Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
01-01-2013, 07:27 PM | #81 (permalink) |
I honestly don't think it matters. If I can ever get my hands on some more a TDR comes with couple of pieces of a teflon-like heat shrink that is slick not grippy like regular heat shrink. It shrinks down super tight to the tail rotor pushrod and that part is what slides through the pushrod guides on a TDR. It would work perfect on a L500-L800 tail rotor push rod and maybe even the L400 I forget the tail rotor pushrod diameter on it.
That is what I need on mine. It works fine with two supports and there is no friction, but the TDR is like buuuuuutter! Norman Ross Jr.
Norman Ross Jr. Mikado USA -- Insane Canopy -- Scorpion Motors |
01-01-2013, 10:21 PM | #82 (permalink) |
I used that on my Logo 500. Thanks for reminding me - I'll add that to the 700 as well.
Mathias Lynx Oxy 3 | JR XG14 |
01-01-2013, 11:02 PM | #83 (permalink) |
any idea what it is ? link ?
I'd like some also. My 800 rod is partially sanded down and is a bit smaller in diameter after 60 flights Martin
Logo XXtreme 800 8917 / 256HV VBC Logo XXtreme 700 on 14s 8917 / 256HV VBC NEO Logo XXtreme 770 14s 8917/9188 VBC Logo 600 8917/ 9188 4035-500 VBC NEO |
01-01-2013, 11:30 PM | #84 (permalink) | |
Synergy helis come with something like that: http://www.fblrotors.com/Tail-Push-R...eve_p_158.html |
01-01-2013, 11:33 PM | #85 (permalink) |
That looks like the stuff Panz posted...
01-02-2013, 04:05 AM | #86 (permalink) | |
01-02-2013, 08:40 AM | #87 (permalink) | |
01-02-2013, 06:46 PM | #88 (permalink) | |
As I promised, here are some details. It does fit. Actually it fits perfect - maybe even a little too perfect, as the L700X filled the whole thing with no room to spare. If you decide to get one - let's just hope there's no big production tolerances. I don't believe so, though. That being said, the quality is excellent - really top notch. The outer fabric seems very solid, while as the inner padding is pretty soft. Nice design too.
01-02-2013, 07:00 PM | #89 (permalink) |
Thanks, Mathias. Nice to know it fits.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2 |
01-07-2013, 04:33 PM | #90 (permalink) |
Cool like the bag indeed!!!
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
01-20-2013, 05:30 PM | #91 (permalink) |
Why does the manual show female bullet connectors for the motor side of the ESC motor connections? I assume this is an error and male bullets go on the motor side as usual?
01-20-2013, 06:01 PM | #92 (permalink) |
I'm with you. The male side of the connectors traditionally go on the motor side. All ours are set-up that way. I guess it's and error, although since it ultimately doesn't matter, I guess it's not "technically" incorrect But certainly not the standard.
(-: Dave |
01-21-2013, 07:25 AM | #93 (permalink) |
Thanks Dave. I just wanted to make sure there was no reason Mikado showed it that way.
01-26-2013, 08:59 AM | #94 (permalink) | ||
I just used the 12 mm version on my new Rush and it worked great. Rick
Helifreak, the place to be! Oxy5 w/Brain2, Rush 750 w/VBAR,Logo 400SE, 600SE w/NEOs, TREX 450SE, 500, 600, Blade mCPX,130X, 180CFX, Nano QX, Convergence VTOL, MiniProtos w/BD3SX My products, used by top pilots worldwide, like you! http://rdlohr.com |
02-07-2013, 07:55 AM | #95 (permalink) |
I have been using Rick's tools on all my 7 helis with perfect results and could not have been happier. Just follow the instructions and you are set to go.
_____________ |
05-20-2013, 06:24 PM | #96 (permalink) | |
The new leveler features a clip-on piece, which makes the leveler a lot more rigid compared to the previous design. See attached pictures. Thank you, Rick! Best regards,
05-20-2013, 06:33 PM | #97 (permalink) | |
People have been happy with the original design once they realize how it used so I haven't even advertised that one. Thanks for posting. Rick
