Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 04-17-2013, 01:53 AM   #1 (permalink)
Default Setting up new MiniTitan V2
This is my first build & set up. The GT5.1 is out of MT325s, setting are all stock 325s settings except for servo adjustments. I set the end point for the tail hitec 5085, centered the cyclic`s (5065s) so the swash is level throughout pitch range after getting as close as I could mechanically. Did a couple test hover`s & something is not right. Thinking of upping the P value to start, but thought I`d ask here first.
[ame]http://youtu.be/R35nVa2b0mI[/ame]
rcnorth is offline        Reply With Quote Quick reply to this message
Old 04-17-2013, 03:49 AM   #2 (permalink)
Its a slow tail wag
What are your P, I and D-sense tail settings?
You could try: Increasing P gain
That should solve your Problem
If you can't get your wag fixed by P-raising completely, you could slightly overtune P and increase D-Sense a bit.
But this will, most likely, get you a whimmering tail sound in Speed flights. (as you're using an improved landing gear, I dont think, that you'll do them in the near future)
I could also be possible that I gain is way to high (I is for constant pirouette rates, to high I Gain makes also a slow wag)
But first i'd try P increasing.
edit: whats the distance between the 5085 center + linkgabe Ball? You might need to put the linkage one hole outwards.
(damn i've forgotten all my english...)
almigurt is offline        Reply With Quote Quick reply to this message
Old 04-17-2013, 11:51 AM   #3 (permalink)
D & I are at 60. D-sense is 30
Old 04-17-2013, 11:54 AM   #4 (permalink)
Here is the tail setting with no rudder input.
ID:	413241   Click image for larger version
Old 04-17-2013, 12:01 PM   #5 (permalink)
My GT5 is about .5mm out from being inline with heli, do I need to correct this?
Old 04-17-2013, 12:13 PM   #6 (permalink)
Try Increasing p by 10 points.
Did you read Gary's gt5 guide?
Old 04-17-2013, 12:25 PM   #7 (permalink)
Thanks, I'll try that. I did read it, but that was before I started using it. I will read it again.
Old 04-24-2013, 10:32 AM   #8 (permalink)
Well I went through 5 batteries trying to get this thing set right, but not there yet.
One big problem I had was servo speed was too low. GT5 servo speed only goes up to .12? and my tail servo is suppost to be .1275. Cyclics are good @ .105.
Another issue was piro correction was reversed. So it's much better, but I still can't get the tail solid, it rebounds a bit on stops. I've played with P, I, D, up & down, as well as deadband & smooth stop a bit. Started looking over possible mechanical set up problems, but everything looks good. Anyhow I have to put it down for a while, so I'll play with it some more when I have time.
I'm getting good at navigating the GT5, and love being able to land, adjust, fly, but I'm a bit frustrated Hopefully I can figure it out.
