500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-25-2014, 03:15 AM | #1 (permalink) |
ESP Tail Pushrod?
Where can I find a CF pushrod set for my 500 Esp The Pro version are longer arent they?
Alzrc have one for 8US, But its a pro.Pro servo under heli wheres as my servo on boom.
Assualt 700 Align DomL 500 Align 470lp Dx9 Fly like there's no limits ! |
04-25-2014, 04:27 AM | #2 (permalink) |
I got the pro, they don't make one for the esp. I had to pull the end off, cut it to fit, and superglue the end back on.
Rich. I WISH !!! |
04-25-2014, 04:55 AM | #3 (permalink) |
Thanks dyn2fly, I thort that might be the case.
Cheers
04-25-2014, 06:44 PM | #4 (permalink) |
I just zip tied a 2mm carbon rod to the ESP steel rod. Looks a little tacky but works great. No need to remove ends from the old one.
Mini Protos 3x HS5065mg, AR7200BX, JR290 Trex 500ESP Robird, Oxy 2, OXY 3, Oxy 4 All on Dx8G2 AMA 732104 |
04-26-2014, 04:32 AM | #6 (permalink) |
2mm hollow cf rod and slide the metal one though it? or do you mean actually side by side and zip together? Wouldn't that really look crappy? Can you take a pic at all for me, Im trying to picture it.lol
So you can take the 2 boom guides off then by doing this?
04-26-2014, 07:00 AM | #7 (permalink) |
yep, sure can. I don't use mine and it's been thru 4-5 crashes and survived.
still hard to believe !!! lol you run the metal rod thru the middle of it.
Rich. I WISH !!! |
04-26-2014, 08:16 AM | #8 (permalink) | |
I didn't because I didn't feel it was necessary. Whichever method you use, I'd still use the pro pushrod guide (comes with pro cf pushrod kit). You go from 2 guides to 1 and you don't have to shim the guide with zip tie section. |
04-26-2014, 03:41 PM | #9 (permalink) |
I take the original pushrod, install it on top of a CF rod with CA and heat shrink tubing. Put the heat shrink over the pushrod and CF rod, drip some CA glue into it and hit it with a heat gun. I make 3 small sections @ about 2 inches each (one on each end and one in the middle).
04-26-2014, 05:01 PM | #10 (permalink) |
I dont use any guides on any of my 500's using CF tail rods.
Trex700N2E Trex500ESPTT(PRO head and Tail ) Trex500ESP (Belted) HC500SE ....GO TEAM FLYBAR! |
04-26-2014, 05:26 PM | #11 (permalink) |
Cheers guys, Mite pop into the LHS before it closes down this week and grab me a piece of CF tube.
Cheers Gav
04-26-2014, 06:46 PM | #12 (permalink) |
Mine are mounted side by side. ya it looks tacky, but quick and easy. No need for the two guides.
05-02-2014, 12:41 AM | #13 (permalink) |
I just added some super glue to the rod and slid the CF rod over the wire. No guides needed and use the same setup for both my 450 and 500.
Trex 700L Ikon 2 / Trex 700L Ikon V. 2 / SAB Goblin 500 Sport Ikon 2 / HD Cell 500 Ikon 2 It isn't about if, it is about when! |
05-03-2014, 09:49 PM | #14 (permalink) |
Thanks Solmanbandit. I did the exact same as you. CF tube over the rod with CA glue. Went for some flights this morning. Works great and looks good to. Didnt change the feel or performance of the tail. Thought I mite have noticed something.
Oh well looks good anyway and for $7 for 2 bits of tube cant go wrong.
05-04-2014, 09:44 PM | #15 (permalink) |
I have used this setup to make custom tail rods for all my helis from 450 to 700:
http://www.centralhobbies.com/contro...e/pushrod2.htm For 500 I use the 1/8 rod with 2.5mm ends.
________________________________ TRex 700E (2) - Fusion 50 (4) - Goblin 630 TRex 500 (5) - Trex 450 (6)... Hell, lots of Helicopters. Lots. Airplanes and Quads too. Unless this is my wife reading this, then just a couple. |
05-05-2014, 03:55 PM | #16 (permalink) |
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz |
