Old 01-02-2014, 07:43 AM   #1 (permalink)
Default OWB locking up
So after my first pinion in the kit was cracked, I ordered another 16t pinion, it worked fine, including the OWB until I started flying...
Now, as soon as the motor starts running, the OWB locks up, and it takes some force to unlock it, but then it works fine...
It doesn't really bother me as I don't plan on doing auto's any time soon, especially with how had they are supposed to be on the mini, but I was thinking it could lead to a bigger problem.
I do have a spare 16t pinion, but I couldn't be bothered to uninstall the current one just for that.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 01-02-2014, 07:49 AM   #2 (permalink)
Aryemis,
I've recently had two stuck 16T pinion/OWBs. These were both purchased late 2013. Must be that MSH had a bad run. I switched to a 15T and it works correctly.
Paul
flyingw is offline        Reply With Quote Quick reply to this message
Old 01-02-2014, 07:50 AM   #3 (permalink)
Wink
You need to add grease and check for any dirt inside it.
dedados is offline        Reply With Quote Quick reply to this message
Old 01-02-2014, 02:21 PM   #4 (permalink)
Hmm well I'd have to take it off the motor to do that, I'll guess I'll wait till I get home to do that.
I'm currently in Tenerife and really enjoying flying here where it's warm
Old 01-02-2014, 06:07 PM   #5 (permalink)
My original cracked after about 50 flights replaced it, that one locked up took it off and a roller fell out now on third one and so far no problems.
keyscrt is offline        Reply With Quote Quick reply to this message
Old 01-03-2014, 03:24 AM   #6 (permalink)
IIRC Corrado himself said no grease on the OWB. The little lubrication it comes with should be sufficient. I coat the motor shaft with a film of oil (smear with fingers) when installing.
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 01-03-2014, 04:01 AM   #7 (permalink)
I never had a problem with OWB locking up, but I had a bits of metal remains from the manufacturing process in my parts bags a couple times. Is it possible you had the same and it got stuck inside your pinion?
Btw, autos are super easy with the Mini Not so much with stock SAB blades, but Edge and Radix make it real fun!
Tom
RCHN#233 | Lynx Heli Innovations Team
Goblin 700
Carbon |
Protos Max | Goblin 570
baui2000 is offline        Reply With Quote Quick reply to this message
Old 01-04-2014, 05:53 PM   #8 (permalink)
Oh well, I just crashed my mini for the first time today, and my pinion is now a perfect bearing
I fell pretty hard while inverted, and my main & tail blades are intact
I was really amazed.
I've broken one of the boom supports, my boom is a bit bent, I destroyed the anti-rotation bracket, one servo arm and my pinion ofc.
I have a tiny nick on the main gear, not a problem though, as it's not somewhere the belt passes over.
Blade grips are OK, just got scraped a bit, but they seem fine, haven't checked the spindle yet, main shaft seems to be fine.
I broke the top part of the stock tail fin, idk how I even did that , I was planning on changing it anyway for an orange lynx tail fin.
My canopy is now reaally ugly, but it has the same shape so it's usable.
All in all I'm amazed at how well it crashed, I'll check it again once I get home, but it doesn't look like a very expensive crash.
Old 01-04-2014, 09:09 PM   #9 (permalink)
whats going on with these pinions? I ordered 3 15t pinions last week. 2 were completely locked up and 1 just blew today on low headspeed pitch pumps after only a handful of flights.
ahunter852 is offline        Reply With Quote Quick reply to this message
Old 01-05-2014, 12:51 AM   #10 (permalink)
It seems like the quality control is on holiday in the Bahamas
Mini Protos, Voodoo 400, Protos 380, Protos Leggero 700 & 700X, Diabolo 700
Chris Nifty is offline        Reply With Quote Quick reply to this message
Old 01-05-2014, 02:55 AM   #11 (permalink)
Pinion that came with my kit, a couple weeks ago, was broken too. I'm waiting on a replacement.
RaptorFuel is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 05:08 PM   #12 (permalink)
Oh well I was wrong, I just never had a pinion that worked properly so I didn't even know how they were supposed to work
Old 01-15-2014, 11:25 AM   #13 (permalink)
MSH will be buying in the OWB's you could buy better quality bearings and fit them - I remember someone saying that they were the same as the Trex 250 OWBs
Mikej is offline        Reply With Quote Quick reply to this message
Old 01-15-2014, 03:02 PM   #14 (permalink)
I run a trex250 OWB in a pinion on my mini.
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 01-15-2014, 06:45 PM   #15 (permalink)
My new 15t is just the opposite. Above 60% throttle, it slips. the heli just sits there with the blades slowly coming to a stop. And yes, I installed it with the correct end up. Going to contact Bill and see what he thinks.
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP Robird, Oxy 2, OXY 3, Oxy 4 All on Dx8G2
AMA 732104
MiataJohn is offline        Reply With Quote Quick reply to this message
Old 01-16-2014, 12:33 AM   #16 (permalink)
I've had one puley in which the owb was upside down, so I had to fit the actual pulley upside down for correct operation. Worked fine.
Old 01-16-2014, 02:17 PM   #17 (permalink)
Well I most certainly don't like the design of these pinions !
My new pinion also locks up both ways under load.
I flew for the first time after my crash today, and it was fine, except after landing, the OWB was stuck every time...
It worked fine when I hovered it at 2500rpm in my garden, but it couldn't handle a real flight, or the 3000rpm I usually fly with.
Old 01-16-2014, 02:32 PM   #18 (permalink)
Default Yikes
Yikes.
Well, hopefully the ones in the 700 will be better.
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready
CrashAddict is offline        Reply With Quote Quick reply to this message
Old 01-16-2014, 03:10 PM   #19 (permalink)
+1. and if not i hope hobbyking also sells a $1,16 upgrade for that part.
GAUI
Old 01-16-2014, 03:19 PM   #20 (permalink)
Well I guess I could get that for my pinion with a dead OWB, no idea how I'll get the original one out or the new one in though.
Also it may be 1.16$ but it's way more in shipping
