Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 02-09-2013, 10:01 AM   #1 (permalink)
Default What did you do to your BL NANO Today?
Since the regular nano forum has this thread, why not for the bl nano????
I got mine back from NCCraig yesterday and flew it for the first time this morning! Its AWESOME!!! I have the Mild kit with a extended solid boom with upgraded wires and she flies awesome!! I even flew it with one of my bad batteries andshe still flew awesome! THanks NCCRaig!
-Jason
gdawgs56 is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 11:10 AM   #2 (permalink)
I use it to learn to fly inverted. I can crash it over and over no problem.
Fooferdoggie is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 11:30 AM   #3 (permalink)
i finely got a full front flip in in the house with my wild bl nano
super bad is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 12:09 PM   #4 (permalink)
I bounced it off the walls a dozen or so times trying to learn how to fly CP. Slow going but making progress!
450X, 350 QX (GoPro H3B), 130X, Nano CP X, Nano QX, Hubsan X4, Proto X Nano
Spektrum DX7s
Phoenix Sim
Aerial pics at http://foosyou.imgur.com
FoosYou is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 12:28 PM   #5 (permalink)
Just got my main board back from NCcraig this morning... put it back together and tried it out... awesome to have the little thing in the air again
Meekrakkin is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 02:43 PM   #6 (permalink)
Yeah I love this little guy. Sooo durable. Nccraig did a great job with the conversion.
Old 02-09-2013, 08:06 PM   #7 (permalink)
Epic crash coming out of a high speed loop directly into a fence! It was awesome! Now got to get it binding again.
_________________________________
MSRX, 130X, DBL Nano CPX, 450X, T-Rex 500 Pro DFC, DX9
lespaulrob is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 09:21 PM   #8 (permalink)
6 awesome flights today! Ran into my knuckles on the last flight! Ouch but no blood=no harm
Old 02-11-2013, 11:21 PM   #9 (permalink)
Flew two packs and gave up until my 35C EFlites arrive. So much bog and TBO
nicholask1993 is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 04:54 PM   #10 (permalink)
Default Re: What did you do to your BL NANO Today?
Soldered battery connector direct to BL ESC using 20awg wire and took it for a quick test. Wow! Made a very large difference, bogging is non-existant! Too bad it's very windy and yard is flooded or I would've kept flying.
Sent from my DROID RAZR using Tapatalk 2
I'm not totally useless, I can be used as a bad example....
bswett is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 05:04 PM   #11 (permalink)
Originally Posted by bswett View Post
Soldered direct to BL ESC and took it for a quick test. Wow! Made a very large difference, bogging is non-existant! Too bad it's very windy and yard is flooded or I would've kept flying.
what gauge wires did you use?
Old 02-12-2013, 05:21 PM   #12 (permalink)
I did the same thing last night...made a HUGE difference (I put up a thread about it).
I used 22 gauge, but that is pretty thick. I would have gone smaller, but I had it laying around so I used it
mixfisto is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 05:41 PM   #13 (permalink)
It was your post that inspired me to do it!
I only used 20awg wire though.
Old 02-12-2013, 08:21 PM   #14 (permalink)
I tried the head kit O-ring mod out tonight. Seems a lot stiffer but I'll give it a chance on a few more flights.Might just need a little more time to get used to it.Certainly different flight caracteristics.
Gasguy is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 10:10 PM   #15 (permalink)
Servo wore disconnected from board. Removed servo and resoldered loose wire. Reassembled and now the left servo is binding against the motor unless I have it super loose again. Add that to the major bogging and TBO that I'm still getting with my new broken in 35C EFlites and I'm tempted to go back to brushed...
Old 02-12-2013, 10:19 PM   #16 (permalink)
My MILD NANO developed a little tail wag and kick today after a blade strike against a brick wall. So i took the feathering shaft out and sure enough its bent, so off to the LHS tomorrow to grab a new one and i will be in the air again tomorrow night
Old 02-13-2013, 01:21 PM   #17 (permalink)
Try straightening it out yourself. It doesn't have to be 100%. I did mine and it worked fine. You still might want a set to keep as a backup but there's no need to spend $6-$7 each time one is bent.
kingmeow is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 05:18 PM   #18 (permalink)
Ok I'll try. I already bought a new one and am going to install it soon.
Old 02-23-2013, 12:01 AM   #19 (permalink)
Got frustrated after replacing the main shaft helped a little bit with the bogging and them introduces the problem of a wandering tail and TBO when just hovering with no rudder input.
Old 02-25-2013, 08:05 AM   #20 (permalink)
formerly koi-fish
Replaced the frame on my newly bought "wild" pjacq nano. Thing went together easy-peasy. Flew it around the bedroom some afterward, the cats scattered under the bed and the wife told me she'd better hide her toes. . Nearly hit the ceiling with it on first spoolup.
Told her I'd fly it outside from now on and use the stocker inside.
/ 180cfx, 300x, X3,X4-II, Protos 380, Chase 360, x5, Logo 480, Gob 380, Gob 500, Gob 570, Warp 360, 450x, forza 450/450ex, T-Rex 600 Dom, Logo 600, DX9, 1973 Ford f100, Traxxas Summit/Bronco/Bandit/X-Maxx
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is offline        Reply With Quote Quick reply to this message
