X5 Discussion and support of the Gaui X5 |
10-01-2014, 01:44 AM | #1 (permalink) |
Does anyone know what this is about...
Guys,
I was browsing the Gaui website the other day and found this under 'Information/Technical' and I qoute: CNC Tail pitch slider set (for 5 mm tail output shaft) and CNC Extra Strong tail pitch slider set (for 5 mm tail output shaft) TECHNICAL INSTRUCTIONS: Greeting dear customers, Tai Shih Hobby Corporation/GAUI in order to satisfy the different flight characteristic need of different users (from novice level to professional level pilots). GAUI provide for you a selection of products which suit your particular need and flight level. Please select the products that that suits your flying style. Notice: CNC Tail pitch slider is the most important mechanical structure on the tail of helicopter. All RC Helicopter pilots should make regular check and maintenance of this part in order keep flying safely. RECOMMENDATION AS FOLLOW: BASIC LEVEL USER (STANDARD) Please purchase CNC Tail pitch slider set (for 5 mm tail output shaft) Models part number information below: 204640-CNC Tail Pitch Slider Set (for 5mm tail output shaft) 208369-CNC Tail Pitch Slider Set (for 5mm tail output shaft) 213654-CNC Tail Pitch Slider Set (for 5mm tail output shaft) 215042-X4 II CNC Tail Pitch Slider Set(for 5mm tail output shaft) MID TO PROFESSIONAL LEVEL (EXTRA STRONG) 204648-Extra Strong CNC Tail Pitch Slider Set(for 5mm tail output shaft) 208388-X5 CNC Extra Strong Tail Pitch Slider Set(for 5mm tail output shaft) 213668-X4 CNC Extra Strong Tail Pitch Slider Set(for 5mm tail output shaft) 215087-1 X4 II CNC Extra Strong Tail Pitch Slider Set(for 5mm tail output shaft) 313089-NX4 CNC Extra Strong Tail Pitch Slider Set(for 5mm tail output shaft) WISH YOU A JOYFUL & SAFE FLIGHTS GAUI TEAM WITH REGARDS http://www.gaui.com.tw/category/technical/ Could someone please shed some light to this?
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.) Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo JR XG14 PL8 v2 |
10-01-2014, 09:50 AM | #2 (permalink) |
I got one on my NX4 kit but didn't realize it at the time. Unfortunately I messed up the brass bushing while taking the slider apart to make sure it wasn't too tight. I can't find anyone that stocks those parts or the thicker bushing (it's 7mm O.D. instead of 6mm)
Counting on the US distributor to bring stuff in is an exercise in frustration sometimes. |
10-01-2014, 10:04 AM | #3 (permalink) |
I'm sure I don't need it, but dammit, I want my s&!# to be "extra strong".
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon) Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi) AMA Member, HCAM Member |
10-02-2014, 12:12 AM | #4 (permalink) |
I can't seem to find any of those 'super' strong ones on stock....
This blows, I do not need any part on my heli only strong enough for 'beginner flight'...
10-07-2014, 12:03 PM | #5 (permalink) | |
"We want to make money so we over charge you for parts you 'need' in order to fly hard safely" |
10-08-2014, 10:01 PM | #6 (permalink) |
Today my pitch slider failed. The heli spun out of control and crashed. $100 worth of replacement parts.
I did a quick search on X5 pitch slider failure and got quite a few hits. Evidently, Gaui has recognized this problem and offers an extra strong version 208388-X5 CNC Extra Strong Tail Pitch Slider Set(for 5mm tail output shaft)In the 208388, the brass bushing is thicker and therefore stronger, but no other part of the slider has been changed. And, it's not available in the U.S. The upgraded brass bushing is available separately---though I don't see it listed on any U.S. sites. I just received an email from Dave Mullen at anythingheli.com pointing out that the best tail slider for the Gaui X5 is Gaui's Dual Push Tail Pitch Slider Set (SKU: 935002). It's expensive: $70. But its design is clearly superior. Both the stock 208369 and "extra strong" 208388 slider introduce a twisting force by having the attachment ball on one side of the slider. I suspect that this design also makes these sliders prone to impact damage. The 935002 is available at anythingheli.com. I just ordered it. It’s interesting that my Blade 450X, Gaui X3, and Goblin 570 all employ the dual push system used by the 935002. Only my stock X5 does not.
Blade 450X, Witespy Quad, Gaui X3, Gaui X5, Goblin 570, Goblin Black Thunder Last edited by lmcwilli; 10-11-2014 at 08:44 AM.. |
12-06-2014, 03:14 PM | #7 (permalink) |
I finally got around to replacing the failed pitch slider on my Gaui X5 FES with the Gaui X5 Dual Push Tail Pitch Slider Set (SKU: 935002).
But I soon realized that this installation requires the CNC Tail Gear Case---not the stock case. Wow. This ended up being an expensive crash caused by a part failure. $69 for the slider + $61 for the CNC case plus the $85 for parts lost in the crash = $215 !
Blade 450X, Witespy Quad, Gaui X3, Gaui X5, Goblin 570, Goblin Black Thunder |
