nano CP X Blade nano CP X Helicopters Information and Help |
04-18-2014, 09:30 AM | #1 (permalink) |
Is this the right part?
I just received part number BLH3325, the brushlee upgrade for the nano. The tag attached to the motor wires says BLH 3326, and frankly I am not sure wher thr battery wires, what appears to be a charging wire and the large black blob at the top in the picture are for. I don't think it will fit in there anyways.
04-18-2014, 10:02 AM | #2 (permalink) |
That is the right part. The BLH3326 is the part number for just the board, so that is the correct label. I'm not sure what you mean by "the large black blob", but everything will fit. It is a bit tight.
04-18-2014, 10:20 AM | #3 (permalink) |
Thanks. The blob is the black square part where the wires go into from the motor. I have it folded over the front of the board.. what about the new connector from the motor to the battery? Still have the similar one coming from the board.?
04-18-2014, 11:10 AM | #4 (permalink) |
I think you are refering to the ESC. The ESC plugs into the recievers battery plug, then the battery plyg plugs into the battery. Or, was it the other way around? Point is its an adaptor to power the ESC.
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7 Courtesy Clerk at Safeway, Lonetree! |
04-18-2014, 01:35 PM | #5 (permalink) |
The original 3 in 1 board plugs into the wire from the new esc, and then that wire plugs into the battery. You should have gotten an instruction sheet with the BL upgrade kit that shows how to install it in drawings.
04-18-2014, 01:57 PM | #6 (permalink) |
Make sure you zip tie or tape the esc to the board with electrical tape or you'll be re-soldering power wires to the esc in no time. The double sided tape doesn't work too well.
DX8, Mcpx BL, Tarot 450 Pro V2 |
04-18-2014, 04:05 PM | #7 (permalink) | ||
Thanks |
04-18-2014, 06:21 PM | #8 (permalink) |
I use the black piece of tape that came with the kit more or less for cushioning. I then cut a long thin strip of black electrical tape and wrap it around both boards to hold the esc in place. Be careful with the battery wires coming from the esc, they break off easily.
04-19-2014, 02:49 AM | #10 (permalink) |
I do the same, with the tape. Ruined a board just relying on the double sided tape. Credit to Horizon as I just received a whole new bl kit today free of charge and put it in.
04-19-2014, 05:54 AM | #11 (permalink) |
So dont use the tape provided then when installing it? What is th best method?
