogging at all... If I was running on the rich side, should I have had a bit of bogging? This thing had much more power than my 500 for sure (500 is running a 12t pinion though...). I also timed the second flight and landed at 7 min... tank was still half full. My temp gun was not working that well as it was showing temps of 110F or so a couple min after landing... it was definitely hotter than that at the time of reading... not sure what I was doing wrong. Anyway, the engine felt good. I had a guy at the field helping me out, and he adjusted the main needle to about 1 and 1/3 out and after seeing me fly said it was rich and was fine for breakin. I still think it wasn't that rich, but I have 0 nitro experience, and he did (although he had never run a YS before, but was thinking of getting one).
Anyway... After the second and third flights (1/2 tank each), I had fuel leaking all over the place. I checked and tightened some motor screws, but it looked like it was coming out of the carb. Both of those last two flights the engine died after landing, and I probably forgot to clamp the fuel line, so the question is... If I do forget to clamp the line to the engine, will the tank pressure force fuel out of the carb and all over the place? I was thinking I had a leaky engine, but after taking it out last night, I realized that it was probably not a leak at all and just the tank pressure making the mess. I need to get in the habit of clamping that line right away.
-David
Old 06-15-2008, 02:57 PM   #6 (permalink)
-David
oh yeah, clamp and pull the line off the one way valve as soon as you land...
WayneBrown is offline        Reply With Quote Quick reply to this message
Old 06-15-2008, 09:12 PM   #7 (permalink)
Live and learn. . Is there an easier way to relieve the pressure rather than reaching under the heli (quite awkward) and pulling the line? I figure a T connector on that line with a simple clamp, but the only T connectors I see have fuel filters in them. Can someone point me to just a plain T connector without the filter?
-David
Old 06-15-2008, 09:20 PM   #8 (permalink)
-David
I don't want to see or hear of you doing that. It adds a failure point on a pressurized system where you don't want or need one.
Simply reaching under the heli is best.
There really is a reason YS states a specific length of tubing from the pressure fitting to the check valve, and is the reason the engine comes with one pre-cut in the box.
Please keep this as simple as you can, even if it's awkward.
Old 06-15-2008, 09:52 PM   #9 (permalink)
I guess I could disconnect the line at the top of the tank rather then at the check valve, which is completely underneath the Heli...
-David
Old 06-16-2008, 05:29 PM   #10 (permalink)
-David
thats what i do.
heliadict1212 is offline        Reply With Quote Quick reply to this message
Old 06-30-2008, 03:49 AM   #11 (permalink)
For this 2 second rule... I've got it to where if I clamp the line, it will idle normal for about 2 seconds, then speed up and eventually die. Once it starts speeding up, it can take 5 or so seconds to die. Is this ok, as long as the normal idle is around 2 seconds?
-David
