Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 11-19-2014, 09:07 PM   #1 (permalink)
Question E7SE Jesus Bolt Play?
I recently noticed that the jesus bolt holding the spur gear (and the OWB sleeve) in place has a little play. What I mean is that if I hold the spur gear (above the main gear) I can rotate the rotor head by a degree or two... I don't remember whether that was always the case...
Underscore is offline        Reply With Quote Quick reply to this message
Old 11-20-2014, 08:15 AM   #2 (permalink)
That's pretty typical. Nothing to worry about. That gear is always under pressure anytime the head is turning so there is no play in flight.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 11-20-2014, 11:13 AM   #3 (permalink)
What Chris said, plus, you don't want it completely tightened up because on the auto-rotation hub you can actually warp it if you tighten that up too much. Over-tightening also puts stress on the bolt which can cause premature failure.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 11-20-2014, 12:07 PM   #4 (permalink)
So the whole torque from the motor is only transferred through that bolt?
Old 11-20-2014, 02:24 PM   #5 (permalink)
Yep, as with every other heli on the market using jesus bolts in the main gear/autohub setup.
Trick is to resist the urge to crank down that bolt and stretch it. These are design to be strong against rotational force, but if you stretch it, it will break.
Old 11-20-2014, 11:09 PM   #6 (permalink)
Just wondering y it is a 3mm, other 700 r using 4mm bolts!
I know it will hold, it is 3mm of steel, but a 4mm will "feel better" :p
No helis!
Jad.
JadAl_87 is offline        Reply With Quote Quick reply to this message
Old 11-24-2014, 04:27 PM   #7 (permalink)
Mine has the same amount of play. I was a little worried about it at the start, but no issues at all.
Logo 400SE - Chase 360
Synergy E7SE - Chronos
JR XG8
Hardsy is offline        Reply With Quote Quick reply to this message
Old 12-03-2014, 03:54 AM   #8 (permalink)
Same here, must be by design
cupracing is offline        Reply With Quote Quick reply to this message
