Old 12-20-2012, 09:43 AM   #1 (permalink)
Default Programming the Hacker X-70 SB Pro
Just purchased the Logo 500 and need some assistance in programming of the ESC...or is there a thread associated with this issue......
Gttahoe is offline        Reply With Quote Quick reply to this message
Old 12-20-2012, 03:39 PM   #2 (permalink)
One way to do this is with the usb interface. You can downlad the needed software on the hacker website.
/ good luck
Kurt
We don't stop playing because we grow old; We grow old because we stop playing!
LOGO700(2) - LOGO690SX - 700XXTREME - GOBLIN380 KSE - VBARCTRL
galensk is offline        Reply With Quote Quick reply to this message
Old 12-20-2012, 03:48 PM   #3 (permalink)
How do I connect the ESC to the USB. And which version of the software is needed.
Tried to connect, but the software did not recognised the ESC.
Do I need some special protocol or so?
Cannot find it in the manual.
LOGO 500 : Spartan Vortex Nano; Scorpion 4020 1100kV
Quad 250 : Openpilot CC3D
chopstick is offline        Reply With Quote Quick reply to this message
Old 12-20-2012, 06:22 PM   #4 (permalink)
The hacker comes pre-programmed for the logo 500 if its part of the super combo.
Logo 500 SE
Mini Vbar 5.3 Pro/Savox/690SX swash
Kontronik 100LV/Scorpion 4025-1100
Edge 603/92 ceramic lightning bearings
Duramax11 is offline        Reply With Quote Quick reply to this message
Old 12-21-2012, 12:48 AM   #5 (permalink)
Don't try to program the X-70 it comes pre-programmed. It's a really simple speed controller with no fancy governors to set or anything like that. Just plug it all in and set your throttle curves.
I tried to program my one once to lower the soft start time and it's really confusing. I ended up accidently switching from heli mode to airplane mode (nothing to tell you what mode is what etc..) and striped half the gears off my Logo 400's main gear the next time I tried to fly it.
Bullfrog98 is offline        Reply With Quote Quick reply to this message
Old 12-21-2012, 07:09 AM   #6 (permalink)
Then what's the USB-link good for?
Old 12-21-2012, 08:46 AM   #7 (permalink)
Great that's what I needed t hear, thanks good news....All that's left is trying to install the Savox servo(rudder) cannot get it to fit....
Old 12-21-2012, 03:08 PM   #8 (permalink)
in the combo kit it comes pre programed in gov mode.
Greg
MSH USA Heli Flight Team
Mikado V Team
Lynx
el guapo is offline        Reply With Quote Quick reply to this message
Old 12-21-2012, 04:42 PM   #9 (permalink)
You might not need extra software or settings, however if you like to use the vbar electric governor with your hacker esc you need to download and put the rigth firmware into the esc.
http://www.hacker-motor.com/en/downloads/index.html
I use the hacker esc which was in the 500 super combo in my logo 400 and miniV bar. it works very nice and on top you can use autoratation bailout mode through the vbar governor. at least if you're still learning onto autorotation.
/Kurt
Old 12-28-2012, 06:46 AM   #10 (permalink)
ok Thanks.
We will fly it without V-bar, so we don't need the USB-link.
Old 01-23-2013, 11:47 AM   #11 (permalink)
I'm having a problem with the HS it's low and I cant seem to increase have a Thro curve of 0.0, 35, 60,75, 83, 86.5 and 90...ST -1 = 90% ST - 2 100% with my pitch curve 0 to 100...I want to believe it's the ESC please advise.....
Old 01-23-2013, 12:10 PM   #12 (permalink)
what pinion are you running? if its a 12 tooth( which is what comes in the super combo kit), then yes it will be limited to 1800 to 1900rpm.
a larger pinion is what is needed.... 15 tooth or 16 tooth. but keep in mind that you'd also need a 100A esc to handle the increased current.
Greg
Mikado V Team
Lynx
Old 01-23-2013, 12:15 PM   #13 (permalink)
That's it from a upgrade perspective the pinion and the 100a ESC ?
Old 01-23-2013, 02:18 PM   #14 (permalink)
the kontronik 100LV combined with a 15 tooth pinion would be the most straightforward way to increase performance of the logo500 super combo. the Kontronik has a very nice built in BEC that is compatible with buffer pack. it has a very nice built in governor.
for me... I use a castle 100, with a phase sensor, 15 tooth pinion, Vbar gov, VBAR pro firmware and I use a Life RX pack instead of the BEC. I do not use the buffer pack.. that is the extent of the modifications I made to my super combo. which is still good for 2200 to 2300 RPM. which provides a very nice mix between power and flight time.
Greg
Mikado V Team
Lynx
Old 01-23-2013, 11:58 PM   #15 (permalink)
+1 to that el guapo
