Old 07-14-2010, 04:05 PM   #161 (permalink)
Originally Posted by FurryTrex View Post
why is everyone so worried about cg, and batteries weights and what not. if anyone is a decent flier you can compensate for any of this. so please stop worrying about all this nonsense and put those 3300's in and go fly
On a FBL heli CG is very very important so if u have FBL then worry about battery weight. But even still it sucks always having to fight the CG
burton8012 is offline        Reply With Quote Quick reply to this message
Old 07-18-2010, 05:26 PM   #162 (permalink)
Default home made under skid bettery mount
TodayI tested my home made battery mount I made for fpv flying and had my first 13 minute flight on a 4800mah 6S lipo. it was a lot less nimble but for FPV its all about range/flight time.
Align Trex 600e, 2x Align Trex 500cf, Align Trex 450SA, 450 Pro, Blade 400, JR X9503, JR XP7202
I must be doing something wrong! I keep planting helis but new ones never grow?
kenn_palmer is offline        Reply With Quote Quick reply to this message
Old 07-23-2010, 05:48 AM   #163 (permalink)
Anyone running 2x3000mah 30c's? Was looking at these on HobbyCity.com
http://hobbycity.com/hobbyking/store...idProduct=9497
But then I saw some 2650mah 3S, 40C's for $24.95. http://hobbycity.com/hobbyking/store...idProduct=9947
What do you guys think? I'm not going 6S always going to run 3sx2.
joeyhatch11 is offline        Reply With Quote Quick reply to this message
Old 07-23-2010, 06:37 AM   #164 (permalink)
Originally Posted by Kenap View Post
The above quote seems to be correct for the older T-Rex 500s. However, I have a new T-Rex 500 ESP and the battery drop method doesn't work for my Hyperion 3300 battery because the battery is too wide on both sides. It won't fit in between the heli sides.The good news is that I only had to slide it down the tray a bit with NO modifications whatsoever.
It does bring the CG forward a little, but because I'm using a standard servo on the tail, my balance was perfect.
With this mod you only need 2 holes...works great!
https://www.helifreak.com/showthread.php?t=108787
Mark, AMA #922614
Blade mCX
Trex 450SE, Spektrum DX7
Trex 500 ESP
"I can do Awesome 3D, just not intentionally..."
mwillack is offline        Reply With Quote Quick reply to this message
Old 08-22-2010, 07:48 AM   #165 (permalink)
Back to the packs.... Guys I got a set of Hyperion 6S VX 2950s and they Rock. I have tried the HC stuff, Turnigy, FF and so far these seem to be the best IMO. I puffed the HC stuff and went with Hyperions and TP 45C and they are too close to call. They maintain power better than anything I have tried.
Rave, Next-D, Radix
Scorpion Power Systems
GensACE
fnity3632 is offline        Reply With Quote Quick reply to this message
Old 08-28-2010, 01:27 PM   #166 (permalink)
Default is it too heavy?
Now that I got my battery ( turnigy 3.0 6s 3000mah) my question is- is it too heavy??
I weighed my T-rex 500 with the new battery- it now weighs 4.0lbs!! is that too heavy? I am a noob so not sure..
beeskybrew is offline        Reply With Quote Quick reply to this message
Old 08-28-2010, 05:35 PM   #167 (permalink)
I use the same battery (I have 2 packs). Gives me a around 5 minutes of flying (I don't do 3D yet) and I find the CG of the T500 to be OK with them. I just need to move the battery a little bit to the front to make the CG perfect. They are not heavy at all.
what-d-heli is offline        Reply With Quote Quick reply to this message
Old 08-28-2010, 07:38 PM   #168 (permalink)
How many cycles do you have on them? I have that same battery (turnigy 3000mAh) and I get 6:30 hard sport with 3.8V left in each cell. Have you checked your gear mesh, tracking, etc?
-Goblin 700: Crashed but re-building, still needing electronics
-Goblin 630: CC Ice 120HV, vBar
scoti333 is offline        Reply With Quote Quick reply to this message
Old 08-28-2010, 08:20 PM   #169 (permalink)
They are just about 10 cycles each. My T500 is smooth, no issues what so ever. My timer is set at 5 minute mark (8FG). But I don't land immediately. I take my time to hover then set it down gently (not used to high autos yet). So, probably...it is somewhere in the 5:15-to-30 range when I pull the plug. I do believe you can get as much as you are saying (more than 6 minutes), but I "baby" my LiPo .
Old 09-03-2010, 07:26 AM   #170 (permalink)
Anybody using the new Hobby King Nano-Tech batteries ?
I was wondering about something like this.
http://www.hobbyking.com/hobbyking/s...~50C_Lipo_Pack
gonzalo38 is offline        Reply With Quote Quick reply to this message
Old 09-03-2010, 08:50 PM   #171 (permalink)
what confuses me is they say these are 25-50C ??
Brick is offline        Reply With Quote Quick reply to this message
Old 09-09-2010, 10:30 PM   #172 (permalink)
25c is the continuous amperage draw rating, the 50c would be the burst rating, so it could handle short bursts of 50c draws (ie: crazy climb-outs) and regular flight continuous draws of 25c. Make sense?
Danno
Blade 500x, Trex 500xt, just back after some time off. You don't ever really QUIT helis do you??
DKS_ONE is offline        Reply With Quote Quick reply to this message
Old 09-13-2010, 07:08 PM   #173 (permalink)
I always wondered what batteries others were running in their T-Rex 500 ESP helis. When I got my kit, I ended up with a Venom 25C 5S 3600 Battery and bought another as my second battery. They work great and with just FF and some punch ups and a lot of learning in Idle up, I have my timer set to 6 minutes and still have a lot of battery left when I land.
I ordered the 550e and went ahead and got the battery. It's a Venom 6S 3600 and although it is bigger, it fits and actually cures the small amount of tail heaviness. It makes a bit punchier and a bit more headspead too. 6 minutes on it and it hardly drops below 4 volts per cell, where the 5S was going down to about 3.85.
I was suprised it handled it and that it balanced almost perfectly. So far the Venoms have been very spot on quality wise.
T-Rex 250FBL 3G, T-Rex 450 DFC AR 7200 BX, 450 Pro Airwolf T-Rex 500, T-Rex 550 FBL BeastX, Trex 600N OS 55 IRCHA Special Edition Black, Trex 600e Pro AR 7200BX Trex 700X BeastX Plus, DJI 450 NAZA/GPS and DJI 550 NAZA, Phantom 2, Phantom 3 Pro
TossinHoss is offline        Reply With Quote Quick reply to this message
Old 09-22-2010, 12:53 PM   #174 (permalink)
I use 25c 3600mah on the latest 500esp and get 8-9 mins with a scale ec-135 fuse on it. I get 10-12 mins of gentle sport flying with just the standard pod and boom, these batteries fit with no mods and give me perfect cog
scott1uk is offline        Reply With Quote Quick reply to this message
Old 09-24-2010, 04:56 PM   #175 (permalink)
yea 25 Amp is continuos and 50 amp is burst. Real nice
TBS Discovery / Nemesis 240 / Park Zone Sport Cub / Taranis X9D / Black Pearl 7' FPV Monitor / iCharger 206-B / Sony 2.8 FPV camera / GoPro Hero 3 Silver +
T/CHunter2009 is offline        Reply With Quote Quick reply to this message
Old 10-08-2010, 04:27 PM   #176 (permalink)
i have the old frame the battery is 147x45x40 this is where it mount it with no mods to the frame but i do have the fusuno 500EX canopy witch is much more roomy i halve to slide it way down the trey with the stock canopy the fusuno canopy's are tough and worth the money IMO especially with the extra room on the ex size.
but center of gravity is good mounted like this, not sure what it weights
Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more.
dannylightning is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 07:57 PM   #177 (permalink)
what you guys think about these batteries?
http://www.hobbypartz.com/83p-3300mah-6s1p-222-30c.html
i have a trex 500 esp,would it be to heavy for it?
celm is offline        Reply With Quote Quick reply to this message
Old 10-18-2010, 10:34 AM   #178 (permalink)
can anyone tell me if the specs on this battery will be to heavy for my bird? just want to know before i buy it
Capacity: 3300mAh
Voltage: 6S1P / 6 Cell / 22.2v
Discharge: 30C Constant / 30-60C Burst
Weight: 495g (including wire, plug & shrink wrap)
Dimensions: 134x45x45mm
Old 10-18-2010, 01:30 PM   #179 (permalink)
the turnegy 3300 are 544 grams according to the website and lots of people use those
and i found this on one of the reviews on that battery
495g listed weight is incorrect!
Actual weight = 566g
Old 10-18-2010, 01:54 PM   #180 (permalink)
so dont go with that battery then?
u think that is to much for the 500 heli?
