500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-03-2013, 04:26 PM | #301 (permalink) |
I tested 70% throttle on the Trex 500 V2 flybar kit with the BL70G in governor mode and the RPM dropped to 2355 rpm. I didn't really notice a big difference in performance for my flying so I am keeping it there. I didn't notice any more heat from the ESC than normal. I might experiment with lower throttle but I don't think I would want to keep it much lower than 70. I have yet to review how dropping to 70% has impacted the held rpm consistency (variance in rpm at hover and during maneuvers). I am curious if it got better or worse and I suspect it got worse.
Helis: OMP M4, M1 Evo DLGs: Solar, Arctus, BAMF 2 Previous helis: Concept 30 DX, HeliMax MX400, Trex 450, 600, 700e F3C V2, 500e, 550e V2, Nano CP X, MCP X BL Last edited by StatiC; 12-03-2013 at 09:24 PM.. Reason: 1350 should have been 2350 |
12-03-2013, 08:47 PM | #302 (permalink) |
Did you mean 2355? 1355 seems awfully low, and you said you were getting 2440 rpm at 75%.
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3, Oxy 3 <> <> Builds in progress: Logo 600SX, Synergy 516 <> *Spartan Vortex VX1e*
12-03-2013, 09:23 PM | #303 (permalink) |
Yea... typo... 2350 rpm.
Helis: OMP M4, M1 Evo DLGs: Solar, Arctus, BAMF 2 Previous helis: Concept 30 DX, HeliMax MX400, Trex 450, 600, 700e F3C V2, 500e, 550e V2, Nano CP X, MCP X BL |
02-06-2015, 09:46 PM | #304 (permalink) |
Im using 5300mah but fly scale in a 500e fuselage so space is not an issue
02-11-2015, 08:41 PM | #305 (permalink) |
Any thoughts on these in a 500e, anyone?
http://www.valuehobby.com/power-syst...0mah-6s-t.html I like the fact that they already come with a Deans connector installed, and the price is also pretty good. They are a little on the large/heavy side, though. Do they fit, and will the COG be OK? They also have slightly smaller/lighter ones, but they have been out of stock forquite a while already: http://www.valuehobby.com/power-syst...6s-lipo-t.html |
02-12-2015, 07:28 AM | #306 (permalink) |
I been using these Geforce as my preferred battery i dont fly 3d only sport scale flying, great packs for the price
02-12-2015, 10:08 AM | #307 (permalink) |
Wow, those are some big suckers! They certainly won't fit under the stock canopy. Are you using them in that MD500?
02-12-2015, 10:18 AM | #308 (permalink) |
Yes sir and not by preference but also the noseweight is needed for balancing
03-23-2015, 04:54 AM | #309 (permalink) |
Just FYI,
Rapicon 3300 30c and Zippy Compact 3300 60C fits into 500 L Dominator, but I dont think a bigger battery than Zippy Compact will fit this heli.
www.losalcotanes.com |
06-18-2015, 05:23 PM | #310 (permalink) |
Anyone know what is the largest 6s battery that will fit in an old 500GF with a fusuno EX canopy?
06-18-2015, 06:02 PM | #311 (permalink) |
Have you done the battery tray mod? If so, then 3300 is about the largest I've seen. You also have to worry about CoG too - any larger than 3300, and the heli is going to be really nose heavy.
06-18-2015, 11:30 PM | #312 (permalink) |
I haven't done any mods apart from buying a larger canopy.
Are you talking about the clear plastic one in the sticky? |
06-19-2015, 05:35 AM | #313 (permalink) |
Probably 3000mAh then, the mod makes the space for the battery larger. However I wouldn't suggest you going bigger than 3A battery, bear in mind that higher C will also make the battery bigger, with the mod done my bigguest lipo is 3000mAh 40C . If you want a heli thats agile then 2650mAh or 2800mAh is better.
06-19-2015, 10:18 AM | #314 (permalink) |
No, go back to the first page of this thread, and you'll see pictures of the mod. Essentially, it just lowers your battery tray. On your heli, your battery tray will meet the upper front corner of your servos. After the mod is done, it should meet somewhere near the middle.
06-23-2015, 10:05 PM | #315 (permalink) |
since this made it to sticky and given its name biggest lipo in a trex 500
It should become a contest Im thinking 6s 10,000 mah ill go first |
06-25-2015, 09:49 PM | #316 (permalink) |
I started using the Revolectrix 6S 3000 HV (charged to 4.3v/cell), the batteries are a little heavier but I run 8 minute flight times @ 2550 RPM. I also have a couple Magnum 6S 2800 that I run for 7 minutes.
I mount the two battery types slightly different, the 3000s put the bird just slightly nose heavy, and the 2800s slightly tail heavy, the change in CG is not really noticeable, but the weight difference is a little bit noticeable. |
06-26-2015, 03:08 AM | #317 (permalink) | |
How are those HV Revolectrix performing, ballancing, cell IR, etc? They have a great capacity to weight ratio. Wich BEC are you using? I am afraid my Castle10A BEC will be damaged with HV batteries (higher than 25.2volts). Thanks Last edited by Mateyhv; 06-30-2015 at 01:46 PM.. |
06-26-2015, 04:32 AM | #318 (permalink) | |
Biggest lipo in trex 500.
In a more satisfactory condition I think you'd be better off if you were using a Castle BEC Pro and didn't use the 10A version which is really limited. |
09-06-2015, 12:46 PM | #319 (permalink) | ||
Anyone know what kind of battery Alan is using here?
I have the same heli and using nano-tech 2650 and only get 2:50mins. They come down a little hot and around 20-25% left. 100% flat throttlecurve and 3D flying.
Align T-Rex 700N DFC w/Brain (Redline 100H) SAB Goblin 500 w/Brain (Scorpion 4025-1100) |
09-06-2015, 06:13 PM | #320 (permalink) | |
Align 3300mAh |
