Old 04-05-2014, 12:42 AM   #1 (permalink)
Default Just ordered my trex 700e dfc hv kit
What's up freaks beeN away for a while and I was just wondering if there is any major mechanical Difference s between the dfc hv kit and the new pro dfc kit with the new canopy and blades? Also I've heard nothing but bad things about the 3gx system and am wondering if the spectrum ar7200bx would be a good choice or should I splurge for the Mikado vbar and if I were to run some servos that pull low amps such as the outrage 9180 s is there a way to run everything off the main flight battery's with a regulator I'm new to flybarless and to 12 s so any advice would be great
dbargetrex500 is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 02:14 AM   #2 (permalink)
Well, here's some good about the 3GX: It works just perfectly for 3D on the 700E.vI've heard it's less good on really small machines, but on larger ones it's perfect.
Use something like an Hercules Super BEC to run it all of the flight pack, it's by far the best way to go along all crteria (reliability, simplicity, ...) .... except price I guess!
HarveyR is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 07:25 AM   #3 (permalink)
I could never get the 3GX dialled in the way I wanted it so I went for the Vbar and never looked back, have them on all my big birds.
As you have the HV kit I would go for a 2s lipo to power the RX and servos direct, never had any issues doing that but others here do prefer using a BEC, either way you should be fine.
Velos 880 Neo, Logo 800 XX Vbar, T-Rex 800 Pro DFC Vbar, T-Rex 800 Trekker Vbar, T-Rex 700 Pro DFC Vbar, T-Rex 800 F3C Vbar, T-Rex 550E DFC Vbar, T-Rex 500 Pro DFC AR7200BX, T-Rex 450 Sport V2 AR7200BX, T-Rex 250 Pro AR7200BX, VController, DX9.
JohnTC02 is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 07:59 AM   #4 (permalink)
Earlier this year I ran 2s life on all my helis until I accidentally ran one dangerously low. Since then I switched everything over to BEC. I also like the simplicity of it.
I purchased the Gryphon 75V 20A HV Switching BEC and have had good luck with them.
If you decide to go the BEC route castle creations bec pro 12s switching regulator is another option at only $41.00. I think its a good value for most. Out put voltage is 4.8 to 12 volt.
ALIGN 800 DFC PRO, SAB KRAKEN 580, SAB GOBLIN 700
bradi is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 09:42 AM   #5 (permalink)
Never used a life, I have the TM1000 telemetry interface on all my birds that run a 2s lipo for RX and servos, this monitors the pack voltage so when it gets to a preset voltage I will get an onscreen warning along with an audible bleep.
Never had any issues with this system, it always warns me when I need to change my RX pack.
Old 04-05-2014, 05:56 PM   #6 (permalink)
Originally Posted by dbargetrex500 View Post
What's up freaks beeN away for a while and I was just wondering if there is any major mechanical Difference s between the dfc hv kit and the new pro dfc kit with the new canopy and blades?.
No mechanical difference that I'm aware of. Main, tail blades, canopy and motor are different. everything else the same.
Old 04-05-2014, 10:31 PM   #7 (permalink)
Elevator bracket is different also. Pro n standard birds will fly the same except a little more punch because of a bigger motor and more aerodynamic in backwards flight due to new canopy design. Pro has newer servo's and new castle edge esc.
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 11:31 PM   #8 (permalink)
We all run the Ar7200bx and it works great. But don't forget you need a sat too.
TS3D#1
NanoCPXBL,TREX550PRODFC,
TREX700PRODFCHV, DX8
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
Old 04-06-2014, 08:06 AM   #9 (permalink)
Yes Sir...I now run telemetry on all my birds as well. Its a nice safety feature. Also run scorpion back up guard.
I forgot to mention another reason why I like the BEC method. I fly a lot in the winter months and didnt want to risk an on-board lipo / liFe failure in cold weather. Im also lazy, I dont want to plug in another connection or turn a switch on...lol.
Thanks for the clarification...I have often wondered the exact difference. And yes, the only difference that I have noticed in (sport) flight between dfc pro and older 700e is power. Both of my 700s are set up the same with the exception of servos.
Old 04-07-2014, 03:27 PM   #10 (permalink)
Oh I thought the ar7200bx was an all in one unit with the sats
Old 04-07-2014, 03:34 PM   #11 (permalink)
Has built in antenna but bigger birds require optional separate sat. Like a trex 250 doesn't need the optional sat but bigger birds do. For peace of mind I'd put the extra sat reguardless.
AMA #1039539
Old 04-07-2014, 03:36 PM   #12 (permalink)
Double post
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 03:43 PM   #13 (permalink)
Yeah the extra sat is only $35 or so.
DX8, Trex 700 dfc, Trex 550 dfc, Oxy3, Rifle 1M (plank!) PL8, PL6
atkin is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 10:58 PM   #14 (permalink)
What part would that be like just a spektrum sat by itself?
Old 04-10-2014, 09:26 AM   #15 (permalink)
SPM9645
http://www.helidirect.com/spektrum-d...er-p-23625.hdx
Old 04-11-2014, 01:56 PM   #16 (permalink)
Looks like the servos that come in the kit are rated for 4.8 - 7.4 volts. Does anyone know if it's ok to run a lipo straight into the receiver @ 8.4 volts?
Synergy 516 | Oxy 3 | V Control Host of Full Pitch RC Heli Podcast
jimmy77611 is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 07:54 AM   #17 (permalink)
If you bought the HV kit as you mentioned in the first post, yes, you can use a straight 2S Lipo.
T-Rex 700E Pro DFC, Spirit FBL Unit, Futaba R6303SB/8FGHS
Blade mCPx 140mm boom, DX7
RealFlight 7
davehour is offline        Reply With Quote Quick reply to this message
Old 04-18-2014, 04:33 PM   #18 (permalink)
Hi congrats on your new kit ,,
Sorry to hijack , thought you all might be able to give me a bit of info , as I'm looking at buying this kit too.
I'm not to clued up on the bec and voltage regulators , my 550 is using a talon 90 esc and I run everything off one pack, much like I do on my 450 , when I buy my 700 does the esc not have a built in bec to power my servos and radio ? I don't really want to use an extra radio pack like I had to on my nitros. .
On the Hv kit the only diff I see are the Hv servos , these are rated at 7.5 the 3gx is good for 8.5 , but the align bec steps the v down to 6v so I wouldn't be getting the full potential from the servos , which in that case would the none Hv kite be a better option ??
Sorry for the ? S thanks guys ..
Dx9, Blade Nano ,Trex 450pro ,Trex 550L , Trex 700
aevans692 is offline        Reply With Quote Quick reply to this message
Old 04-19-2014, 08:01 PM   #19 (permalink)
Check it out..
Build Video
Align Trex 700e Pro DFC HV Build (16 min 48 sec)
Build Photos https://onedrive.live.com/redir?resi...=folder%2c.jpg
I hope this helps.
ALIGN T-REX 800E DFC TREKKER
ALIGN T-REX 700E PRO DFC HV
ALIGN T-REX 600EFL PRO DFC
ALIGN T-REX 450 PRO DFC
HeliGriff is offline        Reply With Quote Quick reply to this message
Old 04-20-2014, 08:20 AM   #20 (permalink)
Originally Posted by HeliGriff View Post
One of the cleanest builds Ive seen.....
I like the idea of having the heli ready to go when its your turn. Thats why I decided to use BEC. Just one battery connection through the canopy and go.
Is there a reason why you don't use BEC? It would clean your build further and no switches.
